extended ball joints
Mopar1
Posted 2014-12-19 2:44 PM (#465227)
Subject: extended ball joints
2000100025
If you're putting disc spindles on your car & the A arm mounts are closer than on the OEM spindles 1/2" & 1" extended shaft ball joints are available to restore travel distance. Made by MOOG or QA1. QA1 has a list at http://www.qa1.net/suspension/ball-joints/screw-in-style-ball-joint...
