'55 Plaza Suburban arrives today Jump to page : < 1 2 3 4 5 6 7 8 ... > Now viewing page 3 [50 messages per page] | View previous thread :: View next thread |
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | The Gabriel was about 3/64" larger in diameter than the stock shock. The recommendation I found elsewhere on this site was to get the KYB shocks for the mid-'70s 'vette. The Gabriels were cheaper, so I went with them. I suspect they may be slightly larger than the KYBs. I don't know if there's a difference in the 6 and 8 cylinder car lower control arms. But, it was only a few seconds work with the Dremel to slip the new shock through. | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | Here's the shock in the car. (Plaza shock installed.jpg) (Plaza Gabriel box top.jpg) Attachments ---------------- Plaza shock installed.jpg (94KB - 397 downloads) Plaza Gabriel box top.jpg (64KB - 416 downloads) | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | Today, I pulled out the old single master cylinder and started on installing the new dual master cylinder. Had to make a gasket for the firewall. The pushrod was way too long. Fortunately, the original pushrod is adjustable. I had to polish off the corrosion to get it to fit into the '70s A-body MC I'm using. (Plaza MC new.jpg) (Plaza MC gasket.jpg) (Plaza MC pushrod.jpg) (Plaza MC installed.jpg) (Plaza MC installed2.jpg) Attachments ---------------- Plaza MC new.jpg (131KB - 415 downloads) Plaza MC gasket.jpg (156KB - 392 downloads) Plaza MC pushrod.jpg (108KB - 404 downloads) Plaza MC installed.jpg (131KB - 396 downloads) Plaza MC installed2.jpg (132KB - 411 downloads) | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | Probably re-plumbing the brake system just in time. (Plaza brake hose.jpg) (Plaza distribution block old.jpg) (Plaza distribution block old2.jpg) Attachments ---------------- Plaza brake hose.jpg (90KB - 392 downloads) Plaza distribution block old.jpg (118KB - 408 downloads) Plaza distribution block old2.jpg (114KB - 397 downloads) | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | Master cylinder label. (Plaza MC label.jpg) Attachments ---------------- Plaza MC label.jpg (104KB - 388 downloads) | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | Got the master cylinder and distribution valve plumbed today. (Plaza MC lines.jpg) (Plaza distribution valve and lines.jpg) Attachments ---------------- Plaza MC lines.jpg (152KB - 395 downloads) Plaza distribution valve and lines.jpg (128KB - 398 downloads) | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | The notch on the top of the mounting flange of the newer master cylinder left a part of the hole in the firewall for the old master cylinder uncovered. I dug out a piece of aluminum sheet I had and made a plate and gasket to go between the new master cylinder and firewall plate. (php5KeOdlPM.jpg) (Plaza alum plate.jpg) (Plaza alum plate2.jpg) (Plaza alum plate gasket.jpg) (Plaza alum plate3.jpg) (php4dGIp5PM.jpg) Attachments ---------------- php5KeOdlPM.jpg (165KB - 390 downloads) Plaza alum plate.jpg (198KB - 402 downloads) Plaza alum plate2.jpg (78KB - 408 downloads) Plaza alum plate gasket.jpg (135KB - 385 downloads) Plaza alum plate3.jpg (106KB - 394 downloads) php4dGIp5PM.jpg (143KB - 394 downloads) | ||
Expert 5K+ Posts: 9666 Location: So. Cal | For the life of me, I can't figure out why Chrysler put that blasted notch there in the end of the master. Even on the '73 Dart where this master was used, it seems bad. I believe that they just covered the hole with a foam gasket originally. | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | Pulled out the 6V wiper motor and installed a 12V I got from Big M. Externally, the units are almost identical. Other than the markings, the 6V has a double ground strap to the mounting bracket and the 12V a single. (Plaza 6V wiper motor.jpg) (Plaza 12V wiper motor.jpg) Attachments ---------------- Plaza 6V wiper motor.jpg (122KB - 398 downloads) Plaza 12V wiper motor.jpg (143KB - 402 downloads) | ||
