another 1960 Chrysler appeared Jump to page : < ... 9 10 11 12 13 14 15 16 > Now viewing page 15 [50 messages per page] | View previous thread :: View next thread |
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | I cleaned the brake pad carriers and added heat resistance copper paste at the contact areas. Brand new return springs are mounted as well. The brake hoses front and at the rear axle to the corresponding carriers are mounted as well (clips to keep the brake hose in place as well). Soon, the brake lines... (IMG_0070 brake pad mounted.JPG) (IMG_0071 as well the return springs are mounted.JPG) Attachments ---------------- IMG_0070 brake pad mounted.JPG (298KB - 145 downloads) IMG_0071 as well the return springs are mounted.JPG (274KB - 151 downloads) | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Today I went to the paint&body-shop to visit the owner. One bad news and one good news (a joke). All parts are painted, the dashboard and corresponding parts got a clear coat as well. This afternoon, wanting to install the brake lines.... only the long brake line I could conned to both ends, but some points to discuss around the front subframe and the rear axle tunnel longitudinal rail... The brake line kit from InlineTubes is from below the lowest bottom drawer, not worth the money I spent. I tried to bent it to the shape the old front axle brake lines show. The wheels got glossy black and a new set of tires. The tire on the passenger side front wheel is mounted, just to look how it looks. Dieter
BTW.: new brake lines for the front axle, the rear axle (destroyed at the first shop) and the main brake line from the main brake cylinder to the distribution block are welcome... different supplier? Edited by di_ch_NY56 2022-05-14 11:37 AM (IMG_0124 dashboard and small parts painted.JPG) (IMG_0129 main brake line and rear axle brake lines are a joke InlineTube.JPG) (IMG_0130 drivers side front wheel brake line does not fit InlineTube.JPG) (IMG_0131 passenger side front wheel brake line from InlineTube.JPG) Attachments ---------------- IMG_0124 dashboard and small parts painted.JPG (301KB - 149 downloads) IMG_0129 main brake line and rear axle brake lines are a joke InlineTube.JPG (327KB - 155 downloads) IMG_0130 drivers side front wheel brake line does not fit InlineTube.JPG (390KB - 153 downloads) IMG_0131 passenger side front wheel brake line from InlineTube.JPG (478KB - 154 downloads) | ||
Expert 5K+ Posts: 9650 Location: So. Cal | Make your own brake lines yourself. The tool you purchase will pay for itself the first time you use it. The dash looks great. Chrysler never painted the dash so shiny because they were worried about reflections into the driver's eyes. So they made all the dash paint with a satin finish. | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Powerflite - 2022-05-13 6:49 PM Make your own brake lines yourself. The tool you purchase will pay for itself the first time you use it. The dash looks great. Chrysler never painted the dash so shiny because they were worried about reflections into the driver's eyes. So they made all the dash paint with a satin finish. A 3/16 inch roll of steel brake line is at me now, the tools are in shipping mode. I just ask, did you forget, that the dashboard has a cover ontop? So most of the shiny area will be covered with the dash pad. | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | in the mean time... partial assembly (preliminary) of the dashboard (new dash board pad ordered, no answer to the question of new aluminum panels). Happy Restoring! Dieter
(IMG_0222 dashboard preliminary part assembly.JPG) (IMG_0235 brake reinforcement plate painted.JPG) Attachments ---------------- IMG_0222 dashboard preliminary part assembly.JPG (364KB - 141 downloads) IMG_0235 brake reinforcement plate painted.JPG (287KB - 145 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | Jan Fridberg should have the alu panels repopped Dieter | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Today I mounted the NOS heater control box into the cleaned holder and back into the moulding. The original heater box... I could remove all buttons without destroying the take up area of the buttons. It is fully functional (all buttons were working hassel free, the fan was working on both speeds, just most of the nipple broke off - I do not dispose it). Prior I removed the rust and did massage penetrating oil onto the holder. Thank you Sven for the nice parts I could purchase from you. Happy Restoring! Dieter BTW: the illumination got a new bulb (the original one wouldn't last long anymore - from the appearance) BTW2: the brake booster is on the way to Booster Dewey - I hope I'll get it back once Edited by di_ch_NY56 2022-06-12 10:15 AM (IMG_0251 NOS heater control box.JPG) (IMG_0252 original heater control box.JPG) Attachments ---------------- IMG_0251 NOS heater control box.JPG (285KB - 150 downloads) IMG_0252 original heater control box.JPG (262KB - 140 downloads) | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | I