1958 regal lancer restoration
Jump to page : 1 2 3 4
Now viewing page 2 [50 messages per page]
LD3 Greg
Posted 2013-12-11 4:16 PM (#415690 - in reply to #415689)
Subject: Re: 1958 regal lancer restoration
1000500252525
Wonderful thread, Paul, thanks for directing me here.
Greg
springsweptwing
Posted 2013-12-15 2:28 PM (#416448 - in reply to #275315)
Subject: RE: 1958 regal lancer restoration
100025
Clive, yes back on with it, sorted a few things around so i can concentrate on one thing at once,there was no real interest in the car when it was for sale?
springsweptwing
Posted 2013-12-15 2:31 PM (#416449 - in reply to #275315)
100025
Painted the bare metal parts on front suspension, also painted in the welds as would have been visible on the bare steel, the bump stops are T4 Volkswagen if any one is looking for some, they are a bit bigger diameter but will do for now till i can get some OEM ones.
(front sus.JPG)
(front sus3.JPG)
Attachments front sus.JPG (148KB - 123 downloads)
Attachments front sus3.JPG (151KB - 110 downloads)
Posted 2013-12-15 3:03 PM (#416456 - in reply to #416449)
5000200010001001001001002525
Hi, Paul:
Great to see you are still moving forward on this wonderful car. I had thought maybe it sold at a ridiculously low price - so I'm glad to see you didn't let it go for a song. I hope your health is well and you enjoy the holidays!
LD3 Greg
Posted 2013-12-16 12:36 AM (#416562 - in reply to #416449)
1000500252525
Hi Paul,
I was a concours judge with the 300 club Int'n. for more than 20 years and I have NEVER seen anyone try to replicate the mig weld bluing/discolouration on raw steel like you have. You have taken restorative work to a whole new height. My hat is off to you!! Well done!
Greg
LD3 Greg
Posted 2013-12-16 1:36 AM (#416564 - in reply to #416449)
1000500252525
As restoration junkies we still have another replication to solve. ALL upper and lower control arms as well as all other brackets were stamped from "hot rolled pickeled and oiled" coiled steel. This steel had a very particular, sort of blotched, appearance. I worked in these steel stamping plants in late high school and university. All the bits that Paul has shown to be welded is correct. We still have to duplicate the original appearance of HR P&O steel!!
Greg
d500neil
Posted 2013-12-16 2:43 AM (#416570 - in reply to #416564)
500050005000200020001002525
Things of beauty.
ToMopar
Posted 2013-12-16 6:46 AM (#416581 - in reply to #275315)
500100252525
Paul,
nice work, but I thought, you've sold that car two month ago at ebay
FIN ME
Posted 2013-12-16 9:43 AM (#416600 - in reply to #275315)
2000500100100252525
Neat as a pin, springsweptwing!
firedome
Posted 2013-12-16 12:02 PM (#416635 - in reply to #416600)
200050010010010010025
Nice work and glad you were able to keep it... the market seems off, we're experiencing no real interest in our '58 Windsor/Dodge either so may proceed with a resto, willing and able or not, but it may not be an entirely bad thing in the end, if it can be pulled off... and we have no illusions of doing the kind of superb job seen here!
d500neil
Posted 2013-12-16 2:47 PM (#416675 - in reply to #416635)
Roger, if you are going to be rebuilding the front suspension, it is not a big deal to 'sand-blast' the components.
The best thing to do with those pieces is to have them be powder coated in natural-bare metal (being sure to
protect any mating-surfaces).
Clear coat will wear off and or show surface corrosion, quickly, and natural 'paint' is OK, but needs touching up.
The powder coat will only require a wipe-off with mild solvent to restore their finish.
The driveline is in natural-shiny appearance; after removing the gunk from it, it can be polished and heavily clear-coated.
The differential carrier assembly is in natural bare-metal/cast iron.
After you strip/brush-grind it as well as possible, you can apply natural finish bare-steel paint to it.
None of this is very difficult to do.
sidesho_bob1961
Posted 2013-12-19 4:18 PM (#417355 - in reply to #275315)
1000500100252525
FYI - Do not wipe off powder coatings with Lacquer Thinner!!! It will dissolve the coating........
d500neil
Posted 2013-12-19 5:03 PM (#417368 - in reply to #417355)
Didn't know that; thanks.
How fast does the lacquer thinner attack the PC?
