1958 DeSoto Electrojector - First Electronic Fuel Injection?Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
| Forward Look NON-Technical Discussions -> 1955-1961 Forward Look MoPar General Discussion | Message format |
| Rebels-59 |
Board Moderator & Exner Expert 10K+ ![]() ![]() ![]() ![]() ![]() ![]() Location: .Norfolk..Mafia.. ,England UK | This is Long,, BUT Very Interesting Reading.. Does anyone have PIC,s of this Car.. 1958 DeSoto Electrojector - First Electronic Fuel Injection?by George Mattar. Courtesy of the Hemmings Classic Car. Copyright © 2005 American City Business Journals Inc. Photos coming soon. Reprinted by permission ofHemmings Classic Car, a publication of Hemmings Motor News. In the early 1950s, there was a bustling economy as young families that began shortly after World War II were growing up. The auto industry was moving forward too, with innovative design and engines that were more powerful each year. In 1955, Chevrolet introduced the small-block V-8, which in its basic form remains in use today on some GM models. In 1957, Pontiac, under the direction of Semon E. Knudsen, shed the company's "Old Man's Car" image and began a facelift of its cars. One way he accomplished this was ordering the end of Silver Streaks, a Pontiac design since 1935, on the cars' hoods, which cleaned up the design. That same year, Pontiac introduced the beautiful 1957 Bonneville, which was available with a 310 horsepower fuel-injected V-8. New domestic car sales were up about 90,000 from 1956 to 1957. But as soon as car sales were picking up, a recession began in 1958. Despite 5.5 million Americans being out of work in 1958, during the worst recession since the war, automotive design continued to change and more car models were introduced. Even De Soto was making some moderate changes, especially with its restyled Adventurer which was designed to polish the company's image. While the 1958 De Sotos were a far cry from GM's and Ford's boxy car look, at the same time there were few signals that De Soto would not exist in three short years. Although De Soto's 1958 styling was not all that different from the vear before, except for a gold anodized grille, the Adventurer had a handsome front end with quad headlamps and massive chrome bumper with bullets. In the rear, it was adorned with Titanic-length quarter panels that swept to a point with fins. At the tips were "Christmas tree" tail fins with three individual taillamps surrounded by, what else, chrome. The cars could be ordered with a plethora of options including air conditioning and a dash-mounted record player that turned at 16 2/3 rpms. It was dampened so the arm wouldn't skip. However, there was one option very few buyers checked off, likely due to its lofty $637.20 price, and that was fuel injection. In 1958 only, De Soto offered an electronic Bendix fuel-injection system that sat atop a 361-cubic inch, 345 hp V-8 guzzling premium fuel. Considering the recession, the nearly $640 price tag was a lot of money, for something that later proved a failure. Chrysler records show only 35 cars, including Chryslers, De Sotos, Dodges and Plvmouths, were built with the complex multi-port system which had two dual-point distributors (one for the ignition, one for the injectors), an electric fuel pump in the gas tank and two "black boxes," a resistance box and modulator mounted to the radiator support that were the brains of the system. The system was built by Bendix Aviation in Elmira, New York, and first used on aircraft during the Korean War. Because aircraft require fuel systems that only need to work at either idle or wide-open throttle, the Bendix engineers had to devise a way to make the system adapt to a car. In theory it worked, but the system proved very troublesome, due mainly to the crude waxpaper-covered capacitors inside the black box, which failed often. Perhaps this is why GM's simpler, Rochester-built mechanical-type fuel-injection system proved far more usable. The Bendix electronic fuel-injection system had many components modern fuel-injection systems employ including a fuel-pressure regulator, fuel rails, individual injectors, throttle positioning valve, an electronic cold start and warmup sensor, primary and secondary throttle bodies, manifold vacuum sensor, idle sensor, air temperature sensor, acceleration sensor and two fuel lines. The difference between a carburetor and fuel injection is how fuel is supplied to an engine. With a conventional system, a fuel pump mounted on the engine gets fuel from the tank and forces it into the carburetor. There, the fuel is mixed with air, and that mixture passes through the intake manifold to the engine's combustion chambers. A fuel-injected engine, however, supplies fuel to the engine by an electric powered pump in the gas tank. Injectors on the intake manifold and electronic controls then determine the exact amount