another 1960 Chrysler appeared
Jump to page : < ... 10 11 12 13 14 15 16 >
Now viewing page 16 [50 messages per page]
Posted 2023-02-25 10:26 AM (#627834 - in reply to #469368)
Subject: Re: another 1960 Chrysler appeared
5000500020001000100100
Great Dieter, that means that you have more possibilities to find some. Most inportant that the "claws" are still there and not rusted away. Not the best solution as for clips, but it works.
As you can see, my spare clips has been cleaned from rust and been given a fresh galvanizing.
di_ch_NY56
Posted 2023-03-01 11:10 AM (#627967 - in reply to #469368)
Subject: RE: another 1960 Chrysler appeared
100050025
Today a free working day for private affairs...
I had an appointment with the engine builder at the cylinder grinder shop. Discussion about further steps at the engine.
The crankshaft (replacement is grinded and hardened, had a color protection layer and the polished surface is another thing in Switzerland).
Discussion about the engine. For the crack, for sure there is a appropriate technical solution to make it sealed for ever. All exhaust valve seats are beyond cutting (too deep). Hardened rings will be installed. The guides for the valve stems are worn out mainly on the exhaust side. The engine builder will have an eye for valves with an oversized stem.
New words as well. The engine comes to the engine test stand to get it broken in and power/torque measurements over a wide rev range.
Happy Restoration!
Dieter
(IMG_1308 cylinder block bottom view.JPG)
(IMG_1309 cylinder heads.JPG)
(IMG_1307 crack in the block.JPG)
(IMG_1311 crack in the block magnified.PNG)
Attachments IMG_1308 cylinder block bottom view.JPG (332KB - 761 downloads)
Attachments IMG_1309 cylinder heads.JPG (343KB - 762 downloads)
Attachments IMG_1307 crack in the block.JPG (349KB - 715 downloads)
Attachments IMG_1311 crack in the block magnified.PNG (246KB - 635 downloads)
Posted 2023-03-02 3:04 PM (#627992 - in reply to #469368)
As for cracks, look on youtube Dieter. Theres a kit with drilling template and short alu screws.....
here's the link https://www.youtube.com/watch?v=Pq0wfU4ZaKk
di_ch_NY56
Posted 2023-03-03 2:24 PM (#628011 - in reply to #627992)
100050025
wizard - 2023-03-01 9:04 PM As for cracks, look on youtube Dieter. Theres a kit with drilling template and short alu screws..... here's the link https://www.youtube.com/watch?v=Pq0wfU4ZaKk
Thanks Sven
I let the companies working. The boss of the company we met, did propose that solution as well. Another solution could be JB welding.
I did watch the video. The crack in the example seems to be wider than the crack in the block. Nobody knows, if the really thin crack goes fully through the wall. Rember the cracks you and me noticed at the cylinder heads of my Beast...
Posted 2023-03-03 2:47 PM (#628012 - in reply to #469368)
500050005002525
I would cut a groove into it, pre-heat it, & weld it with nickel wire - either that or braze it with brass; but it would take more heat that way.
hemidenis
Posted 2023-03-04 1:30 AM (#628024 - in reply to #469368)
20001000500100100100100
in Argentina it is a guy who weld blocks of tractors and big machinery. He told me something like that, he made the cast iron very hot in a furnace and while hot he weld it. But he keep it hot and gradually bring it to room temperature over a 7 days period...
di_ch_NY56
Posted 2023-03-05 4:32 AM (#628066 - in reply to #469368)
100050025
Thank you for the replays.
I had another idea as well: Muggy Weld. That could work as well.
Happy Restoring!
Dieter
Edited by di_ch_NY56 2023-03-05 4:49 AM
Posted 2023-03-05 10:50 AM (#628070 - in reply to #469368)
Even normal soldering could work, given clean surfaces and use of acid.
My friend and had this discussion long time ago, and one thing was just JB Weld, but with all holes temporary closed and vacuum applyed to the cylinder bank. If the crack goes trough, then the vacuum could suck in JB weld in the crack.
Posted 2023-03-05 10:53 AM (#628071 - in reply to #628024)
hemidenis - 2023-03-04 7:30 AM
This is the serious way of handling with the problem Denis. What the old guys did back then, here in Sweden they used coal bedding, bringing the item up to good heat, then welding it hot. This prevent new cracks to form around the weld - a very common thing to happen if welding cold.
