| Anyone know where I can purchase a pair (left and right) of those small trim caps that cover the seam where the stainless meets above each headlight? Preferably NOS or mint. Thanks, Clark
goodtoothdoc@yahoo.com (315) 637-1189 |
According to the factory parts manual they changed mid year, the early used the same cover left/right but later versions had a different one on each side. Part number for the early is 1686358.
Collector's Auto Supply shows at least one.
http://www.collectorsautosupply.com/query.asp?make=Mopar&year=0&sec... |
| THANKS FOR THE INFO. MY 57 CORONET HAS CHROME CAPS AND NOT STAINLESS. THEY APPEAR TO BE DIFFERENT ON EACH SIDE. I WONDER IF I COULD JUST SUBSTITUTE FOR THE STAINLESS KIND THAT YOU LOCATED. ANY THOUGHTS? THANKS, CLARK |
I would imagine that the type that fits both sides has the screw hole centered while the others have the screw hole either to the left or right of center. Might be able to redrill the screw hole in the eyebrow...dunno. |
Location: Hay Lakes, Alberta, Canada | Would you have a picture of the caps? I have a '57 "Plodge" here that I am parting out...and the caps may be the same. |
