1960 dodge vent window rebuild Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
ttotired |
Expert 5K+ Posts: 8443 Location: Perth Australia | Hi All I have been reading the other vent window thread trying to learn off that one, but it seems that the 56ers used rubber in the glass run channel from the looks of it. I am looking at the ones for my dodge (4 dr sedan) and the ones on the plymouth (4drht), and I cant see how the flocking (or whatever its called) comes out. I got my door rubbers ect from andy burbaum and I got them to send me what is supposed to be the channel part for a 4drht in the hope that I can work out how to put it into the dodge, but I cant see how it would go into the 4drht either. I dont have the vent windows out of the dodges doors yet, but the ones for the plymouth are. I didnt want to incroach on the other thread Has anyone fixed these before or are they a case of find the best you can? Cheers Mick | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | The Divider bar channel has a strip of mohair glued in the channel (Gary Goers). The mohair was glued into the channel first, then the stainless moulding is pushed over the channel and riveted to the divider bar. It is possible to clean out all the old remains and trim a mohair strip to a center widht of 23 mm for a lenght of 365 mm of the total of 770 mm lenght of the strip. I'm doin it now, so I will try to upload some pic's later. | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | Here are some pictures. You'll need a rotary cutter for the best result, the green sheet is a selfcuring plastic used for quilting, same as the ruler (special grid keeps the fabric firmly while cutting). The '60 divider channel is covered for the whole lenght with a stainless molding, while the "newer" (62 and up?) has only the half lenght covered by stainless molding. My spare frame and channels are from a '63, I believe. I cut the mohair in a "T" shape for a perfect fit in the channel part covered with the stainless moulding, wider where there is no stainless moulding - that way I can fold it over and glue it to the channel side. I used the Schotch-Weld (very sticky and tready), applied only richly to the channel sides and mounted the mohair with the glue still wet and "open". After adjusting the position perfectly, I added some masonite strips for to press/hold the mohair in position while the glue cured. (Resize of IMG_8325.JPG) (Resize of IMG_8340.JPG) (Resize of IMG_8342.JPG) (Resize of IMG_8347.JPG) (Resize of IMG_8348.JPG) (Resize of IMG_8350.JPG) Attachments ---------------- Resize of IMG_8325.JPG (43KB - 169 downloads) Resize of IMG_8340.JPG (84KB - 163 downloads) Resize of IMG_8342.JPG (68KB - 181 downloads) Resize of IMG_8347.JPG (60KB - 164 downloads) Resize of IMG_8348.JPG (49KB - 164 downloads) Resize of IMG_8350.JPG (51KB - 157 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | Here is the measurements (in millimeters - work it out ) I'll update with the measures for the rear channel later........ Edited by wizard 2013-02-06 6:18 AM (Resize of Mohair_template.png) Attachments ---------------- Resize of Mohair_template.png (25KB - 174 downloads) | ||
ttotired |
Expert 5K+ Posts: 8443 Location: Perth Australia | Thanks Wiz Your a genius, I'll go shopping for the stuff today (I think) I have no idea what the other chanel thing will work on, but I will find where it sits when I get into the doors some more | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | Here's the rear channel and the updated drawing (Resize of IMG_8351.JPG) (Resize of IMG_8352.JPG) (Resize of IMG_8353.JPG) (Resize of Mohair_template.png) Attachments ---------------- Resize of IMG_8351.JPG (72KB - 171 downloads) Resize of IMG_8352.JPG (71KB - 172 downloads) Resize of IMG_8353.JPG (36KB - 174 downloads) Resize of Mohair_template.png (34KB - 171 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | Here is ther rear channel ready (Resize of IMG_8354.JPG) (Resize of IMG_8358.JPG) (Resize of IMG_8360.JPG) Attachments ---------------- Resize of IMG_8354.JPG (47KB - 156 downloads) Resize of IMG_8358.JPG (37KB - 170 downloads) Resize of IMG_8360.JPG (49KB - 179 downloads) | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | Gary Goers makes/sells those vent window run channels. Just pop 'em in. | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | For your knowledge Neil, the mohair strips comes from Gary - there's no place for any "pop-ins" in the 60-64 channels. Well I take that it was a slip of your tongue.... makes me think about a joke; Do you know the equality between speaking in the parliament and eating p***y... one slip of the tongue and your in deep sheet Edited by wizard 2013-02-08 3:58 PM | ||
ttotired |
Expert 5K+ Posts: 8443 Location: Perth Australia | Good joke Wiz I was going to try the local habbadashery (stupid word) cloth shop and see iff they have it, but I do need to put an arder in at gary goers, so might just get it there Thanks | ||
d500neil |
Exner Expert 19,174 posts. Neil passed away 18 Sep 2015. You will be missed, Neil! Posts: 19146 Location: bishop, ca | Well, I suppose that if you were to become happy with your mohair (the opposite of lesshair?) work, it could be said that you would have had Merry Pop-in's ? Edited by d500neil 2013-02-09 3:24 AM | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | The part No is Gary Goers 6114 Michael. The Merry Pop-in's (good one Neil) is for the 4 door sedans mostly | ||
ttotired |
Expert 5K+ Posts: 8443 Location: Perth Australia | Cheers wiz I think Neil has had a few merry drinks | ||
ttotired |
Expert 5K+ Posts: 8443 Location: Perth Australia | What I ended up doing was use wide velcro (the soft loop side) that has sticky on the back and just pushed it in. It seems to have worked fine, but my car is not in service yet, so I dont know how durable it will be | ||
Adventurer 60 |
Elite Veteran Posts: 827 Location: tailFinland | wizard - 2013-02-08 3:08 PM For your knowledge Neil, the mohair strips comes from Gary - there's no place for any "pop-ins" in the 60-64 channels. Well I take that it was a slip of your tongue.... makes me think about a joke; Do you know the equality between speaking in the parliament and eating p***y... one slip of the tongue and your in deep sheet Wiz! I got my mohair strips from a guy who was selling this kind of interior material, in Västerås Power Meet swap. He got rolls of it. You perhaps know this company, They got a gatalog. | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | Yes Jari, I know them now - I bought the strips many years ago and had them on the shelf. For the convenience of those that doesn't know them, it's Örebro Agenturaffär http://www.agenturaffaren.se/ | ||