of fuel injected into the cylinder's intake ports. Among the advantages to fuel injection over carburetors were faster warm ups and performance gains while the engine is cold because the proper fuel-air mixture ratios and distribution can be more easily maintained. Here's how the Bendix system was supposed to work: Electronically controlled and electrically actuated, the "Electrojector" had a transistor-equipped brain or modulator, about 5 inches in size. The brain took a timed electrical signal from the ignition distributor. It sensed, through tiny electronic transmitting devices located at key points on the engine, the engine's temperature, throttle position, manifold pressure and even the altitude (or density) of the air being sucked into the cylinders. The modulator integrated all of the information received and instantly translated this data into a control signal that actuated the injectors," according to an article in Bendixline, a company newsletter, dated Sept. 28, 1956. In a 1956 Bendix newsletter, company President Malcolm P. Ferguson announced that fuel injection "will replace the carburetor and improve performance." Nearly 50 years ago, he was truly a visionary, but a trouble-free system would be years away. Ferguson also said in that issue, "Compared to the latest four-barrel carburetor designed for high performance engines, the 'Electrojector' system provides between 10 and 20 more horsepower — achieved at lower engine rpm-throughout the whole range of speeds, boosts fuel economy, achieves quicker starts and warmups, eliminates the 'smog' problem created by unburned fuel exhausted from the engine and is a system with a minimum of moving parts." One man who knows the ins and outs of the Bendix system is Tom White of Hopkinton, Massachusetts, who owns a 1958 Adventurer, one of only 82 convertibles built that year. There also were 350 hardtops. Today, only five 1958 Adventurer convertibles are known to exist worldwide. White owns two, there are two in Sweden and the fifth is in Wisconsin, he said. But White's car is automotive Nirvana for De Soto aficionados. Yes, folks, Chrysler Historical Records show White's perfectly restored gold Adventurer is the only car built with and retaining fuel injection remaining on the planet. The president of the National De Soto Club, Dean Mullinax, said White's car is probably the only fuel injected example in existence. According to a Bendix manual, two Plymouth Furys, 16 Chrysler 300s, 12 Dodge 500s and the five De Sotos, were built with the two-carburetor option and taken to a De Soto plant on Warren Avenue in Detroit to have the Electrojector system installed along with a 40-amp generator, electric fuel pump and a pair of "Fuel Injection" emblems. Unlike today's cars, in which mechanics have to remove the gas tank to gain access to the fuel pump, Chrysler installed a black metal cover over a cutout in the trunk floor of the 1958 models to make access to the coffee maker-size fuel pump easier. The history of this perfectly restored car, showing 66,671 actual miles, is as interesting as the car itself. Built December 6, 1957, it was a styling exercise and the first convertible built, said White, who has the Chrysler build sheets. Sold new at Liberty Dormont in Pittsburgh to William Dickson, the car was issued a Pennsylvania title January 21, 1958. White has that same title tucked away in a New York City phone book-thick pile of documentation. Dickson traded it for a recreational vehicle at Huffy's RV Sales in Harrisburg in 1975. The RV dealer, still in business, never took the car out of Dickson's name and put it in a barn, where rodents got the better of it. White heard about the car, and in June 1998, worked out a deal and trailered it home. He stumbled onto what he believed was a fuel-injected De Soto, because attached with speed nuts on the front fenders, albeit they were broken and some pieces missing, were gold and silver "fuel-injection" emblems. Was this the car that had eluded collectors for years? Would he ever find the fuel-injection unit he needed to properly restore the car? Lady Luck was about to pay him a visit. While at Hershey's big AACA October 2002 swap meet, White was showing a photo of the car to a friend and a felt a tap on his shoulder. It was Paul Gabauer, who overheard the conversation and said he could lead White to the original system installed on White's car. It was in nearby Harrisburg. Gabauer told White he could put him in touch with the son of the man who had stored it since it was taken off a car in 1958. White could not believe what he was hearing and contacted the man with a grungy, wrinkly brown box full of parts. That man was the son of J. Gerald Cassel, who died at 67 in 1990. Cassel was a Chrysler field representative in 1958, who removed a complete fuel-injection system, possibly the one from White's car, 44 years earlier. He put the