With the aid of a wide flat blade screw driver, I've answered my own question: The filter is the normal spring-loaded ceramic filter element. Difference is instead of glass bowl to hold the filter element and spring, this one has a stamped steel bowl. I guess the concern was glass bowl breakage but....was that ever a real thing???
Replacement filter elements are Carter 30-82. Available through Carter (I presume) and aftermarket resellers like JEGS (as a 180-30-82)
https://carterengineered.com/fuel-filter-30-82
Edited by 56D500boy 2023-02-02 8:48 PM
(InsideTheMysteriousMetalBowlCarterFuelFilter.jpg)
(Carter30-82FuelFilterElementAndGasket.jpg)
Attachments ---------------- InsideTheMysteriousMetalBowlCarterFuelFilter.jpg (144KB - 40 downloads) Carter30-82FuelFilterElementAndGasket.jpg (148KB - 40 downloads)
