Reproduction weatherstripping?
The Chrysler Kid
Posted 2014-04-02 2:12 PM (#434307)
Subject: Reproduction weatherstripping?
1000100100100252525
Anyone know of a good source?
plymouth
Posted 2014-04-02 2:55 PM (#434315 - in reply to #434307)
Subject: Re: Reproduction weatherstripping?
20001001002525
Try rockauto. I just ordered the trunk seal for my Polara.
kmccabe56
Posted 2014-04-02 3:06 PM (#434318 - in reply to #434307)
Subject: RE: Reproduction weatherstripping?
100100100252525
Can't speak specifically to FWDLK cars, but my '78 NYB uses the same roof rail w/s as some similar vintage Caddys. The extruded corners have to be recycled, but the straight runs are a total swap-in.
If you still have enough of your original rubber, some time perusing something like the Metro Molded catalog might find you the same cross sections, which are likely the most important issue.
JT Vincent
Posted 2014-04-15 5:05 PM (#436244 - in reply to #434307)
1000100100100100252525
On a sedan, this stuff is pretty easy to approximate with standard yardage. I don't even recall any special corners. it's just a strip around the 2 doors and a strip for where the deck closes.
Posted 2014-04-15 9:04 PM (#436291 - in reply to #434307)
50002000100100
The Chrysler Kid - 2014-04-02 11:12 AM
Gary Goers, download his catalog. http://chryslerclub.org/PDF%20files/GOERS.pdf
NewportBob
Posted 2014-05-01 12:43 PM (#438812 - in reply to #434307)
All the weatherstripping on my '61 is from Gary's Goers: good stuff
wbower3
Posted 2014-05-01 9:41 PM (#438851 - in reply to #434307)
Walter passed away on Jul 29, 2014. We will miss you, Walt!
50001001001002525
Can also try Steele Rubber Co. I've used their products for years and it always fits, or they make it fit! ! ! ! And prices are competitive. . . .
I've also noticed that thee are some re-sellers out there that buy from Steele and dropship the products to the customer.