system in his attic and told his wife to never get rid of it. His son realized how valuable that box of stuff was and White braced himself to pay the piper. He went to Harrisbur~ "ready to buy." He would not divulge what he paid, but after several negotiations, it took a "five-figure sum" to acquire the Electrojector unit, even though the primary distributor which fires the ignition was missing. This striking De Soto retains its original radiator, and White boasts, "It's even the original core." The trunk mat is NOS, the only known example, as is the gold speckled carpet, found in Texas. All the original parts are still with the car, like the top well, which somehow survived the rodents in Harrisburg. The dash was repainted and re-padded. Everything on the car, including both clocks-the dashboard clock and the Benrus watch inside the steering wheel's center-work. Looking at this beautiful De Soto takes you back to when Ike was President and gas was less than ?8 cents per gallon. No detail on this car was overlooked. The tit and finish of every component is Pebble Beach quality. Even the door and trunk jambs glisten on this car that cost Dickson more than $6,000 in 1958. Base price of a 1958 Adventurer convertible was $4,369, the most expensive De Soto in history. The body and paint was tackled by White's son, Tom. The car was rust-free and no panels needed replacement, so Tom bolted the car to a rotisserie and began media blasting the undercarriage. White said little scraping was needed because the car was built without undercoat. They did find "lava-like" undercoating inside the car on the floors and trunk, but left it alone because that's how it was made. The front suspension and frame also were media blasted, repainted with urethane enamel and clear coated. All removable panels, such as hood, trunk, doors and fenders were taken off, stripped to bare metal, smoothed out, then covered with six to eight coats of Ditzler PPG primer applied with a DeVilbis paint gun. Tom then used PPG Adventurer Gold and sprayed four color base coats, wet sanding between each coat, on the car. Both inside and out of the hood, trunk lid and doors were painted off the car. After that, he sprayed three coats of urethane clear, again sanding between each coat with 1,000-grade paper and finishing with 1,500-paper. After sanding, Tom power buffed the body with 3M products. The door jambs were hand buffed. "When Tom paints a car, he paints the bottom first, then the top. There are no paint lines anywhere. He spent many hours on the paint alone. We estimate more than 2,000 hours were spent restoring this car," the elder White says. The car's original engine was taken apart, but did not need a complete rebuild. The elder White did a valve job, installed new bearings and that was about it. Even the original camshaft was retained. His son then painted the engine and all accessories in a base coat/clear coat finish. The gold paint needed to paint the dual air cleaners took their local paint supplier about a week to match correctly. Even the air cleaner lids were wet sanded and hand polished. The cardboard box of fuel-injection parts was left to the elder White. "These systems were quite complex, as I learned while taking it apart. To a mechanic in 1958, this was nearly impossible to fix. It took me six weeks to figure it out. I determined the failure was in the electronic modulator. It was interesting, like an old 1940s radio," White said. "Once the system was operating, it was upgraded with new polyester capacitors and modern transistors, as the originals were wax-paper dipped and not reliable even when new." Being an electrical engineer made the task at hand easier for White to figure out. He reverse engineered the unit, found the faults and got the electrical portion to work. Before he could determine whether the system would pump fuel, he had to machine some parts on his lathe. Using factory photos, to replace the missing primary distributor, White shortened a stock distributor from a Chrysler 413 engine and re-worked the keyway. "The keyway shaft into the distributor is round with a tab sticking out. I had to enlarge it and re-machine it. It was a lot of hand work as the key way is threaded both internally and externally," White said. He also had to fabricate a coupler from scratch and attach it to the secondary or "trigger" distributor, which controls fuel flow. Not wanting to mess up his concours-prepared engine compartment, he then bench tested the unit with air pressure and a power drill, hooked up to turn a distributor and create a driving environment without fuel. With everything working as it should, the system was completely detailed then placed atop the original engine. White received invaluable help from a Bosch employee, Jim Bartuska, who has been trying to track down an elusive Bendix system for 36 years. Once mounted to the engine, the