Sandblasting doesn't work very well/easily against PC (coarse material required).
Acetone will really attack some plastics; how does it affect PC?
springsweptwing
Posted 2013-12-19 9:06 PM (#417428 - in reply to #417368)
100025
d500neil - 2013-12-19 10:03 PM
that is what PC is, a plastic coating, plus if you do get any chips on your parts that are subjected to the weather, rust will work its way under,
(IMG_2398.jpg)
Attachments IMG_2398.jpg (131KB - 120 downloads)
Posted 2013-12-19 9:30 PM (#417435 - in reply to #417428)
5000500050005000200010025
Powder coating SUCKS for use on ANY surface that will sustain joint cracks, surface chips, etc. It WILL
peel off like a #@! potato chip and cannot be repaired like paint. It requires the TOTAL (and PITA) sand
blast cleanup and redo of the powder coating (if you are so inclined to repeat the mistake) !!!
Powder coating may be great for non-exposed apps, but honestly, once damaged and exposed to moisture,
can go to hell in a hurry. The big hassle is that desired "hard surface" material is a major fight to UN-coat
off your part/s, and touch up is not a possible option.
Paint is a far better surface coater in most auto apps.
SENIX
Posted 2013-12-19 9:32 PM (#417437 - in reply to #417428)
100100252525
Exactly, think of powder coating as a ziplock bag, it keeps everything out but when you get a pinhole or a chip in it, it also then hold moisture in under the surface. Draw Tite hitches are a good example if you have seen one in this area, Michigan, they rust from under the p.c. Also paint can be touched up P.C. has to be reprocessed. Very Nice Work.
Swanny
springsweptwing
Posted 2014-01-31 9:51 AM (#425069 - in reply to #275315)
100025
Got my plating back just after new year, sorted out most of the Dodge bits, and started on putting the frame back together, with the info that Greg had in his pictures and other pictures i could find, i have done what i think the markings would look like, any other info on marking etc would be welcome,
Paul.
(plating.JPG)
(plating2.JPG)
(plating3.JPG)
Attachments plating.JPG (143KB - 111 downloads)
Attachments plating2.JPG (154KB - 108 downloads)
Attachments plating3.JPG (150KB - 102 downloads)
springsweptwing
Posted 2014-01-31 9:53 AM (#425070 - in reply to #275315)
100025
Frame pictures, backing plates for brakes on loose as waiting fr cylinders, Paul.
(frame paint.JPG)
(frame paint2.JPG)
(f paint3.JPG)
(f paint4.JPG)
(f paint5.JPG)
Attachments frame paint.JPG (147KB - 116 downloads)
Attachments frame paint2.JPG (152KB - 115 downloads)
Attachments f paint3.JPG (151KB - 99 downloads)
Attachments f paint4.JPG (156KB - 109 downloads)
Attachments f paint5.JPG (149KB - 102 downloads)
d500neil
Posted 2014-01-31 4:44 PM (#425143 - in reply to #275315)
Very, very nice!!!
The Swedes should take lessons from you; they tend to paint everything in/on the chassis in gloss black.
The T/bars' paint daubs WILL be visible, from underneath the car, when the car is assembled and the
T/bars are rotated by the full weight of the car?
Edited by d500neil 2014-01-31 4:51 PM
springsweptwing
Posted 2014-03-10 10:08 AM (#430603 - in reply to #275315)
100025
getting there slowly, had a break from bodywork and decided to try out the copper paint i had matched to the original, it looks darker than it is under the lights, but the column is the colour it looks in daylight, the rear speaker surround is the same colour as dash, non of the die-cast pieces were originally primered and the paint just chips away,
thanks Paul.
(DSC_0017.JPG)
(DSC_0018.JPG)
Attachments DSC_0017.JPG (79KB - 104 downloads)
Attachments DSC_0018.JPG (74KB - 105 downloads)
springsweptwing
Posted 2014-03-10 10:12 AM (#430604 - in reply to #275315)
100025
Original parts before painting, colour matched to a hyundai copper, will post the code if anyone struggling with a colour match, thanks Paul.
(DSC_0011.JPG)
Attachments DSC_0011.JPG (75KB - 103 downloads)
springsweptwing
Posted 2014-03-10 10:16 AM (#430605 - in reply to #275315)
100025
Going to have a play around with the dash inserts next, just deciding best way to mask off all those dots? bronze colour is different to dash colour, steering horn ring will have to wait until i can find a better one or have this one plated, Paul.
