1956 Plymouth rear end number?
jerrybev
Posted 2023-07-24 10:42 AM (#630917)
Subject: 1956 Plymouth rear end number?
500100100
I am seeking to improve gas mileage. I am a senior citizen and drive as gently as possible and get 11 mpg. Wondering if the housand or something can be changed to improve gas mileage. It is a 56 blevedere 4 door station wagon, automatic transmission. with a 318A 1958 engine in it. serial # 26556317
Does anyone have access to information to reveal what rear end gear it has? The tag on the rear end is missing. Would it be a 8 3/4 rear end?
Whatever rear it has, would a later model one fit in ?
thank you for your time and help
jerry whitfield in N. carolina
(1956 ply rear xxxsmall.jpg)
Attachments 1956 ply rear xxxsmall.jpg (111KB - 434 downloads)
Posted 2023-07-24 2:53 PM (#630929 - in reply to #630917)
Subject: RE: 1956 Plymouth rear end number?
500050001000100
Jerry: I think in those years 55-56 the estate wagons of the senior cars (Chrysler and Desoto) would have had 8 3/4" rear ends. However, I think your 56 wagon would only have the 8 1/4" rear end.
The axle ration is probably stamped on the nose of the pinion carrier as shown in the photo below. I would guess that the ratio would be 3.54 but it might be 3.73. You can confirm this by checking the stamping and/or jacking one wheel up safely (with a jack stand for safety) and, with the eBrake off and the transmission in Neutral, count the number of rotations of the drive shaft per one rotation of the elevated rear wheel.
58coupe
Posted 2023-07-25 12:14 PM (#630944 - in reply to #630917)
Subject: Re: 1956 Plymouth rear end number?
1000500100100252525
The 8 1/4" rear diff. was used in the 6 cylinder cars until I believe 61 but pretty sure you won't find a ratio lower than 3.31 which would be some improvement. The 8 3/4" rear used in the V-8 Plymouths from 57 on and also Dodge, Desoto, and Chrysler has a lot more options but is not an easy bolt in.
You have to change the complete housing and the width is different. Search in the archives to see what others have done.
Posted 2023-07-26 2:23 AM (#630966 - in reply to #630917)
50005000500
If you want to put a later 8 3/4 into it, you will need a '65-'67 B-body rear. The '68-'70 B-body will work too, but with more custom offset on your wheels. You will need to remove your original spring mounts, clean them up, and weld them to your new housing at a 41" separation. You will also need to make a new driveshaft to fit up to it.
jerrybev
Posted 2023-07-26 2:52 PM (#630978 - in reply to #630929)
500100100
hi
elevated vehicle and verified my rear end # 1141544N1. Can you verify that this is a 8 3/4 or 8 1/4 based on the #? Mine is an 11 bolts in housing, either 339 or 389 is on side.
thank you
Jerry
Posted 2023-07-26 4:24 PM (#630980 - in reply to #630917)
50005000500
I have no idea what that number means, but a '57-up 8 3/4 has 10 bolts to mount the 3rd member, so if yours is 11 bolts, it isn't an 8 3/4.
Edited by Powerflite 2023-07-26 4:26 PM
jerrybev
Posted 2023-07-28 10:38 AM (#631014 - in reply to #630966)
500100100
hi
thank you for your time. Others are telling me my rear end is 8 1/4 since it has 11 bolts in housing. Therefore, what would I need.
thank you
jerry
Posted 2023-07-28 11:23 AM (#631017 - in reply to #630917)
At the minimum you would need a ring and pinion with a ratio in the 2.9:1 or 3..2:1. I think a 2.7:1 might be a little too light for your car.
You also would need the gaskets and seals.
Good luck.
Posted 2023-07-28 6:06 PM (#631021 - in reply to #631017)
200010005001001001002525
Look at Dave's snip from the parts book, looks like 3.54 was the lowest numeric ratio available.
Posted 2023-07-28 8:11 PM (#631022 - in reply to #631021)
500050001000100
57chizler - 2023-07-28 3:06 PM
At least for a 55-56 Dodge/Plymouth.
(55-58RearDiffGears_2.jpg)
Attachments 55-58RearDiffGears_2.jpg (149KB - 431 downloads)
Posted 2023-07-29 12:42 PM (#631032 - in reply to #631022)
The early 8 1/4" was used from '37-'61 and in all those years the available ratios ranged from 3.54 to 4.78.
The '62-'65 version offered 2.93 and 3.31 ratios but they won't interchange with the earlier version.
Then, to confuse matters even more, they introduced a third version of the 8 1/4" in '69.
Posted 2025-08-08 8:09 PM (#641140 - in reply to #630917)
50005000500
Interesting. I never knew there was yet another 8 1/4 used in '62-'65. My '61 Lancer has a 7 1/4 under it.
Posted 2025-08-09 11:31 AM (#641146 - in reply to #641140)
Powerflite - 2025-08-08 5:09 PM
The pre-'62 8 1/4" drop-outs attached with 11 nuts, the '62-'65 attached with 10 nuts so they could use the same main housing as the 8 3/4".
