360 rebuild installed
Moderators: big m
   Forward Look Local Regions -> Pacific Northwest RegionMessage format
59 in Calif
Posted 2016-02-24 8:20 PM (#505096)
Subject: 360 rebuild installed
Hey guys, Finally got that 360 put back together. Those 9.3 pistons not leaving much area left in the combustion chamber at top dead. They put a pretty healthy valve relief in the top of those pistons. If my measurements are correct, I should have well over .100" clearance. KB recommended a minimum of .080". Got the eng installed and am hooking up all the 'stuff'. Rechecked the dr. line angle and still holding at 4 degrees. Picked up the dist. from the shop today ( had the adv. recurved ) and set it in place. I'l get started on throttle linkage tomorrow. Jerry
(360 rebuild 001.jpg)
(360 rebuild 002.jpg)
(360 rebuild 003.jpg)
(360 rebuild 004.jpg)
(360 rebuild 005.jpg)
(360 rebuild 006.jpg)
Attachments 360 rebuild 001.jpg (87KB - 293 downloads)
Attachments 360 rebuild 002.jpg (95KB - 309 downloads)
Attachments 360 rebuild 003.jpg (97KB - 304 downloads)
Attachments 360 rebuild 004.jpg (142KB - 310 downloads)
Attachments 360 rebuild 005.jpg (152KB - 301 downloads)
Attachments 360 rebuild 006.jpg (128KB - 325 downloads)
big m
Posted 2016-02-25 5:26 PM (#505184 - in reply to #505096)
Subject: Re: 360 rebuild installed
50002000500100100100
Looks like you're coming along nicely, Jerry!!
Keep up the good work!!
59 in Calif
Posted 2016-02-25 8:29 PM (#505193 - in reply to #505096)
Thanks, John ! Seems like it took a long time getting it put back together. Had a couple obstacles to overcome, but finally got them worked out. Jerry
60 dart
Posted 2016-02-26 12:09 AM (#505225 - in reply to #505096)
50002000100050010010010010025
lookin real purdy--------------------------------------later