(DSC_0012.JPG)
(DSC_0015.JPG)
Attachments DSC_0012.JPG (128KB - 102 downloads)
Attachments DSC_0015.JPG (113KB - 110 downloads)
Posted 2014-03-10 1:08 PM (#430624 - in reply to #430605)
Wow! Great work, Paul! Thanks for the updates. If you could just drop a bead of wax or a sticky bb into each of those dimples and then spray without upsetting the whole thing...
Posted 2014-03-10 2:58 PM (#430632 - in reply to #275315)
500050001000100100100100
Way to go Paul, that looks really good and it sure is the fun part of it; assemble all the clean and treated parts.
matt
Posted 2014-03-11 11:17 AM (#430740 - in reply to #275315)
Wonderful thread, love the colour.
FIN ME
Posted 2014-03-11 12:38 PM (#430756 - in reply to #275315)
2000500100100252525
Very impressive! You are one patient and hard working guy!
It's all looking great!
Windsor59
Posted 2014-03-11 1:56 PM (#430766 - in reply to #430756)
Wow! You do a very Great work
I like what i see at pics.
springsweptwing
Posted 2014-03-13 9:54 AM (#431019 - in reply to #275315)
100025
Thanks for the positive replies guys, Mike i had a idea of dropping some mould release agent in each of the holes, but after painting the pattern was not consistent
(unnamed.jpg)
Attachments unnamed.jpg (83KB - 97 downloads)
springsweptwing
Posted 2014-03-13 9:59 AM (#431021 - in reply to #275315)
100025
In the end i just painted then went over every hole with a 1/8 drill bit by hand to clean out the dimples, looks as original and every dimple is the same size, next gauge surround to do, thanks Paul.
(dash trim.jpg)
Attachments dash trim.jpg (64KB - 107 downloads)
VAN HELSING
Posted 2014-03-13 10:26 AM (#431023 - in reply to #431021)
500100100100100252525
Wish I had the time and patience to do a rebuild like this, I admire your dedication to it
sidesho_bob1961
Posted 2014-03-13 12:04 PM (#431033 - in reply to #275315)
1000500100252525
Would the frame have had the part numbers stenciled on it like that? I thought only replacment parts had part number identifications marked on them???? Just asking, not criticizing.......very nice work indeed...
springsweptwing
Posted 2014-03-13 9:02 PM (#431114 - in reply to #275315)
100025
Bob, there was some kind of White markings there under what was left of the underseal, so i thought it may have been a number on the frame? The 183 was there and is also chalked on the cowl near the data plate, every other marking is just from information i have gathered from other pictures, Paul.
(JB_DeS57 044.jpg)
Attachments JB_DeS57 044.jpg (96KB - 110 downloads)
springsweptwing
Posted 2014-03-13 9:04 PM (#431115 - in reply to #275315)
100025
Finished up the guage surround tonight
(guage surround.JPG)
Attachments guage surround.JPG (151KB - 110 downloads)
Posted 2014-03-13 9:35 PM (#431130 - in reply to #431115)
Paul, that looks fantastic. Trying to mess around with those dimples is probably just too much unless there is some very simple solution - the painted dimples look excellent to me. That's an area that many Regal restorers seem to miss.
d500neil
Posted 2014-03-13 10:08 PM (#431138 - in reply to #431130)
Truly MoPar Madness.
I had thought that most-all of the production Regals had/have chrome-shiny facias, and not the regal-copper color(ed)
toned ones.
Thoughts?
LD3 Greg
Posted 2014-03-22 4:13 PM (#432489 - in reply to #431138)
1000500252525
Great work, Paul. I'm glad you kept the car!!
The dash inserts on my Regal were originally bronze.
Greg
christine-lover
Posted 2014-03-22 6:27 PM (#432505 - in reply to #275315)
200050010010010025
Awesome work Paul!
And Greg...great to see you back on here again!
LD3 Greg
Posted 2014-04-08 2:01 AM (#435033 - in reply to #432505)
1000500252525
Paul, just a note for the future. When you get to the interior vinyl etc. get in touch with me. While I don't have any of the copper threaded cloth I do have vinyl left over that SMS had and embossed for me.
Greg
d500neil
Posted 2014-04-08 3:27 PM (#435098 - in reply to #275315)
SMS should already have (a lot of) the Regal Lancer upholstery cloth loomed up, ready to sell.
