Help 57 New yorker 2 door need quarters and a rocker
   Forward Look Local Regions -> Desert Southwest RegionMessage format
Doright
Posted 2008-02-04 1:43 AM (#113387)
Subject: Help 57 New yorker 2 door need quarters and a rocker
10010025
Please help looking for both lower quarters, Both Forward lower 8 inches,
Lh about 6 inches forward
RH all the way to the door jamb
And the full RH rocker panel this would be ideal measurments for the ideal fix.
Call if you have or know of a source please
I do not want to use the metal listed on EBAY looks to be home made
Dennis
775 727 1964
circlerounder
Posted 2008-02-14 9:29 AM (#114920 - in reply to #113387)
Subject: RE: Help 57 New yorker 2 door need quarters and a rocker
100252525
I foolishly bought their (classicparts4u) floorpans, which was a waste of money. You are smart to stay away. There is another thread where a guy tried their rear QP's on his 300, but ended up needing metal from a parts car anyway. At this time I think that is your best bet, search the salvage yards. There is another guy that makes floor pans that looked really good. I can't seem to find his info at the moment. Maybe he could be convinced to make some QP skins.
circlerounder
Posted 2008-02-14 9:41 AM (#114922 - in reply to #113387)
100252525
I forgot to mention that their is another guy (SCOPAN) that sells excellent rockers. He can also be found in Hemmings under the Rocker King. Good luck. Mark
Chopper John
Posted 2008-02-22 10:45 AM (#116247 - in reply to #114920)
1000100100100100252525
Yup, that was me who ended up using metal from a parts car for my 300. Someone had already butchered my Texas '57 Saratoga 4-door hardtop parts car by cutting the top off, but I still didn't like cutting into the quarters - especially after forking out $350 for the pair of new quarters from "Classicparts4u".
My recommendation is to stay away from them and keep looking for an unwanted parts car - they do show up from time to time - mine was a no-sale eBay listing at $500 (plus another $1000 to get it home to south Florida - including one-way airfare, a Ryder truck, used tires, a trip to Harbor Freight--tow bar, trailer lights, etc-- tolls and gasoline).
agirlandher58
Posted 2008-03-01 9:42 PM (#117782 - in reply to #116247)
Subject: Re: Help 57 New yorker 2 door need quarters and a rocker
1001001002525
The rockers i got for my car i obtain from (scopan) ...they were pretty good they had the rt. curved face to them that spme don't have....my set got banged up in the mail a little bit but i just worked them out -welded them in....the front fender lower rear sec i bought the driver's side and had to graph metal into it to make it fit rt....so i just fab my own for the other side...but i got that pan . from someone else off of e bay ...the headlight brows were not in too bad of shape so i just fitted in new metal there ...working with flat metal usually takes me about 4 to 6 hours to cut shape and start the fit of it to the car....but sometimes your better off doing it this way plus it save you a lot of bucks too!!
circlerounder
Posted 2008-04-18 7:16 PM (#126213 - in reply to #117782)
100252525
agirlandher58 - 2008-03-01 7:42 PM
Mine got banged up too. Cheap b-flute wrap was all that he (scopan) used as packaging material. My packaging was shredded when it arrived and the rockers had a few dings and bent corners. We should let mr. scopan know....
Chopper John
Posted 2008-04-29 3:45 PM (#127720 - in reply to #126213)
I'm pretty certain these vendors of "reproduction" sheetmetal have NO clue that their stuff is NORMALLY arriving at its destination with moderate to heavy damage. It's bad enough there are inaccuracies in the shaping of the panels, but then UPS, Fedex or the USPS adds their additional bends.
As far as the rockers go, I haven't seen any reproductions with the proper drain holes. Anyone?
agirlandher58
Posted 2008-04-30 10:19 PM (#127980 - in reply to #113387)
1001001002525
I do know where a total rear clip is for a 57-58 new yorker .But if came from a four door car..it's pretty solid but i don't know if that will work for repairing a 2 door car...it was cut rt. at the rocker-dog leg sec. it has the whole trunk floor still in it too which is solid also...very little rot on the very lower rear quarter sec. rt by the bumper mounting...wheel lip\flange areas very good. let me know if this could help you out...
Chopper John
Posted 2008-05-09 2:43 PM (#129254 - in reply to #127980)
Teffany - I sent you an IM.
agirlandher58
Posted 2008-06-01 2:10 AM (#132313 - in reply to #129254)
1001001002525
i e mailed the guy back about a week and a half ago....as soon as i hear something back from him i'll post what he's said....
chrysler300c
Posted 2008-06-02 11:39 PM (#132420 - in reply to #114920)
Expert ,, George Passed away July 28th 2021, He will be Missed
1000100100252525
I had a pair of the lower rear quarters that were made for the Chrysler 300 Club International by Metal Crafters a few years ago for one of my 57 300's and I compared them to the ones by carparts4u and they match virtually perfectly. They are a little thinner metal than the originals and the ones the 300 Club had made but as far as fit goes, they do fit very well. I would buy and use them again from carparts4u.
George
Chopper John
Posted 2008-07-18 5:03 PM (#138168 - in reply to #132420)
George - that's interesting about your comparision to the Metalcrafters quarters. I know from Dave Schwandt's photos of installing the Metalcrafters quarters on his 300-C, that they needed some massaging to fit properly -
http://www.chrysler300club.com/tech/schwandt/schwandt.html
The body guy who is doing my 300-D told me that the wheelwell lip on the "classicparts4u" was not shaped as the original ones, and that it would have taken a fair amount of work to make them correct. That's why I acquired the parts car and used its quarters.
John
Edited by Chopper John 2008-07-18 5:04 PM
Doright
Posted 2008-11-10 11:28 AM (#151346 - in reply to #138168)
10010025
Wow this thread went on for a while after I disapeared sorry guy's
Been working and life and all, My Paint booth is now up and running took forever to build it.
I will be back in the hunt for sheetmetal for the 57 after the first of the year probably at end of feb when I get a tax return,
Been looking at that ebay stuff again
Doright
Posted 2009-06-23 1:32 PM (#179005 - in reply to #113387)
10010025
Sorry again guys after my last arm surgery it went bad again my body just doesnt take too these things I guess still don't have any parts last deal kinda fell apart my own fault but I had problems with my arm again and Doc had to do some more carving on it, no fun left me in sad state.
Ok well things are getting better day by day not my arm but life in general. One day at a time as far as my Arm goes some day I will get back too the Chrysler but its sits for now.
