| removed from a 1959 Lancer: good running 383 does NOT smoke (can send video of it running) complete air cleaner to oil pan, includes a/c compressor, power steering pump, radiator, a/c condenser, a/c lines, automatic trans shifts good, has small leak as I noticed some fluid on floor (just wanted to be honest in description so there are no surprises) complete driveshaft. $2500. I am in Lakeland FL in-between Tampa and Orlando.
Location: Lordstown, Ohio | i can vouch that all above is accurate and to the T the trans shifted flawless and engine ran beautifully | |
