1957 Plymouth power steering column grommet.
The Chrysler Kid
Posted 2015-08-04 8:06 PM (#486277)
Subject: 1957 Plymouth power steering column grommet.
1000100100100252525
Does anyone reproduce it? Where can I find it?
Posted 2015-08-04 9:19 PM (#486287 - in reply to #486277)
Subject: Re: 1957 Plymouth power steering column grommet.
50001000100100100100252525
Page 2
http://www.garygoers.com/cat10A.pdf
JT Vincent
Posted 2015-08-14 12:36 AM (#487093 - in reply to #486277)
Or you could save money and buy a used one, or even better-- make one. Do make sure the seal is good. Blow-by (and potentially exhaust) can get sucked through that hole and make you pass-out when you and your car are at speed. Whatever you do, don't leave the column to firewall opening unsealed. Danger, Will Robinson.
FURY
Posted 2015-09-09 7:01 PM (#489345 - in reply to #486277)
Subject: RE: 1957 Plymouth power steering column grommet.
100025
I have a friend who has a nos rubber piece for sale, that goes over the carpet/around the steering column at the floor if that's any help.
Glenn.
