´58 torqueflite oil level
MSS73
Posted 2022-06-26 3:29 PM (#622401)
Subject: ´58 torqueflite oil level
Please can someone confirm, how high oil level shoud rise when car has been parked couple days?
My problem is this kind:
Last week i change oil pan gasket, i started car and let it idling.
After that i fill up oil until level was about F mark, couple times i switch every gear and leave transmission to N position.
Everything seems to be ok, i use car and everything works normaly.
But when car was parked about 4 days, there was leaking quite much and oil level was really high on stick.
After 1 or 2 days, there was no any leaking.
Can all that oil be from torque converter?
Leak itself seems to be from that upper joint, i fix that later.
Edited by MSS73 2022-06-26 3:40 PM
(TF oil stick.jpg)
(screenshot-www.automaticchoice.com-2022.06.26-22_26_00.jpg)
Attachments TF oil stick.jpg (217KB - 92 downloads)
Attachments screenshot-www.automaticchoice.com-2022.06.26-22_26_00.jpg (71KB - 89 downloads)
Posted 2022-06-26 3:40 PM (#622402 - in reply to #622401)
Subject: RE: ´58 torqueflite oil level
20001000500100100252525
Perfectly normal. The rise in fluid level is caused by converter drain back i.e. when not running, a little over half the fluid in the torque converter will drain into the sump. When restarted the converter will fill back to normal capacity.
Shep
Posted 2022-06-26 7:00 PM (#622407 - in reply to #622402)
Subject: Re: ´58 torqueflite oil level
20001000100100100252525
If you filled it based on the full capacity of about 11 quarts, then it is way overfilled as the convertor holds a lot fluid by itself.
