New User
| Good evening, Name is Cory McDowell and I just started my own business here in Schweinfurt Germany. I have a customer that came in with a '55 Dodge Royal Lancer and the drum / hub assembly is bent. It looks as if previous mechanics tried to beat the drum off. I on the other hand used the puller. Any ways, is there a possibility to find a set or any at all. I am not trying to separate the drum from the hub as I noticed that the studs are swaged. Any help would be greatly appreciated. Thanks. By the way love the Forum! |
Location: Eastern Iowa | Which side are we talking about here?
Am I correct to assume this is a rear drum??
Location: Michigan | I have Chrysler drums... off the hubs. This isn't hard to do by the way. You just need new studs. I am not sure if my drums would work though for the Dodge. I will double check the size, but I am pretty sure they are 11x2. or 11x2.5
New User
| Yes it is a rear drum.
If I could get the drum and hub together that would be great as I need both. |
Location: bishop, ca | Cory, these two threads should give you all the information that you will need, for your problem:
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=57250&...
And this one:
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=57230&...
Edited by d500neil 2015-04-27 2:55 AM
