blank ibm card
   Forward Look Technical Discussions -> Fender/VIN Tag and Broadcast Sheet DecodingMessage format
1956DeS
Posted 2013-02-06 11:06 AM (#358622)
Subject: blank ibm card
5001001002525
In '56, it seems the  LA plant used this card for all cars.  The colors on the card correspond to a Plymouth.
Some areas were unreadable.
Edited by 1956DeS 2013-02-06 11:11 AM
Attachments 56 IBM BLANK sm.jpeg (169KB - 399 downloads)
d500neil
Posted 2013-02-07 1:34 AM (#358746 - in reply to #358622)
Subject: Re: blank ibm card
5000500050002000200010025
Yup; and the commonality of this IBM card makes it very difficult to confirm the various possible D500 equipment codings
for a Dodge, although the D500 engine number is hand-written under the "Motor Number" box, on it, but, confirming the
HD suspension items, or not, is not self explanatory on them.
Also, the 1955 & 1956 Detroit built Dodge IBM cards are identical, which causes more confusion in understanding what
they're saying, about either years' options.
1956DeS
Posted 2013-02-07 2:27 PM (#358863 - in reply to #358622)
5001001002525
The punches seem to correspond to an invisible grid of numbers on the card. 1's across the top, 2's next line...on down to the bottom row of 9's which are visible. Following the punch up to the very top of the card, the numbers are printed out for various things...I think.
[It took me forever to make this.  I thought I would go blind.]
Edited by 1956DeS 2013-02-07 2:28 PM
d500neil
Posted 2013-02-08 1:30 AM (#358972 - in reply to #358622)
Subject: RE: blank ibm card
Here's the card, in-question.
Yeah, the side numbers relate to the punch-outs on a vertical line of codings, but, the trick is in understanding
what a certain punch-out might specifically refer-to (and, of course, where, on the P/T plate a certain option coding might be located, that refers to a coding on the IBM card).
Edited by d500neil 2013-02-08 1:33 AM
(56 IBM Card.jpg)
Attachments 56 IBM Card.jpg (169KB - 357 downloads)
