Location: Perth Australia | As the title says, I messing about with some of the smaller (costly) stuff
I have 4 of these clocks now, a NOS one thats in a cupboard (for the plymouth) and 3 others
2 I only recently got and 1 I had in the dodge, but the ratchet on the wind up wheel thing kept spinning around backwards, making the internal solder fuse melt
I worked out that the tiny hole that the wind up wheels axle goes through was worn out a bit (I think), so I bent the plate that has the hole a really small bit to tighten the mechanism a bit
Its working now, so time will tell, the other 2 were dirty inside and basically needed a clean and re lube
I put one of the recent purchases back in the dodge and I guess I will end up selling these 2 at some stage provided they stay working
The heater control is really just a clean up of the switch, the vacuum side I havnt worked out yet
Its quite ingenious how they make the buttons pop out when you push another one
(Accessories 002.jpg)
(Accessories 003.jpg)
Attachments ---------------- Accessories 002.jpg (50KB - 116 downloads) Accessories 003.jpg (52KB - 111 downloads)