got the new dash panels. I did mount it yesterday evening. The new panels are looking gorgeous. To the engine... The block is bored out, the pistons mounted. I got a notification from the engine builder, containing three pictures (enclosed in the entry). Short: the engine block is good, the camshaft is toast (lobes worn down), the judgement of the crankshaft is desastrous. Crankshaft: not like the engine block new at the time, but cut to one step undersize. After grinding, hardening, polishing... one tenth bent of the whole length and many hair cracks did appear. Cylinder grinder and the engine builder do not recomend to use this crankshaft longer - it's jam. SO, I NEED A NEW EARLY RB CRANKSHAFT, the better the condition, the sooner, the better ~ big thank you Big thank you Dieter (bild1 journal bearing with straightening mark and load of hair cracks.jpg) (bild2 journal bearing with straightening mark and loads of hair cracks.jpg) (bild3 journal bearing with straightening mark and load of hair cracks.jpg) Attachments ---------------- bild1 journal bearing with straightening mark and load of hair cracks.jpg (437KB - 133 downloads) bild2 journal bearing with straightening mark and loads of hair cracks.jpg (433KB - 143 downloads) bild3 journal bearing with straightening mark and load of hair cracks.jpg (456KB - 132 downloads) | ||
22mafeja |
Elite Veteran Posts: 649 Location: Finland | This is very sad Dieter. I am no crankshaft expert but in my eyes it looks like it has been worn out and welded and then badly grinded. I will keep the eyes open for a RB axle here in Finland. | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | 22mafeja - 2022-06-24 5:23 PM This is very sad Dieter. I am no crankshaft expert but in my eyes it looks like it has been worn out and welded and then badly grinded. I will keep the eyes open for a RB axle here in Finland. Hi Ralf The cylinder grinder is a very professional person. He said, too bad he didn't see the damage sooner, he did grind the crankshaft to the next undersize measurement - nothing did appear until the crankshaft got a hardening process for the surface of the bearing surfaces. During the hardening the cracks did open. the cracks did appear during the polishing process! The cylinder grinder said, nobody knows how deep theese cracks are (forged crankshaft). Of course during the hardening the crankshaft bent again. For sure the crankshaft could get hammer and chisel (round tip) hits to get it straight again. But the risk for a crankshaft cracking (falling into two parts) will rise drastically. BTW: my first thought was the same as yours, with no background information. kind regards Dieter | ||
22mafeja |
Elite Veteran Posts: 649 Location: Finland | Hmm I wouldn`t have ordered any hardening at all. Just grinding and polishing. The hardening seems to be the beginning of the troubles. Surely it would not have been needed on an engine going to be used very carefully. | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | 22mafeja - 2022-06-24 10:47 PM Hmm I wouldn`t have ordered any hardening at all. Just grinding and polishing. The hardening seems to be the beginning of the troubles. Surely it would not have been needed on an engine going to be used very carefully. Hypthetically just the main and connecting rod bearing surfaces are hardened. It's a question if thermal hardening or chemical hardening is better. But for sure a hardened surface at the bearing surface would last ways longer than a soft surface. Sidemark, but very interesting... the engine builder did resist from balancing the rotating assembly. So, this way no amount lost for a useless job. BTW: The trouble began at the Chrysler factory. The should have thrown away that bent crankshaft and use a new one, just like the engine block. Apparently the engine block has been exchanged (why else did the engine block have the original bore measurement?). Of course during the thermal process this crankshaft sprung back to the original shape (bent). Happy Restoring! Dieter Edited by di_ch_NY56 2022-06-26 2:17 AM | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Brake lines are done, except the one from the main brake cylinder to the distributor. But... At one hex nut is free turning at the top right position (one of five) - the threaded stem almost has no thread anymore. Replacement? Happy Restoring! Dieter (IMG_0365 brake shoe support plate rear axle drivers side - note hex nuts.JPG) Attachments ---------------- IMG_0365 brake shoe support plate rear axle drivers side - note hex nuts.JPG (236KB - 130 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | Zollshop.de | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | wizard - 2022-07-09 11:42 AM Zollshop.de Thanks Sven - as far as I got out, it's pressed in. Will see if the Zollshop has the fitting press in screw | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | Hmm, mine are ordinary bolts and nuts Dieter | ||
22mafeja |
