325 57 poly engine Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Forward Look Swap Meet -> For Sale - PARTS | Message format |
Expert 5K+ Posts: 5006 | Anyone interested in a 57 325 poly? It is froze up. so will need bored out. I can sell just the heads also if anyone is interested in those. Edited by mikes2nd 2016-09-03 12:25 AM | ||
DepsilonD |
Elite Veteran Posts: 792 Location: Buena Park, CA | I would be potentially interested in the camshaft if you end up parting the motor out. And would consider the heads but shipping could be a killer. -Dave | ||
Expert 5K+ Posts: 9665 Location: So. Cal | I need a 4bbl intake. | ||
Expert 5K+ Posts: 5006 | Parting out the engine. Its a 2 barrel carb car. Complete. Cam is sold so far | ||
wayfarer |
Elite Veteran Posts: 888 Location: Peoples Republic of Oregon | where are you located? | ||
Expert 5K+ Posts: 5006 | I am in ohio | ||
samdjr74 |
Veteran Posts: 109 | Mike, do you have a good water neck/thermostat housing? | ||
Expert 5K+ Posts: 5006 | Yeah, I am about to yank it apart this weekend So far sold (heads), cam/fuel pump. | ||
evrydahero |
Member Posts: 44 | Mike I see you are in ohio, me too. I have a 58 belvedere looking for some body parts, you know of anyone around ohio? | ||
samdjr74 |
Veteran Posts: 109 | Mike, I sent you a PM | ||
Expert 5K+ Posts: 5006 | this thing came apart amazingly easy. I was able to take the pipes off the headers...
this must be some kind of arizona car, its got a protective crust of oil and dirt on it, every bolt ive taken off comes of easily.
Edited by mikes2nd 2017-01-22 11:03 PM (325Dodge.jpg) Attachments ---------------- 325Dodge.jpg (235KB - 168 downloads) | ||
Expert 5K+ Posts: 5006 | Cam, fuel pump sold. Available (heads, headers, water pump housing/crossover, intake/carb, timing cover. I wont know if crank is good till later but I expect its fine. Low wear/miles on this engine (intake57dodge325.jpg) (water57dodge2.jpg) (water57dodge1.jpg) Attachments ---------------- intake57dodge325.jpg (242KB - 152 downloads) water57dodge2.jpg (245KB - 144 downloads) water57dodge1.jpg (246KB - 157 downloads) | ||
Expert 5K+ Posts: 5006 | valve covers also. (325Poly.jpg) Attachments ---------------- 325Poly.jpg (247KB - 149 downloads) | ||
RUSTORICHES |
Extreme Veteran Posts: 494 Location: Alberta | How about the bracket for the air cleaner? or do you want to sell that complete with the valve covers. I am interested either way it's up to you Edited by RUSTORICHES 2017-01-29 8:00 PM | ||
Expert 5K+ Posts: 5006 | Heads are available. I need to check on that bracket. I may need. | ||
Tulsai |
New User Posts: 2 Location: Moscow, Russia | Hi. I need for my 325 poly engine: 1. Rocker arm mounting studs and nuts (for two heads), 2. Intake push rods, 3. Exhaust push rods, 4. Thermostatic coil spring, 5. Cross-over choke assembly, 6. Choke rod, 7. Choke clip, 8. Exhaust gas crossover passage bolts (with 12 faces head). By the way. I also need: 9. Gearbox (PowerFlite) mounting bolts, 10. Speedometer cable, 11. Ignition lock with key(s), 12. Dome light. If something is available, please, let me know prices. Thank you in advance for answer. Edited by Tulsai 2017-02-26 2:34 PM | ||
elimontfort |
Regular Posts: 58 | Hi I was wondering if the oil pan is still available? it should fit a 315 correct? | ||
Expert 5K+ Posts: 5006 | oil pan is a mess... but available, if you want it for 50$ plus shipping let me know quick. It is covered in thick dried oil... This car was rustproofed by a leaking front seal I have rods, crank, 6 pistons... If someone wants the block in NE ohio, let me know quick... | ||
