Hi
does someone knows the size of the thread original carburetor studs? I'm adding a thicker temperature insulation gasket and I'm going to need longer ones. Thanks!!
Posted 2022-09-13 12:41 AM (#624227 - in reply to #624224) Subject: RE: Intake carburetor studs size help
hemidenis - 2022-09-12 6:50 PM. Does someone knows the size of the thread original carburetor studs? I'm adding a thicker temperature insulation gasket and I'm going to need longer ones. Thanks!!
I went through this with my 56 Dodge and what I found out was:
56D500boy - 2016-11-08 7:38 PM
FINAL UPDATE - on this topic. Bought 5/16" x 24 nuts and lock washers at Lowes yesterday. Not stainless. Just the regular plated. Installed them. Saved the original nuts and lock washers for the next purist.
Posted 2022-09-13 11:39 AM (#624241 - in reply to #624224) Subject: RE: Intake carburetor studs size help
The intake manifold is threaded 5/16"-18 and the factory studs have 5/16"-24 at the carb end. Summit has a variety of studs in different lengths.
5/16"-18 All-Thread rod will work but the correct type studs with a space between the two threads can be torqued into the manifold and won't back out when the nuts are loosened.