Posted 2023-03-05 11:16 AM (#628072 - in reply to #469368)
500050005002525
Yes, however, with advances in cast iron welding rod, namely using the proper nickel alloy; it's now quite easy to weld cast iron without cracking, and only use a much smaller amount of preheat. My welds here didn't crack and don't leak. I cut and added a whole section to it.
(392 Extended Crossover Welded.jpg)
Attachments 392 Extended Crossover Welded.jpg (123KB - 674 downloads)
Posted 2023-03-05 12:04 PM (#628075 - in reply to #469368)
I saw your work, really nice!
di_ch_NY56
Posted 2023-03-12 12:46 PM (#628209 - in reply to #469368)
100050025
The engine block was initially magnafluxed. I just wonder why this crack they didn't discover. The result I got, was that all cylinder bores are co-centrical with an almost identical bore wall thickness.
One idea... cold welding..
Pontiac engine welding https://www.youtube.com/watch?v=uNwYdFNDlM8
Happy Restoring!
Dieter
Edited by di_ch_NY56 2023-03-12 12:58 PM
Posted 2023-03-12 12:52 PM (#628211 - in reply to #628209)
500050001000100100
di_ch_NY56 - 2023-03-12 9:46 AM
Happy Resotring! Dieter
No fancy formating required to activate the link, just a carriage return on the keyboard.
di_ch_NY56
Posted 2023-04-15 11:49 PM (#628930 - in reply to #469368)
100050025
Yesterday afternoon I did clean the filter cases of my Letter. Of course the covers need a new paint job. The underside of the base plate a surface rust removal and rust inhibiter primer.
Happy Restoring!
Dieter
(IMG_1501 air filter case top view base plate.JPG)
(IMG_1500 air filter case top view.JPG)
Attachments IMG_1501 air filter case top view base plate.JPG (390KB - 581 downloads)
Attachments IMG_1500 air filter case top view.JPG (455KB - 641 downloads)
jwheath68
Posted 2023-04-18 10:40 AM (#628985 - in reply to #469368)
How’s the project coming? Did you find a solution for the block?
di_ch_NY56
Posted 2023-04-19 2:05 PM (#629005 - in reply to #628985)
100050025
jwheath68 - 2023-04-17 4:40 PM How’s the project coming? Did you find a solution for the block?
Hi
Thank you for your question. Nothing new under the sky. No answer from the engine builder nor from the cylinder grinder shop. The last I sent to the cylinder grinder shop is the metal stitching process documented on an engine block (preferred method over two component glue with a CNC-machined plate over the crack).
Happy Restoring!
Dieter
di_ch_NY56
Posted 2023-04-22 4:47 AM (#629048 - in reply to #469368)
100050025
Last Tuesday, or last Tuesday one week ago, I destroyed the top thread (leaking now). No replacement in sight anymore. So the brake system will be unfinished forever...
Happy Restoring!
Dieter
Edited by di_ch_NY56 2023-04-22 4:48 AM
(Brake line Tee 1960.jpg)
Attachments Brake line Tee 1960.jpg (3KB - 657 downloads)
Posted 2023-04-22 6:34 AM (#629049 - in reply to #629048)
500050001000100100
di_ch_NY56 - 2023-04-22 1:47 AM<
Not like you to be so negative Dieter. Of course there are solutions to your problem and probably not for too much $$.
Following your 5-58-1 hint in that tiny tiny image from the 1960 Mopar parts catalogue, I found what I think is the correct PN for the tee on page 5-11 as PN 2123 218.
When I chased 2123 218 in eBay as "2123218 brake line tee", there were no perfect hits but there were some very close ones. Have a look at these and post a photo of your tee:
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2510209.m570.l131...
One example:
Brake Line 3-Port Tee Fitting SAE 3/8-24 Inverted Flare Edelmann 3/16" 3-Way Tee
https://www.ebay.com/itm/122665110171
Hang in there. All is NOT lost
di_ch_NY56
Posted 2023-05-02 2:03 PM (#629287 - in reply to #469368)
100050025
I'm very nervous... so a storm in a water glass did appear.
I'm in contact with John (Big M). The brake tee is not forgotten. sooner, or later I gonna get it. Big thanks to you John.
Happy Restoring!
Dieter
samstrader
Posted 2023-05-10 4:09 PM (#629438 - in reply to #469368)
Amazing welding cast iron Nathan.  I didn't know that could be done yet.  I thought only brazing worked which wasn't all that strong.  I'm sure glad to know about this.  There are opportunites for me on this.
