| Looking for a brake pedal return spring for a 1959 Plymouth Belvedere. Message me or reply if you have one. Thanks |
Location: So. Cal | I just buy new ones, and they are cheap. Century C-191 is a good replacement for the '57-'59 power pedal setup and works well.
https://www.ebay.com/itm/124784108177 |
| Oh wow didn’t think of doing something like that. Do you happen to know if there is a difference between power and non-power springs? |
Location: So. Cal | Yes, the non-power spring is much lighter, and smaller. I didn't try to match that one up. Just measure the outer diameter, length between connection points, and wire diameter to match it up to another spring. |
| I unfortunately don’t have one to measure. I got my car disassembled and this spring wasn’t amongst the parts. |
| Yes i use the C191... they are stronger and work better than stock |
| Great! Thanks for the info everyone. |