Elite Veteran Posts: 649 Location: Finland | What length are they? I might have one in one of my boxes... I suppose the bolt head is round with a section cut of for locking behind the axle flange.. | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | 22mafeja - 2022-07-11 5:18 PM What length are they? I might have one in one of my boxes... I suppose the bolt head is round with a section cut of for locking behind the axle flange.. UNF 3/8-24 x 1-1/4" - I did order the bolts at epain Edited by di_ch_NY56 2022-07-12 12:59 PM | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Old brake shield bolt (almost no thread on it) of the brake support plate drivers side rear is removed. Light tap with a fitting punch and a light hammer hits was enough to get it out. New bolt (modified screw) installed and all five screws tightened equally. Happy Restoring! Dieter BTW: still recovering from Covid-19 (16.7.2022 grill party at the employers hall) - negativ again since August, 1st Edited by di_ch_NY56 2022-08-02 9:21 AM (old brake shield bolt out - new screw modified.jpg) Attachments ---------------- old brake shield bolt out - new screw modified.jpg (51KB - 126 downloads) | ||
Expert 5K+ Posts: 9650 Location: So. Cal | I'm surprised it stripped the bolt. Everytime I have had that trouble, the nut strips, but the bolt is fine. Usually, the bolt is very hard, but the nut is much softer. | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Powerflite - 2022-08-01 6:03 PM I'm surprised it stripped the bolt. Everytime I have had that trouble, the nut strips, but the bolt is fine. Usually, the bolt is very hard, but the nut is much softer. I don't know if the first shop (lock and farmer smith but not a car mechanic) did sandblast that stem... I had big difficulties to remove all the sand blast sand. Happy Restoring! Dieter | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | While assembling the dashboard. I wanted to install the Chrysler 403 Golden Touch radio into the dashboard - not mounted, when I got my Letter. What I discovered is - one mounting nut is missing - where to get one? - mounting support rear to the dashboard lower end is missing - where got get one? I'll appreciate your help. Thank you. Dieter (IMG_0740 Chrysler Radio 403 installing.JPG) Attachments ---------------- IMG_0740 Chrysler Radio 403 installing.JPG (411KB - 94 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | I might have both Dieter, I'll check.... | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | wizard - 2022-10-01 2:30 PM I might have both Dieter, I'll check.... big thanks to you | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Just minor details are still waiting for the dash board. It's almost ready to install. I'm waiting for the dash pad now and some small parts already ordered. (IMG_0774 dashboard waiting for the dash pad.JPG) Attachments ---------------- IMG_0774 dashboard waiting for the dash pad.JPG (320KB - 93 downloads) | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | This afternoon first I cleaned up the trunk floor, the axle tunnel and passenger compartment floor (resting sand blasting sand due to force out the sand with pressurized air and nozzle). Then I laid out first the roof wiring (illumination while door is open) and installed the wiring. Some time and the end with the connectors got through the C-pillar as it was. Then the rear light wiring and installed it. Next was the center console and electric window lift wiring. Finally the main wiring, containing the dash board wiring, the engine wiring and the front lights... Missing... the dash board (just the soft cover - pot metal problems later - retirement of me), the circuit breakers (toDo list on Sunday), the engine and the inner fenders (after the engines is installed). (IMG_0823 wiring trunk.JPG) (IMG_0824 connetions trunk and passenger compartment light.JPG) (IMG_0825 passenger room compartment.JPG) (IMG_0826 passenger compartment center wiring.JPG) (IMG_0827 foot well and dash board wiring.JPG) (IMG_0829 engine compartment wiring.JPG) Attachments ---------------- IMG_0823 wiring trunk.JPG (206KB - 91 downloads) IMG_0824 connetions trunk and passenger compartment light.JPG (233KB - 88 downloads) IMG_0825 passenger room compartment.JPG (195KB - 89 downloads) IMG_0826 passenger compartment center wiring.JPG (227KB - 93 downloads) IMG_0827 foot well and dash board wiring.JPG (259KB - 93 downloads) IMG_0829 engine compartment wiring.JPG (305KB - 91 downloads) | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Prior Christmas I traded in the old rear bumper for the cover of the antenna acces at the farmer smith's. During the Christmas Season I restored and mounted the cover on the passenger side inner fender (antenna cable access). The crankshaft did arrive and is at the engine restorer's now (last week: two weeks holiday, I didn't see my engine block while googling around). The dash pad is on the road as well. A solution for the long awaited brake booster is on sight. Happy Restoring!