car ran terribly. Starving for fuel, it would not accelerate properly. White went over the entire system again and determined the trouble was in the altitude sensor. With the engine completed, White had a friend overhaul the transmission. Turning to the interior, he was able to find NOS seat cover material. After someone else made the gold and white vinyl and gold cloth brocade seat covers, White installed them and also made door panels from original material. All the gauges, oil, amp, temperature, fuel and 150 mph speedometer, were detailed and re-installed. All replacement parts are NOS, such as the correct date-coded 1958 spark plug wires and windshield washer bag. This car is restored with all NOS parts, because there are no reproduction parts available, White said. The hardest parts to find, other than the fuel-injection unit, were four correct spinner wheel covers, which were missing, and an original steering wheel. To find one, White bought a complete 1958 Adventurer hardtop, which he still owns. White's Adventurer convertible was built with the 361-cu.in. V-8, power steering, power brakes, power windows, power seat, triad horns, bumper guards, remote driver mirror and matching passenger mirror, dual antennas, clock, steering wheel watch, and Prismatic rear view mirror, Sure Grip differential and Highway Hi-Fi Record Player, which White played during our drive in this quite powerful car. By the way, the record player is NOS. The NOS fuel injection emblems, the only ones known to exist, were "liberated" from a Chrysler building by an employee and found by White. He also has all factory manuals, fuel-injection schematics and service bulletins, about 200 pages in all, related to the car. "Funny thing is, I didn't find this car, it found me. The crazy part is, I restored this car knowing it would probably never, ever be restored to fuel injection. There just are no parts out there," White said. Our ride through the eastern Massachusetts countryside showed the 4,185-pound car pulls strongly, with no hesitation. As White mashed the accelerator pedal to the floor while going up a hill, the car was somewhat loud, with most of the roar coming from the dual gold colored air cleaners. The TorqueFlite automatic transmission shifts with some authority, and the car stops fairly quickly despite having a four-wheel, unvented, 12-inch drum brake system and 8.50 by 14-inch bias-belted tires: This De Soto, as with most cars of 1958, has a soft ride and doesn't take corners with any authority. The front bench seat is comfortable to a point, but you would find yourself moving about after a few miles. Since its completion in March 2003, judges have taken note. The nine awards so far include Best in Class at the Meadow Brook Concours d'Elegance and Most Distinguished Chrysler presented by Daimler Chrysler at the Greenwich Concours. And at the AACA's Grand National meet in Buffalo, New York, this past July, it earned the highly coveted Senior Award. No doubt an accurately awarded honor for an accurately restored automobile. | ||
| 1960ny |
Extreme Veteran Posts: 467 ![]() ![]() ![]() ![]() ![]() ![]() Location: Sweden | Here is a 1958 Desoto Adventurer site with the fuel injection car! http://www.58-adventurer.com/ Jorgen | ||
| 60 Finatic |
Extreme Veteran Posts: 483 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: near St Augustine, FL | Coincidentally, I was at the Amelia Island Concour d'Elegance today and spoke to Tom White and took several pics of his '58 Adventurer. I will post pics later this week, including some I took a few years ago of the F.I. setup. | ||
| Doctor DeSoto |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: Parts Unknown | I first crossed paths with Tom white back when he first got this car. Much of what was written in that article was still just hopeful speculation for Tom at that time. It is great to read this and see that many of the puzzle pieces fell into place. I would sure like the chance to take this car out for a spin and see how the FI unit changes performance. It is a stunning car. | ||
| Phil_the_frenchie |
Elite Veteran Posts: 932 ![]() ![]() ![]() ![]() ![]() ![]() Location: Pau, S-W France | There was a very interesting article about the beginning of the Electrojector in one issue of the Chrysler 300 Int. magazine. I can scan it but i don't know if i can post it here. | ||
| Doctor DeSoto |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: Parts Unknown | Is there a way to positively ID a Fuel Injected car ? | ||
| DeSotohead |
Board Moderator Posts: 3186 ![]() ![]() ![]() ![]() ![]() ![]() Location: The not-so-great, dirty-white North ( Michigan) | I think the WPC has a list of the Vehicle Body Tag numbers..... | ||
| big m |