Thanks for showing this.
di_ch_NY56
Posted 2023-05-17 2:28 PM (#629620 - in reply to #469368)
100050025
There is a professional cast iron welder in Germany, who restored the exhaust manifold with one broken mounting ear (to the exhaust system). He welds the Mercedes Benz truck engine with imperfections from the casting process. I did a proposal mail to the engine builder and cylinder grinder. But no answer so far....
IVG Reviguss GmbH
Thomas Tscherneschek
Am Steinfeld 3 - 5
91592 Buch am Wald
Deutschland
Happy Restoring!
Dieter
di_ch_NY56
Posted 2023-06-04 2:26 AM (#629976 - in reply to #469368)
100050025
The main brake cylinder is back together (intended was to install the boot correctly). Of course I know that work had to be done prior to mount the brake cylinder to the reinforcement plate....
To mount the collar with the boot again, I had to release the brake pressure through the brake cylinder at the passenger side rear wheel. Of course I did open the bleeding screw too ways (should be 1/4 of a 360 degree turn). In comparison to the New Yorker (Beast) the wheels were not mounted wile replacing all wheel cylinders.
Sometimes, of often, I feel overstrained while restoring that car.
Happy Restoring!
Dieter
(IMG_1693 main brake cylinder.JPG)
(IMG_1694 release brake pressure.JPG)
Attachments IMG_1693 main brake cylinder.JPG (185KB - 680 downloads)
Attachments IMG_1694 release brake pressure.JPG (302KB - 644 downloads)
di_ch_NY56
Posted 2023-06-18 3:44 AM (#630278 - in reply to #469368)
100050025
The brake sytem is basically bleeded now. Some air bubbles are still in the system, with a geysir in the main brake cylinder pot when applying the brakes with my left hand, while inspecting the pot through the open windshield opening.
Full air extraction later on when the passenger floor is protected.
Happy Restoration!
dieter
di_ch_NY56
Posted 2023-07-08 9:30 AM (#630662 - in reply to #469368)
100050025
The dashboard is at the body and paint shop again for the charcoal part repainting job. Ready during August 2023.
Engine: absolutley bad story. Nothing did happen so far
Even though the amount is ready on my account for years.
I assume mostly due to a talk of a member here to the engine builder boss. A black painting on me forever. He shot directly into my back.
I do not forgive, I do not  want to talk to that person anymore.
The rumour the engine builder did mention at the visit of the cylinder grinders job was "he has no money, we will wait until he saved some money"!
Happy Restoring!
Dieter
di_ch_NY56
Posted 2023-07-16 7:33 AM (#630792 - in reply to #469368)
100050025
News about the engine block. I got a call from the engine builder last week. He went to the Gussschweisser homepage and did agree with a professional repair of the engine block crack.
This morning I wrote to the company (Gusschweisser.de) to ask if they would be open at July, 31st, 2023.
There are two options I'm thinking about now.
a) picking up the engine block at the cylinder grinders and bring it to Germany on the same day (July 31st)
b) picking up the engine block on July, 29th this year and store it over the weeking in my daily driver to start early on the Monday to drive 335 km one way from my home to bring the engine block to Germany (Buch am Wald).
Happy Restoring!
Dieter
hemidenis
Posted 2023-07-16 9:40 AM (#630798 - in reply to #469368)
Darn I missed the whole engine saga. What a pain in the neck, apparently engines rebuilders are the same around the world, they don't even consider making things right to a customer living in another country.
di_ch_NY56
Posted 2023-07-31 5:04 AM (#631050 - in reply to #630798)
100050025
hemidenis - 2023-07-15 3:40 PM Darn I missed the whole engine saga. What a pain in the neck, apparently engines rebuilders are the same around the world, they don't even consider making things right to a customer living in another country.
The whole saga did turn another way. I got a mail from the wife of the professional cast iron welder in Berg am Wald in Germany. No appointment available for a not definded time due to the reason the welder is on duty actually.
I did a phone call to the engine builder to inform and propose "metal stitching method" as an alternative. We did agree to wait to what will happen to the professional cast welder (most probably a health issue).
Happy Restoring!
Dieter
Posted 2023-07-31 11:55 PM (#631068 - in reply to #631050)
20001000500100100100100252525
I don’t know if you’re looking to replace your engine, but a ‘60 Imperial 413 just came available for a cheap price. Might be a rebuildable core? Not mine, just want to help.
https://www.facebook.com/groups/ForwardLook/permalink/10159926237314...