BTW: partial restoration of the kitchen at me is on work as well. Edited by di_ch_NY56 2023-01-11 2:10 AM (IMG_1062 Antenna access cover mounted.JPG) Attachments ---------------- IMG_1062 Antenna access cover mounted.JPG (163KB - 72 downloads) | ||
ToMopar |
Elite Veteran Posts: 1157 Location: D-70199 Heslach | Dieter happy new year. The service door on inner fender looks familar and may similar to 57 Fireflite Can't wait to see yout "F" in person Regards from Stuttgart /ToM | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | That car is gonna be real nice once it's don, that's for sure! Great news about the crank Dieter. Let me know before you mount the dash pad - I have some advices..... | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Thanks a lot to you (both) Early August 2022 I started with mounting the exhaust system as well. The drivers side muffler didn't fit as expected. So I will have a look next Saturday. Because when I brought the crankshaft to the engine shop, I took the resting parts of the muffler system back to the barn (the exhaust system has to be mounted prior the engine, except you'll remove the steering box). Happy Restoring! Dieter | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | The dashpad has arriven. It looks very nice. In short form.. I have to cut out the surrounding of the speaker grille. Then... what glue to use? I assume fluid glue to use a small brush, am I wrong? It doesn't hurry... Happy Restoring! Dieter | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | No glue at all Dieter. The pad is held in place with tabs in the front towards the windsheild. Push through and bend slighty with pincer. Over the glowbox there are clips with studs and nuts. Under the AstraDome cap theres a garnish with screws. It's best to put a light coat of silicone on the AstraDome pot metal housing for easier mounting. Cut out for the speaker grille and rearview mirror first when you mouted the pad. If there still is the transport safety in the AstraDome area, then cut it out before mounting. Trim the areas for the pushbuttom unit when the pad is mounted. The radio garnish must be removed before mounting the pad. | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | wizard - 2023-01-12 8:37 PM No glue at all Dieter. The pad is held in place with tabs in the front towards the windsheild. Push through and bend slighty with pincer. Over the glowbox there are clips with studs and nuts. Under the AstraDome cap theres a garnish with screws. It's best to put a light coat of silicone on the AstraDome pot metal housing for easier mounting. Cut out for the speaker grille and rearview mirror first when you mouted the pad. If there still is the transport safety in the AstraDome area, then cut it out before mounting. Trim the areas for the pushbuttom unit when the pad is mounted. The radio garnish must be removed before mounting the pad. Thank you very much for your very accurate guide to mount the dash pad. In the barn I have to look for the bar with the threaded stems... it's not mounted on the dash pad. I guess I'll take a scissor to cut that area out (soft). Happy Restoring! Dieter (IMG_1175 detail 1960 Chrysler dashpad.JPG) Attachments ---------------- IMG_1175 detail 1960 Chrysler dashpad.JPG (280KB - 74 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | If I recall, there should be 5 small clips with studs welded to them Dieter. You must cut in the proper area for to install them. If you still have the old dashpad - check if the clips are still there. On my pad, the tabs in the front was included | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | wizard - 2023-01-13 10:35 AM If I recall, there should be 5 small clips with studs welded to them Dieter. You must cut in the proper area for to install them. If you still have the old dashpad - check if the clips are still there. On my pad, the tabs in the front was included Thanks for your information. The dashpad is now mounted. But not without scratches at the antracite metallic surface (of course, visible area) I noted that the countersunk phillips screws (8-24 * 3/8") were too short for two position. So I did order a set of the same screws, but 1/2" long. I mounted the whole exhaust system this morning. The hex nuts at the joints are just slightly torqued. But the metal strip with 5 studs (I saw it, when I removed the old dashpad - a pain to do it; it's was broken in small pieces and the foam did glue to the surface). I came to the conclusion that I have to take a second 110 Liter trash bag with me, to move from one to the other with a chance to find the strip. Happy Restoring Dieter Edited by di_ch_NY56 2023-01-14 12:37 PM (IMG_1177 exhaust system installed.JPG) (IMG_1178 dash pad mounted.JPG) Attachments ---------------- IMG_1177 exhaust system installed.JPG (293KB - 73 downloads) IMG_1178 dash pad mounted.JPG (309KB - 73 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | Dieter, I found a couple of spare clips. I think there were 5 of them. It's a must to have them, but it's not difficult to fabricate new ones. It seems that the clips are just tucked in on the upward bent area of the dash pad. (20230115_113944.jpg) Attachments ---------------- 20230115_113944.jpg (166KB - 66 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | As for the risk of damage the paint, I use thin but good plastic strips