318/350 Camshaft
RobbytheRobot
Posted 2012-06-23 3:05 AM (#326799)
Subject: 318/350 Camshaft
Does anyone know if I can put a 350 Golden Commando camshaft in a 318 engine? Thanks.
58coupe
Posted 2012-06-23 12:13 PM (#326855 - in reply to #326799)
Subject: RE: 318/350 Camshaft
10010010025
NO, will not fit. You can interchange all big block and raised big block cams: 350,361 383, 400,413,440, 426 wedge. The 440 magnum used a 3 bolt cam sprocket and the others only 1 bolt, just use the correct sprocket. The A engine, 277,301,303,313, 318 326 will interchange but are completely different from the 1967 and newer LA engines, 273, 318, 340, 360.
RobbytheRobot
Posted 2012-06-23 12:26 PM (#326857 - in reply to #326799)
Subject: Re: 318/350 Camshaft
Thank you 58coupe.
Search for anything on eBay!