22mafeja
Posted 2023-08-01 2:16 AM (#631069 - in reply to #469368)
5001001002525
I am suffering with you Dieter. I don`t tell you what to do here , I am just telling you what I would consider. Make a cover plate out of soft copper sheet hammering it to fit over the whole
freeze plug hole and attaching it to the cylinderblock with a number of M5 12.9 machine screws. When the copper is formed to fit you put enough 260 deg celsius silicone on the block and
screw it down evenly so the silicone comes out all around the cover. Sweep off the extra material and carefully wash the edges. Of course you first of all have to put a stop screw at the absolute end of the crack.Copper can be painted with epoxy as primer.
I mention this since I have done this once 30 years ago and still today it is not leaking. This I know since I still use the tractor it was done to.
It is frankenstein thinking yes but hey these are still cars aren`t they and your youth is ticking away Dieter.
Posted 2023-08-01 5:56 PM (#631090 - in reply to #469368)
I've never seen a cast iron weld that lasted. That doesn't mean it is not possible, BUT in such an application, were you spend many thousands of Euros and many, many hours into a block, you should be 100% sure.
Given the fact, that there is no numbers matching block, only a vague time matching and that the 300 blocks were regular 413 New Yorker/Imperial blocks, I'd get a parts car with a good 413. I will buy the 8.3/4 from you then, if its not an Imp
di_ch_NY56
Posted 2023-12-29 8:07 AM (#633198 - in reply to #469368)
100050025
Two times verified that nearby is a good, professional cast iron welder (oldtimer engine blocks and heads, and more)
Over the last two afternoons I replaced the master brake cylinder. Easy to replace and all is sealed again. At the pedal now pressure builds up (few air bubbles went out of the reservoir,I guess that's normal).
Not easy, but I managed to get the front wheels off as well (heat gun) - no wonder the center hole and the flange at the brake drum must be clean, with no color on it. Now I have to look for a person who holds the brake pedal downl (or a bag with snow chains) to start bleeding.
(IMG_2511 brake systen ready for bleeding.JPG)
Attachments IMG_2511 brake systen ready for bleeding.JPG (259KB - 624 downloads)
Posted 2023-12-29 10:06 AM (#633199 - in reply to #469368)
Nice to see your posts again Dieter! Since you don't have the dashboard mounted it should be easy to put in a wooden wedge somewhere on the pedal fulcrum.
You can bleed the brakes by first open a bleeder, press down the pedal, insert suitable wooden wedge, tighten the bleeder, remove the wedge. Repeat as needed. This is how I do it when I dont have any helper available.
Takes longer time, but works......
di_ch_NY56
Posted 2023-12-30 11:36 AM (#633211 - in reply to #633199)
100050025
wizard - 2023-12-28 4:06 PM Nice to see your posts again Dieter! Since you don't have the dashboard mounted it should be easy to put in a wooden wedge somewhere on the pedal fulcrum. You can bleed the brakes by first open a bleeder, press down the pedal, insert suitable wooden wedge, tighten the bleeder, remove the wedge. Repeat as needed. This is how I do it when I dont have any helper available. Takes longer time, but works......
Thanks my friend, I guess I need one more bottle of DOT4-Brake fluid... Most probably next week. Happy New Year 2024 for you and your family.
Edited by di_ch_NY56 2023-12-30 11:37 AM
di_ch_NY56
Posted 2024-01-05 5:14 AM (#633298 - in reply to #469368)
100050025
The brake are bled, the rear brake pads adjusted.
di_ch_NY56
Posted 2024-04-02 7:05 AM (#634500 - in reply to #469368)
100050025
Last week I had a phone call the the employee of the cyinder grinder company (where the block, the crankshaft, both cylinder heads and the rotating assembly are sitting now).
I did fully agree with the metal stitching method for the crack in the engine block. Furthermore I said, please clean the other side of the block as well to check for a crack as well.
I did inform the engine builder. No anser so far. He (the engine builder) was hanging on the idea, that I gonna seek for a better 413 engine block. My answer was just (in the mail) it's like seeking for a needle in a haystack.
Happy Restoring!
Dieter
ToMopar
Posted 2024-04-03 3:02 AM (#634519 - in reply to #469368)
10001001002525
Dieter, don't give up to convince the engine builder that he should do his job
di_ch_NY56
Posted 2024-04-15 8:03 AM (#634705 - in reply to #469368)
100050025
Thanks to MoPar
Now longer ago I got 12 clips for the moulding (surrounding windshield and rear window). The ones are smaller (I assume for the windshield) the others are bigger (I assume for the rear window). The bigger clips I just have three rusted clips. But double amount of the smaller clips.
