Location: N.W. Fla. | Car needs upper/lower control arms or bushings, tie rods ends. Place thinks the wheel bearings & ball joints also but they don't have all that much milage on them. So..individual parts or kit? Rock Auto Kanters, or the usual parts houses? |
Location: northern germany | Individual parts! Only replace really worn out parts. Do not exchange quality OE parts with China stuff without a reason. |
Location: N.W. Fla. | looks like mainly upper and lower A arm bushings. |
Location: Perth Australia | Having a go at fixing the drag link for mine as we speak.
I have one that someone cut and extended that had perfect ball joints, so I have pressed it out and I
have pressed out the bad one from the link I am going to use. Today, I am going to try and work out how to get it back together.
The end thats bad is the steering box/pitman arm end
Location: N.W. Fla. | seems that the lower control arm bushings aren't available from the usual suapects inc. RockAuto, just uppers... |
