1961 413 Manifold
Zak
Posted 2015-11-15 4:56 PM (#495263)
Subject: 1961 413 Manifold
Is there anything unique about a 1961 413 manifold that makes it different from later model years? I usually see them listed as 62-66 model years.
Thanks.
Zak
Posted 2015-11-16 2:11 PM (#495365 - in reply to #495263)
Subject: RE: 1961 413 Manifold
200010005001001002525
The casting numbers are different so they're only listed for a particular year span. There might be physical differences like mounting bosses.
Zak
Posted 2015-11-17 7:29 AM (#495416 - in reply to #495263)
Subject: Re: 1961 413 Manifold
Thank you.
Rodger
Posted 2015-11-25 10:53 AM (#496158 - in reply to #495263)
1000500
Hola Zak
If one Exhaust Manifold has nothing other than Mounting Holes --- it is one Part Number,
If it has an un-used "boss" --- it has its Part Number,
Add a hole of any type into "The Boss" --- it has its Part Number.
The Left and Right Exhaust Manifolds are an example of this because The Right has a "Flapper".
Some where in the 1965'ish area - the length of The Dumping Portion of MoPar's Big Block Exhaust Manifolds was extended ( every Raised Block Engine uses the same Part Number ).
Rodger & Gabby
COS
