Location: Upstate NY | I pull the headliner down (it was rotten) and all these nests are coming down with mice feces and skeletons and I just want to get it down as fas as possible. In doing so I pulled all the rods out and threw them all together as I moved to the rear. Well then I start looking at them and some have red ends some orange others white so what is the sequence for reinstallation or should I just fit them the best I can? is there a standard sequence? 57 Fireflite 4dr Sedan
Thanks
Bob |
Location: Alaska | I have yet to do this on my car but there is supposed to not only be a sequence but multiple holes each rod can go in. |
Location: Upstate NY | Oh boy! I was afraid of that and figured as much when I saw the colors on the ends of the rods. Thanks for your reply. |
Location: Perth Australia | I kind of had the same problem
I removed the roof lining in my dodge in a hurry (it was on fire at the time), so I lost the position of a couple of the bows
I thought as they had to go in the right spot, that the service manual might have had the sequence in it, but I couldnt find it
I didnt (but should have) written the sequence down once I worked it out
You should be able to "dry run" the bows in the roof to get an idea
If its any help, the one with the biggest loop is the second last
Location: Perth Australia | Not sure if this is help full, but heres a pic of mine when it was out
(roof lining 007.jpg)
Attachments ---------------- roof lining 007.jpg (75KB - 51 downloads)
Location: Upstate NY | Not really but thanks anyway. I will fit them in empty and get a feel for where they go. |