for to guide in the taabs. Far as I recall, you should have the clips as we discussed this when you removed the old dashpad. I don't think that there was a strip with 5 studs. | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Dear Sven Please excuse me. It was not a plan to mount the dash pad asap. So I thought I'll read your very good guide later. Too late, yesterday. I could slap my head, inseart the rear first and bend all tabs. But... I bent the tabs afterwards, the light gap has disappeared and the area above the glove box fits good and tight. At the time righ now. Happy Restoring! Dieter | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | Remove the pad again, fix the paint damages, find the clips and mount it properly. Mopar did not mount anything not needed, the pad will tend to shrink somewhat due to the ambient. | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | wizard - 2023-01-14 6:35 PM Remove the pad again, fix the paint damages, find the clips and mount it properly. Mopar did not mount anything not needed, the pad will tend to shrink somewhat due to the ambient. Postponed to the Spring. Happy Restoring! Dieter | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | got the band with the threaded stems for the dash pad, but I assume to contact Tony. One more thing that needs my attention asap! (IMG_1250 dash pad mounting strip (old one).JPG) (IMG_1246 malignant melanoma.JPG) Attachments ---------------- IMG_1250 dash pad mounting strip (old one).JPG (341KB - 64 downloads) IMG_1246 malignant melanoma.JPG (57KB - 71 downloads) | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Dash board stripped again to ship to the body and paint shop to get a new surface of charcoal metallic color. I assume I'm going to install the dash board afterwards direct into the car. Happy Restoring! dieter | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Dash board stripped again to ship to the body and paint shop to get a new surface of charcoal metallic color. I assume I'm going to install the dash board afterwards direct into the car. Happy Restoring! Dieter BTW: April, 29th this year appointment at the dermatologist to check my skin. (IMG_1278 dashboard stripped again to ship.JPG) Attachments ---------------- IMG_1278 dashboard stripped again to ship.JPG (343KB - 65 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | Your dashboard will be fantastic once it's ready Dieter. To mount the dashpad, two persons is needed to keep control of the tabs. Cut small strips of plastic to use as guides for the tabs. Mount everything in the dashboard and mount the unit with two persons in the car. Dont forget the cable harness and the windlace before mounting the dashboard. | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Got a phone call from the engine builder. He did ask for an appointment at the cylinder grinder company near the engine builders home. March 1st. I'll be there on the afternoon. Title of the mail for the appointment dates is "work on heads and engine block". My Idea was from Nick's Garage "413 Head Work - Valve Job, Bowl Work and New Seals". Happy Restoring! Dieter | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | The windshield trim clips (361 B from Quirey Quality Design, as well as the #704 upper windshield and rear window clips) I got. The rear window trim clips (361 A are not deliverable). Where to get it? I need 10 clips, the original all mostly are rusted away. I'll appreciate your answer. Thanks Happy Restoring! Dieter Edited by di_ch_NY56 2023-02-25 5:20 AM | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | Check with Big M, John Fowlie Dieter. Otherwise, hopefully you have at least one for to use as a template for to fabricate new ones. | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | wizard - 2023-02-24 11:32 AM Check with Big M, John Fowlie Dieter. Otherwise, hopefully you have at least one for to use as a template for to fabricate new ones. Thanks, reproduction in Switzerland is the very most expensive way (tool costs!). At least I have two ones (all others were broken into parts due to the corrosion), at one the perimeter is good, on the other the mounting to the body is quite okay, but very coarse, do to the rust. Happy Restoring! Dieter Edited by di_ch_NY56 2023-02-25 7:32 AM (IMG_1292 361 B windshield molding clips (lower).JPG) Attachments ---------------- IMG_1292 361 B windshield molding clips (lower).JPG (303KB - 64 downloads) | ||
Board Moderator & Exner Expert 10K+ Posts: 13045 Location: Southern Sweden - Sturkö island | Then you must try with Big M Dieter. My photos below shows the clips for a 4DHT - compare with your clips, perhaps they are the same? (Clip Backlight Molding-rez.jpg) (Clip Backlight Molding_1-re.jpg) (Clip Backlight Molding_2-rez.jpg) Attachments ---------------- Clip Backlight Molding-rez.jpg (304KB - 62 downloads) Clip Backlight Molding_1-re.jpg (269KB - 59 downloads) Clip Backlight Molding_2-rez.jpg (155KB - 60 downloads) | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | wizard - 2023-02-24 3:28 PM Then you must try with Big M Dieter. My photos below shows the clips for a 4DHT - compare with your clips, perhaps they are the same? exactly the same size, thanks my friend!
I was looking into the chapter 23, parts book, exactly the same parts number. Edited by di_ch_NY56 2023-02-25 10:17 AM | ||