There's another Regal Mystery (in addition to the others, shown/discussed on earlier thread pages): how and why were
there different colors of the dash-insert panels, and how many were built in either color?
At least, we know the production total of the RL models.
My SWAG is that (only-) the earlier models got the bronze inserts...but, never-say-always.
d500neil
Posted 2014-04-08 3:44 PM (#435104 - in reply to #275315)
Just as a measure of Paul's O.C.D. (attention to detail!), he could have had his car's dash inserts
look like these, on A. Lejins' Regal; standard 58 Dodge pieces.
BTW, this car was built o.o.a. 3/6/58, so, it was not one of the 'early' built exemplars.
(PICT1060.JPG)
Attachments PICT1060.JPG (102KB - 93 downloads)
sidesho_bob1961
Posted 2014-04-08 4:26 PM (#435109 - in reply to #275315)
1000500100252525
I've never saw stenciled numbers like that on assembly line parts.....very interesting. Keep up the excellent work!!!
LD3 Greg
Posted 2014-04-08 11:33 PM (#435147 - in reply to #435104)
1000500252525
Neil, the dash inserts in my Regal looked exactly like a regular 58 Dodge. No hint of any copper at all. I left them that way-- just like Aivar did. BUT, when you take them apart the copper colouring shows under all the edges covered by gauge and surround bezels. This is why I said that the copper colouring was definitely NOT paint. It was a fragile anodizing that faded to nothing in daylight.
Unless one was there when these inserts were actually disassembled for any particular car one could never know whether they were copper coloured or not.
Greg
d500neil
Posted 2014-06-29 12:12 AM (#447082 - in reply to #275315)
Paul, why is the frame factory-OEM painted 1-9-57A, upside-down, and you painted 2-1-58A, right-side up, on a frame rail?
christine-lover
Posted 2014-06-29 7:08 AM (#447103 - in reply to #275315)
200050010010010025
Isn't the 1-9-57 one from a red and white 57 Desoto convertible in Sweden?
springsweptwing
Posted 2014-11-23 11:21 PM (#462628 - in reply to #275315)
100025
Bit more done, will post more pictures when i get them off camera, in mean time steering box rebuilt and painted, found some white paint marks on which would have been done before fitting as it had run down length off steering box.
(steering box.JPG)
(steering box 2.JPG)
(steering box 3.JPG)
(steering box 4.JPG)
(steering box 5.JPG)
(steering box 6.JPG)
(steering box 7.JPG)
(steering box 8.JPG)
(steering box 9.JPG)
Attachments steering box.JPG (47KB - 87 downloads)
Attachments steering box 2.JPG (49KB - 92 downloads)
Attachments steering box 3.JPG (51KB - 93 downloads)
Attachments steering box 4.JPG (46KB - 98 downloads)
Attachments steering box 5.JPG (49KB - 86 downloads)
Attachments steering box 6.JPG (62KB - 100 downloads)
Attachments steering box 7.JPG (47KB - 84 downloads)
Attachments steering box 8.JPG (66KB - 94 downloads)
Attachments steering box 9.JPG (61KB - 88 downloads)
LD3 Greg
Posted 2014-11-24 11:55 PM (#462729 - in reply to #275315)
1000500252525
Great to see you posting again, Paul. Wonderful thread, keep up the good work! Look forward to seeing more!
Greg
LD3 Greg
Posted 2014-11-25 12:07 AM (#462730 - in reply to #462729)
1000500252525
Glad to see that you reproduced that paint daub as it was done---- with runs!! I have always thought of these as being inspection marks. You know, made by an inspector who was just paid to watch a particular, or series of procedures being done and completed. When completed, he simply painted his "Mark"! There were no points for neatness!
Greg
d500neil
Posted 2014-11-25 1:40 AM (#462734 - in reply to #462730)
Going back to Greg's comment/posting, of 4/18/14, above, the Regal Lancer literature does show 'bronze' colored/lacquered glove box and dash inserts on the car.
Chrome finish inserts look 'wrong' on a Regal Lancer's dash board.
Posted 2014-11-25 11:27 AM (#462749 - in reply to #462734)
Great work, Paul! Very few restorers would take the time to recreate these details! Your Regal is going to be outstanding.
matt
Posted 2014-11-25 1:27 PM (#462759 - in reply to #275315)
Great restoration.