See picture....
(IMG_3035 window moulding clips.JPG)
Attachments IMG_3035 window moulding clips.JPG (382KB - 629 downloads)
Posted 2024-04-15 11:58 AM (#634707 - in reply to #469368)
Dieter, ask Carlo Notaro, he might have some https://www.facebook.com/notaro.se/
di_ch_NY56
Posted 2024-04-16 1:24 AM (#634717 - in reply to #634707)
100050025
wizard - 2024-04-14 5:58 PM Dieter, ask Carlo Notaro, he might have some https://www.facebook.com/notaro.se/
Thanks Sven I'm in contact with John.
sermey
Posted 2024-08-06 3:26 PM (#636437 - in reply to #634500)
di_ch_NY56 - 2024-04-02 1:05 PM
Happy Restoring!
Dieter
Dieter: Your engine builder is absolutely right. There are engines block 413 available. But not seeking in a haystack. Purchase and forget this mess!  - SERGE - ;)
22mafeja
Posted 2024-08-10 2:14 AM (#636478 - in reply to #469368)
5001001002525
Dieter , I know where to purchase a 63 413 good running engine. Would that be of interest? If so I can ask for price and proof of former repairs ...
22mafeja
Posted 2024-08-10 3:38 AM (#636479 - in reply to #469368)
5001001002525
The engine is located in Finland so I guess the shipping would be 300-400e.
di_ch_NY56
Posted 2024-10-13 1:48 AM (#637367 - in reply to #469368)
100050025
Thanks for your offers for a replacement engine. I'm affraid, no other engine to replace the my engine, currently at the engine restoring company, not Buttwil AG. I do not want to pay the ultrasonic, cleaning the block, the grinding, boring, honing again.
But what I got is a set of 6 side windowns (solex glass). The main issue is the vent window frame (on the driver side the extension for the adjusting screw is broke off since the beginning of the menbership of that car).
Might be that a friend located in Switzerland will help with that sub project, next winter.
Thanks a lot
di_ch_NY56
Posted 2026-03-23 9:06 AM (#643117 - in reply to #469368)
100050025
Ready to mount are the inner front fenders and the carrier of the hood lock.
With the radiator yoke and the outer fender mounted, the inner fender are impossible to mount.
When the inner front fenders are mounted, I could mount all electric hardware, the brake parts, the vacuum parts inside the inner left fender.
At the rh front wheel brake drum I have the check the link between both one action brake cylinders.
In a dream I got an idea of how the mount the dash board alone - almost impossible.
I sent a sharp email to the engine builder (basically): If you do not agree with metal stitching, there will be a time when I set a dead end to get the final bill and all parts resting at the engine builder to find a new engine builder. basically I could keep the contact to the engine grinder. Last phone call (3/2024): The quite experieced mechanic at the engine grinder did agree with metal stitching. I did note the other side to check as well.
Then I need a solution to the lh vent window frame (the lower adjusting screw holder was broken off, when I did remove it from the drivers door. A skilled mechanic nearby could potentially find a solution to sovle that problem (white metal).
di_ch_NY56
Posted 2026-03-24 11:45 AM (#643124 - in reply to #469368)
100050025
Yesterday evening I got a phone call of the Heinz, the owner of the engine grinder shop. The cylinder heads both are ready. He'll purchase a new metal stitching set to repair my block. We did fix an apointment. April 30iest I'm going to visit the engine grinder shop. I'll take the breather tube and the oil measure stick set with me.
Kind regards
Dieter
Posted 2026-03-24 4:53 PM (#643128 - in reply to #469368)
Dieter, a friend built a wooden platform for to support the dashboard. He manager to mount the dashboard without help. Don’t forget to mount the windlace first, it’s mounted with clips under the sides of the dashboard.
di_ch_NY56
Posted 2026-03-25 3:28 PM (#643136 - in reply to #643128)
100050025
wizard - 2026-03-23 10:53 PM Dieter, a friend built a wooden platform for to support the dashboard. He manager to mount the dashboard without help. Don’t forget to mount the windlace first, it’s mounted with clips under the sides of the dashboard.
Thanks, Wizard could you do a favor for me (send a picture)?
Posted 2026-03-25 4:36 PM (#643137 - in reply to #469368)
I don’t have that Photo Dieter, I’ll try to give more info via email
