DUI Ignition
canyouheminow
Posted 2015-12-24 8:49 AM (#498933)
Subject: DUI Ignition
Has anyone tried this distributor before and how do you like it?
http://performancedistributors.com/product/dodge-small-block-dui-di...
It sounds good with the higher 55 gap and custom advance curve.
StillOutThere
Posted 2015-12-24 9:47 AM (#498936 - in reply to #498933)
Subject: Re: DUI Ignition
2000100010010025
Interesting !
58coupe
Posted 2015-12-24 10:10 AM (#498940 - in reply to #498933)
100050010010025
I am not sure their standard unit will fit a 57-58 Plymouth but their Tri-power unit will. The only advantage I can see over a Chrysler electronic ignition is they will set it up for your engine specs. before shipping.
Polybun
Posted 2015-12-24 12:48 PM (#498948 - in reply to #498933)
Subject: RE: DUI Ignition
Temporarily suspended to cool off
don't like HEI, advance weights are too light, the curve is unstable, really only works on drag setups in my opinion. NOW, if that thing has programable electronic curve control, then it probably works pretty well. But, for a bit more you could have an MSD distributor, and you get to move the coil away from the engine heat. Myself, I'll just use a chrysler distributor that gives a good reliable advance curve.
1961plymouthfury
Posted 2016-03-17 9:11 AM (#507116 - in reply to #498933)
200050010025
It would not be a bad idea. I knew some who was hit head on by an 18 year old drunk and died at the scene. I knew the victim since she was little . The incident happened back in 1997 in Palm Bay, FL . I found out about it when I read about it in the Florida Today Newspaper and it hit me really hard.
I do not drink but if I do and I had too much will not get behind the wheel of a motor vehicle. I will stay were I am at until it wears off.
canyouheminow
Posted 2016-03-17 9:36 AM (#507125 - in reply to #498933)
????????????????? DUI stands For Davis Unified Ignition
wayfarer
Posted 2016-03-17 4:20 PM (#507153 - in reply to #498933)
500100100100252525
...I really don't like that I can't post a emogi on the reply cause it really needs one.....
Edited by wayfarer 2016-03-17 4:22 PM
1961plymouthfury
Posted 2016-03-18 2:03 PM (#507226 - in reply to #507125)
200050010025
Ok I thought it stood for driving under the influence