Expert 5K+ Posts: 7831 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: Williams California | DeSotohead - 2008-03-10 8:14 AM I think the WPC has a list of the Vehicle Body Tag numbers..... You're correct, Hank. When I bought a 300 D several years ago, it came with a whole file folder of info, some of it being documented as an FI car by the historical society. A couple giveaways to an FI car is a hole in the center of the trunk floor to gain access to the electric fuel pump, and a crook in the oil filler tube [to clear the Electrojector unit]. ---John | ||
| 57burb |
Expert Posts: 3976 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: DFW, TX | Several of the 300s have turned up with their fuel-injection specific 300 badges on the quarter panel. Here are some great pictures of Tom White's Adventurer. This may be the finest FL car of all time. http://www.chrysler300club.com/jhstuff/fuelie/fuelie.html | ||
| 57burb |
Expert Posts: 3976 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: DFW, TX | Also - "collector" here on the board has a '58 300D ex-EFI car for sale. Thread: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=15368 More info: http://www.harkania.com/cars_for_sale.html | ||
| 57belvedere |
Extreme Veteran Posts: 406 ![]() ![]() ![]() ![]() Location: Voss,Norway | WOW!!!!!! That Adventurer of Tom White is absolutly stunning Make me almost loose my breath. Should have loved to see that in person. Is anyone have a video of it?? Edited by 57belvedere 2008-03-10 2:07 PM | ||
| d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: bishop, ca | I know of the reported possession/existence of another complete (CHRY) fuelie-system, but it's not installed and operational, yet. Most of the parts may be interchangeable, but the DOD/PLY installations involved the 361 c.i. B block wedge-head engines, compared to the 392/354 Hemi CHRY/DeS applications. Can you Imagine some Corporate hot-shot with a Fuelie IMP convertible???? | ||
| Lancer Mike |
![]() ![]() ![]() ![]() ![]() Location: The Centennial State | 57burb - 2008-03-10 11:53 AM Here are some great pictures of Tom White's Adventurer. This may be the finest FL car of all time. http://www.chrysler300club.com/jhstuff/fuelie/fuelie.html Gets my vote! | ||
| 57burb |
Expert Posts: 3976 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: DFW, TX | Neil, I believe all the Dodge and DeSoto '58 EFI cars ran 361s, the Plymouths used the 350, the only Hemi was the 300D with its 392. I'm trying to find info to back that up but can't find anything, just remembering off the top of my head. | ||
| 60 Finatic |
Extreme Veteran Posts: 483 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: near St Augustine, FL | Here are the photos as promised. Photos were taken at 2004 Carlisle, 2006 National DeSoto Convention and yesterday at the 2008 Amelia Island Concours d'Elegance. Brett, while chatting with Tom, someone asked how it ran; he grinned, and said, "Real good..." You had to be there to appreciate the smile on his face when he said it. Edited by 60 Finatic 2008-03-10 11:12 PM (at-Carlisle.jpg) (fender-insignia.jpg) (front-3-4.jpg) (rear-3-4.jpg) (interior.jpg) (highway-hi-fi.jpg) (FI-setup.jpg) (FI-setup-frontview.jpg) (FI-setup-sideview.jpg) Attachments ---------------- at-Carlisle.jpg (61KB - 1069 downloads) fender-insignia.jpg (26KB - 793 downloads) front-3-4.jpg (81KB - 804 downloads) rear-3-4.jpg (70KB - 842 downloads) interior.jpg (54KB - 881 downloads) highway-hi-fi.jpg (66KB - 1327 downloads) FI-setup.jpg (85KB - 965 downloads) FI-setup-frontview.jpg (72KB - 885 downloads) FI-setup-sideview.jpg (57KB - 828 downloads) | ||
| chrycoman2 |
Member Posts: 14 | d500neil - 2008-03-11 12:51 AM I know of the reported possession/existence of another complete (CHRY) fuelie-system, but it's not installed and operational, yet. Most of the parts may be interchangeable, but the DOD/PLY installations involved the 361 c.i. B block wedge-head engines, compared to the 392/354 Hemi CHRY/DeS applications. Can you Imagine some Corporate hot-shot with a Fuelie IMP convertible???? DeSoto never used the Chrysler hemi block, except for the Canadian-built 1958 Firedome that used the poly 354. In the U.S. the 1958 DeSoto used the 350 engine in the Firesweep and the 361 in the rest. No DeSoto hemis after 1957. The Plymouth used the B block 350 while Dodge and DeSoto shared the B block 361. Only the Chrysler used the 392 F.I. hemi. Thus Plymouth, Dodge and DeSoto EFI parts will interchange while the Chrysler parts are unique to Chrysler. The 354 was a poly engine in 1958 for the Windsor and Saratoga. No EFI engines were built by Chrysler of Canada. Bill Vancouver, BC | ||
| moparsteve |
Elite Veteran Posts: 1155 ![]() ![]() ![]() ![]() Location: somerville mass | i first saw this on the 300 site. but never saw detailed pics and info until today. 1 of 1. most expensive desoto sold. f.i. units/components are priceless and do not exist. mechanics hated working on the units in 1958. and few that were built were converted to the dual quad setup. i live in mass. and grew up west of boston. hopkinton is where the boston marathon starts. the car is breathtaking and priceless, and i only hope one day to see it. | ||
