Getting an old engine UNSTUCK Jump to page : 1 2 Now viewing page 2 [50 messages per page] | View previous thread :: View next thread |
59CRL |
Expert Posts: 2679 | 1956DeS - 2010-01-16 2:27 PM To remove rust stains in a sink, put ketchup on them. What's in ketchup? Vinegar. Will vinegar harm steel? Probably eventually. I use Liquid Wrench at work a lot and have found it to be a good (effective) product, superior to PB Blaster. Liquid chlorine bleach will eat up aluminum (pistons, for instance). Downside is it releases poisonous chlorine gas in the process. Not sure if it harms steel (cylinder walls), but it could be determined easily via testing. A 50% sodium hydroxide solution, while pretty dangerous stuff, will dissolve aluminum while releasing hydrogen gas (explosive). I know it won't harm steel because it is used in boilers. Ammonia will affect aluminum. I have soaked parts in diesel fuel (flammable) to loosen rust. Works very slowly. It's basically a thin oil product. Brake fluid will corrode aluminum but won't harm steel (brake lines). Hydrochloric acid. Attacks aluminum but also maybe steel. Not sure. Lemon juice is about 5% citric acid. Uses unknown to me. Here's a good link... http://www.crankshaftcoalition.com/wiki/Freeing_a_stuck_engine#Brea... Seen somewhere: "If a engine will turn or move just a little i use a 50/50 mixture of diesel and ATF. For one that is stuck solid i use brake fluid. You could also put the block in a electrolysis tank." Good info, the Vinegar is the best kept secret, one of the strongest cleaners you can buy. If you want to remove hard mineral deposits in water ect.... use white vinegar, I mix it in my glass plus and clean the whole car with it, glass, chrome ect..... works great! Lemon juice is another great one..... | ||
Polara |
Regular Posts: 59 Location: Northern Wisconsin | When I was younger my dad had a 1950 Buick with a stuck strait 8 in it. I remember him putting Coca-Cola down the cylinders, and after a couple of days he took a block of wood and hammer then beat on top of the pistons. And it worked!! Just another thought to ad to the rest.. John | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | Greg, what is your mixture ratio of vinegar-to-"Glass Plus"--assuming an almost full quart bottle of the stuff? | ||
59CRL |
Expert Posts: 2679 | d500neil - 2010-01-19 6:05 PM Greg, what is your mixture ratio of vinegar-to-"Glass Plus"--assuming an almost full quart bottle of the stuff? I use 1/3rd vinegar to a full bottle of glass plus, I clean the whole car, glass paint and rims, works great! | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | So, the mixture is 3:1; when cleaning glass; does 'that' solution leave any streaking, or, is a dry wipe-off still needed? Edited by d500neil 2010-01-19 7:34 PM | ||
phins |
Elite Veteran Posts: 1172 Location: bradenton florida | so the pistons will come out easier with the windows clean with vinegar ??? | ||
59CRL |
Expert Posts: 2679 | phins - 2010-01-19 9:35 PM so the pistons will come out easier with the windows clean with vinegar ??? Your engine might be stuck but your car will be squeaky clean! | ||
imopar380 |
Expert 5K+ Posts: 7206 Location: Victoria, BC, on Vancouver Island, Canada | Looks like we got a spammer in the above post. | ||
1959 Belvedere Conv |
Elite Veteran Posts: 1107 Location: Arvada, Colorado (NW Denver Metro Area) | Yea, she put an entry in the John Samsen posting about Carisle too. | ||
