  Location: central Massachusetts | As I poke around the '55 Custom Royal on YET another rainy day, I figured I would clean up the turn signal lens, etc. Although they all work the front, rear, reverse, dome, and now I noticed, gauge lights (which were either missing or burnt out) are mismatched numbers. This may explain the brighter/dim front markers which I thought were just experiencing a ground issue. I figured I have the time and since the bulbs are exposed or easy access, I would like to set everything straight and matched. The car is still 6V. Could one of you share the correct # for the front markers/turn signals, rear tail lights, reverse, dome,map, gauge clusters, under hood and trunk. Like I said, ...I am grounded so figured I would keep busy or the wife will find something for me to do! Thanks! |