| 60 Finatic |
Extreme Veteran Posts: 483 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: near St Augustine, FL | While speaking to Tom, he told me the car will be at the AACA Grand National Meet in Melbourne, FL this weekend on March 15th. I plan on driving down if anyone else plans on attending. The Show itself is in the field next to the Melbourne airport. I'll be the ugly one (unless Steve & JW come all the way from Iowa...) | ||
| d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: bishop, ca | Yeah, yeah; I brain-farted on the 58 Soto Hemi Fuelie... But, didja hear about that Fuelie IMP convertible, that was that 'that' show, somewhere, that a friend of mine saw, one time, not long ago???? | ||
| d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: bishop, ca | The story goes, that ALL the '58 Fuelie cars shared that-same F.I. emblem, and that Dodge's was installed at the rear end of its shortened-for-58 quarter panel molding. And, it's interesting that the B-block Fuelies apparently did not have all that pretty, perforated-chromed heat-shielding that you see appearing in the photo-images of the 392 F.I. engine(s). Edited by d500neil 2008-03-11 7:08 PM | ||
| d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: bishop, ca | AND, I finally heard/learned not too long ago, that the purpose/function of those plain-green paint-markings, on the horns, was to differentiate the 12 volt units, from the 6-volters. True? Didn't DeSotos have the standard "square-head" battery head-connections? Edited by d500neil 2008-03-11 7:17 PM | ||
| Resurrector |
![]() ![]() ![]() ![]() | Thanks for posting that story and the pics...I have to go change my shorts now. | ||
| MOPAR-TO-YA |
Expert 5K+ Posts: 5141 ![]() ![]() ![]() Location: cornpatch county, Southwest IOA | 60 Finatic - 2008-03-11 3:19 PM If JW and I were to be there , maybe it would add a little CLASS to the event! ! While speaking to Tom, he told me the car will be at the AACA Grand National Meet in Melbourne, FL this weekend on March 15th. I plan on driving down if anyone else plans on attending. The Show itself is in the field next to the Melbourne airport. I'll be the ugly one (unless Steve & JW come all the way from Iowa...) | ||
| tuske427 |
Veteran Posts: 273 ![]() ![]() ![]() ![]() Location: Los Angeles, Ca | I don't suppose any has, or can get- pics of the trunk and access panel/ hole? I'm curious to see how the factory did it as I too had to cut a hole in my trunk and make an access panel for my fuel injection. | ||
| dukeboy |
Expert 5K+ Posts: 6203 ![]() ![]() ![]() ![]() Location: Big pimpin' | Ain't this the dude that dropped a $100K to get that system rewired to run "Real good"...? | ||
| 57burb |
Expert Posts: 3976 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: DFW, TX | Dukeboy, Tom White is an electrical engineer by profession and managed to get it working himself by replacing a lot of the wax and paper covered capacitors with modern replacments. It is really running with the EFI system. But I have no idea how much he has in it.. | ||
| firedome |
Expert Posts: 3161 ![]() ![]() ![]() ![]() ![]() Location: NY & VT | We restore vintage HiFi components along with writing for a magazine that deals with that kind of stuff, and automatiically replace all the power supply filter capacitors and output transformer coupling caps with Illinois polypropylene caps. It's just a given that in any old electronics, radios, etc that the original caps are either bad or soon will be, so it's no surprise they were bad in the Electrojector unit. Better to just replace them than risk losing an expensive and hard to find transformer | ||
| horace |
Extreme Veteran Posts: 471 ![]() ![]() ![]() ![]() ![]() ![]() Location: MN | 35 FI were rated @ 315 hp 361FI a catchy 333 hp | ||
| mstrug |
Expert 5K+ Posts: 6690 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: Newark, Texas (Fort Worth) | more pics for future reference: (1958desotoelectrojectorfi1.jpg) (1958desotoelectrojectorfi2.jpg) (1958desotoelectrojectorfi2.jpg) (1958desotoelectrojector4.jpg) Attachments ---------------- 1958desotoelectrojectorfi1.jpg (97KB - 1012 downloads) 1958desotoelectrojectorfi2.jpg (71KB - 1616 downloads) 1958desotoelectrojectorfi2.jpg (71KB - 979 downloads) 1958desotoelectrojector4.jpg (100KB - 1230 downloads) | ||
| ttotired |
Expert 5K+ Posts: 8456 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: Perth Australia | Thanks for all that It was really interesting reading Mick | ||
| mstrug |
Expert 5K+ Posts: 6690 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: Newark, Texas (Fort Worth) | Link to other Electroinjector forum: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=42214&... | ||
