300c Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
carmikael |
Regular Posts: 84 Location: Northern sweden above the arctic circle!! | HI! I just bought a car..what did i buy? Oh its a 1957 300c hardtop..but can anyone decode? Edited by carmikael 2012-03-03 3:19 PM | ||
carmikael |
Regular Posts: 84 Location: Northern sweden above the arctic circle!! | here are the tag Edited by carmikael 2012-03-03 3:42 PM (Chrysler 300C -57 PllÃt 2 mini.jpg) Attachments ---------------- Chrysler 300C -57 PllÃt 2 mini.jpg (132KB - 332 downloads) | ||
Chrycoman |
Expert Posts: 1819 Location: Vancouver, BC | MODEL : ?66 : PNT : P : Gaugin Red - single tone TRIM : 60 : No info SCH : 0523 : Scheduled build date : May 23, 1957 ITEM : 0431 : 431st car scheduled to be built 0523 351 : Power antenna 328 : Power windows 326 : Power seat 353 : Stone shields 344 : Air conditioning, 323 required 335 : Mirror, outside, left rear view 321 : Radio with touch tuner 323 : Heater / Defroster BODY : 24071: 23,071st body built 265 : Delivery to dealer - via truck 332 : Solex glass Option 349 was for quad headlamps What's the VIN? Should be on a tag attached to the driver's door hinge post. Thanks, | ||
StillOutThere |
Location: Under the X in Texas | That would be a 566 for the body style indicating the 300C hardtop. The convertible was 563. Not every code relevant to the car appears on the data plate; several are only on the IBM card that built the car. Chrysler Historical or the 300 Club can do a full decode as they have microfiche of the IBM cards from which the cars were built. If you would like a 60 plus page 300C restoration Handbook showing all codes and far more information, I authored the book almost 20 years ago and it is self-published so it has had innumerable edits and updates. It is the only 300 Letter Car restorer's manual. PM me with questions. | ||
carmikael |
Regular Posts: 84 Location: Northern sweden above the arctic circle!! | HI! Thank you guys,that was fast decoded! This site and people here are the best! Thanks again! Mikael | ||
carmikael |
Regular Posts: 84 Location: Northern sweden above the arctic circle!! | Here are some pics for you interested. The car is in parts,99% complete..orig paint..no rust!!! Ididnt believe it first but there are no rust...look at the doors..unbeliveable! Mikael Edited by carmikael 2012-03-04 12:53 AM (Chrysler 300C -57 DDÃrr passargerarsida inner.jpg) (Chrysler 300C -57 Karossida Passagerarsida 1.jpg) Attachments ---------------- Chrysler 300C -57 DDÃrr passargerarsida inner.jpg (160KB - 329 downloads) Chrysler 300C -57 Karossida Passagerarsida 1.jpg (184KB - 333 downloads) | ||
finsruskw |
Expert Posts: 2328 Location: Eastern Iowa | That's an awedome find indeed!! It must have come off the line about the same time as my Parade Green coupe with that build date. Hey, maybe they know each other! Why in the world is the door off?? Dave S. | ||
matt |
Veteran Posts: 143 Location: Malmberget, Sweden | Nice find! | ||
Windsor59 |
Expert Posts: 2599 Location: Upplands Väsby, Sweden | Hope to see lite live forward Sven you built it upp. Verk Nice projekt. | ||
matt |
Veteran Posts: 143 Location: Malmberget, Sweden | I´ve heard at my job down under (LKAB) that you found this car in Sweden! any trouth in that rumour Mikael? | ||
carmikael |
Regular Posts: 84 Location: Northern sweden above the arctic circle!! | Here are a pic of glove box,it seems as they wrote wrong number first. The red numbers matches the numbers from tag. Also took pic of door jambs,def untouched. But lot of price winner 300c doesnt have painted door latches and strikers... (ATT00049.jpg) (ATT00071.jpg) (ATT00080.jpg) Attachments ---------------- ATT00049.jpg (62KB - 324 downloads) ATT00071.jpg (53KB - 331 downloads) ATT00080.jpg (43KB - 348 downloads) | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | The door latches and strikers are supposed to be painted, just like your is, Mikael. Because the latch receives some contact and loses a bit of its paint, some restorers are afraid to paint those items, for fear of losing some paint on them. Same thing with trunk latches and hood 'catches'; often you'll see them in natural finish instead of being painted. | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | Mikael, you should remove both doors' latch mechanisms and look at their inner/lower/hidden gear sets' condition. Those 'hidden' gears' condition bears no relationship to the probably-excellent condition of the visible upper-exposed latch gears. | ||
carmikael |
Regular Posts: 84 Location: Northern sweden above the arctic circle!! | Neil,what can you tell about the double numbers on glove box? Maybe not a miswriting,maybe the first writing means something? No buildsheet found above glove box... Interesting doing some car arceologhy:) Mikael | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | What numbers have you found, there, Mikael? | ||
1959Dodge |
Expert Posts: 2244 Location: Yorba Linda, Ca | Look at the 4th picture from the top picture, Neil, that is a glove box with numbers on it. It had red and white numbers. Gary Edited by 1959Dodge 2012-04-14 10:53 PM | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | uh...OK! Note how the parts number was corrected, from 409-1506, to 523-431; makes you wonder how/when the mistake was found, and what the assembly line had to do to correct the installation, to reflect the proper coding. Although somewhat similar in style, the handwriting is different in those numbers, so a different person (with an orange crayon) discovered and corrected the screw up; his marking-offs' style indicates that he wasn't too happy to have found the mistake. This writing is on the underside of the glove box? Those numbers almost certainly confirmed how the dashboard was to be assembled and painted, because no one else would ever have been able to see and take note of those numbers, except for someone creating the dash board features. Edited by d500neil 2012-04-15 1:49 AM | ||
carmikael |
Regular Posts: 84 Location: Northern sweden above the arctic circle!! | yes it on underside. The last writing with the red crayon matches the numbers on the body tag. SCH : 0523 : Scheduled build date : May 23, 1957 ITEM : 0431 : 431st car scheduled to be built 0523 Mikael Edited by carmikael 2012-04-15 3:13 AM | ||
StillOutThere |
Location: Under the X in Texas | Note the 523 on the bottom of the glove box is also on the data plate as the date the cars was SCHeduled to be built. It is the month (5) May, followed by the date; 23rd day of the month. This 523 then is also the beginning of the sequence number which becomes the shipping order number. Thus on May 23rd this was the 431st car to be loaded up for truck transport. The original number that was Xed out was a change or an error and it is highly doubtful that anything more complicated than that needs to be ascribed to it. The grease pencil markings on the bottom of the glove box are described in the Decals/Stamps/Tags/Markings chapter of my '57 Chrysler 300C Handbook for restorers. | ||
carmikael |
Regular Posts: 84 Location: Northern sweden above the arctic circle!! | Ok,i will look in that chapter in my book i bought from you.(hasnt had time read thru it thoroughly) Thanks Mikael | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | The grease pencil markings would serve the same purpose as masking taping a broadcast sheet to the glove box, as was done on the Dodges. It quickly confirms to the Line Supervisor (if he bothered to look) that 'this' dash assembly does indeed go onto 'that' car 0431 (which was Scheduled to have been built on May 23rd). Some scheduler had earlier planned that that glove box was to have been put into a car that was Scheduled to have been built o.o.a. 4/9/57, with a sequence number of 1506. You can't screw up (typo-) a couple production dates by almost a month and a half ? Edited by d500neil 2012-04-15 8:50 PM | ||
