Quantity | Item/Description | Price | |
1 | 300G dash with 150 m.p.h. speedo. 7 button radio and power window switches | 575 | |
1 | 1960 120 m.p.h. speedo. and gauge cluster | 190 | SOLD |
1 | Power brake booster, hard canister w/mounting bracket | 75 | |
1 | Drivers interior windshield pillar trim die-cast/steel | | |
3 | Pairs/sets exterior windshield front top corner stainless | | |
2 1/2 | Pairs/sets exterior windshield front lower corner stainless (1 extra pass. side) | | |
1 | Pair/set exterior back window L shaped across top and down sides stainless (short) | | |
2 | Pairs/sets exterior back window L shaped across top and down sides stainless (long) | | |
2 | Pairs/sets exterior back window lower corner stainless | | |
1 | Left of speedo. dash switch surround | | |
1 | Right of speedo. dash switch surround | | |
1 | Set of door panel and rear side panel pieces (4 pieces 2 door and rear upper) | | |
1 | 300G steering wheel | 230 | |
1 | Dash speaker cover | | |
2 | Pairs/sets interior door handles with recess chrome | | |
2 | Drivers exterior door handles | 50 each | |
1 | Passengers exterior door handle | 50 each | |
1 | Wiper switch | | |
1 | 1961 park brake release handle | 45 | |
1 | Ribbed console insert | | |
1 | 300G grille crossbar and center | | |
1 | Pair/set side trim for rear console | | |
1 | Front console trim-side | | |
3 | Exterior windshield bottom stainless middle long | | |
2 | Exterior windshield top stainless middle long | | |
3 | Exterior back window bottom middle long piece stainless | | |
1 | Pair/set interior sunvisors | | |
1 | Pair/set rear armrests | | |
1 | 300F/300G side emblem bezel | | |
3 | 300F/300G side spear trim front-short | | |
1 | Ignition key/lock cylinder surround | | |
2 | Sets transmission pushbuttons with bezel | 65, 75 | |
2 | Sets heater control, pushbuttons and bezel (nipples broken) non A/C | | |
1 | Set heater control, pushbuttons and bezel (nipples intact) A/C | | |
1 | 2 door (convertible?) drivers vent window assembly, clear glass | | |
1 | 2 door (convertible?) passengers vent window assembly, Solex glass | | |
1 | Pair/set exterior vent window bottom cover trim | | |
1 | Console ashtray-front | | |
1 | Console ashtray surround-rear | | |
2 | Rear Chrysler emblems unbroken with pins | 75.00 each | |
1 | Rear license plate mount/filler cover plate | | |
1 | Power seat switch with pigtail | | |
1 | Remote mirror with bezel, switch and plastic surround-drivers | | |
1 | Remote mirror control bezel and plastic surround-drivers | | |
1 | Standard outside rear view mirror | | |
3 | Headlight bezels 2 with insert-passengers | | |
2 | Headlight bezels both with inserts, 1 broken-drivers | | |
3 | Pairs/sets rear panel lower curved stainless next to license plate | | |
4 | Rear panel lower straight stainless next to license plate | | |
1 | Dash clock | 50 | |
1 | Tachometer | | |
1 | Steering wheel horn ”ring” w/pads chrome mount and relay contact ring | 40 | |
1 | Pair of horn “ring” pads | | |
1 | 300G steering wheel center | | |
2 | 300H/sport steering wheel center | | |
1 | 1963-64 black steering wheel center | | |
1 | Steering wheel center white with lion/crest | | |
10 | 300 club license plate frames | | |
1 | Mopar factory license plate frame | | |
1 | Set astrodome switches and lower bezel | | |
1 | Master power window switch | | |
3 | Single power window switches | | |
1 | Headlight switch | | |
1 | Interior dome light lens | | |
1 | Pair/set crossram exhaust manifolds with heat riser, tubes and pipes | | |
1 | Power window motor and linkage | | |
3 | Air filter | | |
3 | Taillight bezels 2 intact, 1 broken and piece missing-drivers | | |
2 | Taillight bezels I intact, 1 broken with piece-passengers | | |
1 | Parking light assembly-drivers | | |
1 | Taillight lens used faded intact except small part on corner under bezel-drivers | | |
1 | Taillight lens used good color a few scratches one small broken spot under bezel-drivers | | |
1 | Taillight lens used faded intact-passengers | | |
2 | Taillight lens N.O.S.-drivers | | |
2 | Taillight lens N.O.S.-passengers | | |
1 | Hubcap emblem broken | | |
1 | 300G grille emblem new | 45 | SOLD |
1 | Parking light lens used one small crack-passenger | | |
4 | Parking light lens N.O.S.-passenger | | |
1 | Radio 5 button 1961 | | |
1 | Radio 5 button 1960 | | |
1 | Front bumper non 300 short wheelbase Chrysler and 1961 DeSoto | 125 | |
1 | Battery Tray | 40 | SOLD |
8 | Pieces rocker and wheel well trim moldings | 250/set | |
1 | Exterior driver's dog let trim (for a car without full rocker/wheel well trim) | 100 | |
