| Good Morning,
I am in the process of replacing the broken turn signal cancelling ring on the steering wheel of my '61 Imperial. The horn contact ring rubber insulator fell apart as I was removing the assembly. Can anyone tell me whether the contact ring is the same for Imperial as it is for other Mopars? I have these part numbers but one vendor has told me this is not correct for Imperial: 2258588 [supercedes 1972208] The rings look the same, but I am unsure of dimensions. Any help is appreciated! Rex | |