throwinwrenches |
Member Posts: 43 Location: Peoria< IL | 71charger_fan - 2017-04-11 10:54 AM The Gabriel was about 3/64" larger in diameter than the stock shock. The recommendation I found elsewhere on this site was to get the KYB shocks for the mid-'70s 'vette. The Gabriels were cheaper, so I went with them. I suspect they may be slightly larger than the KYBs. I don't know if there's a difference in the 6 and 8 cylinder car lower control arms. But, it was only a few seconds work with the Dremel to slip the new shock through. I can an also weigh in here. I believe the control arms are different. I did the same thing as you did, I ordered the Gabriels and tried to fit them without any luck. The tube is slightly larger, and I didn't want to grind anything so I sent them back and bought some KYB's. They fit perfectly. Looks like those were the originals you removed. Very cool to see. | ||
throwinwrenches |
Member Posts: 43 Location: Peoria< IL | You make things look easy. Nice work updating things. Are you keeping your old front and rear brake hub / drums? | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | I offered the fronts up to my Chrysler Products Owners Club membership, but have gotten no takers. I'm keeping the rear drums. If you need the fronts, you can have them. Just pay shipping or I can bring them to Chrysler Carlisle. They're 10" for the three-bolt knuckles. Also the master cylinder. It had some sludge in it, but the car stopped, so it was working. Edited by 71charger_fan 2017-04-20 7:05 PM | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | I looked in the parts book and 1955 to 1956 Plymouths and Dodges, both 6 and 8 cylinder cars, used the same lower control arms, part nos. 1615 108 (right) and 1615 109 (left). Maybe there were variances from vendor to vendor or even different stamping dies. | ||
Expert 5K+ Posts: 9903 Location: Lower Mainland BC | 71charger_fan - 2017-04-21 12:28 PM I looked in the parts book and 1955 to 1956 Plymouths and Dodges, both 6 and 8 cylinder cars, used the same lower control arms, part nos. 1615 108 (right) and 1615 109 (left). Agree. (55-56FrontSuspensionPartsDiagram.jpg) (55-56FrontSuspensionPartsControlArmPNs_1.jpg) (55-56FrontSuspensionPartsControlArmPNs_2.jpg) Attachments ---------------- 55-56FrontSuspensionPartsDiagram.jpg (202KB - 416 downloads) 55-56FrontSuspensionPartsControlArmPNs_1.jpg (264KB - 415 downloads) 55-56FrontSuspensionPartsControlArmPNs_2.jpg (267KB - 404 downloads) | ||
Old Ray |
Extreme Veteran Posts: 507 Location: Invermere B.C. Canada - Rocky Mountains | ........................or maybe it's the shock manufacture? | ||
throwinwrenches |
Member Posts: 43 Location: Peoria< IL | 71charger_fan - 2017-04-20 6:03 PM I offered the fronts up to my Chrysler Products Owners Club membership, but have gotten no takers. I'm keeping the rear drums. If you need the fronts, you can have them. Just pay shipping or I can bring them to Chrysler Carlisle. They're 10" for the three-bolt knuckles. Also the master cylinder. It had some sludge in it, but the car stopped, so it was working. Thanks for the offer, 71charger_fan. I may take you up on it. Any idea what shipping would be to 61614? Thank you! | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | Depends on the weight. I don't know how much all that weighs, but it's a lot of steel/iron. | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | Got the steering wheel back on. I'm waiting on some tie rod ends. The grease seals on mine look like they failed decades ago. Getting the horn switch back together was a huge pain as the rubber isolators had come apart. I had to stick them all together with black RTV and wait a day for it all to set up before I could turn the horn button over and attach it to the wheel. (Plaza Steering Wheel Installed.jpg) (Plaza Brake Line Wheel Well.jpg) (Plaza Bearing Boxes.jpg) Attachments ---------------- Plaza Steering Wheel Installed.jpg (140KB - 381 downloads) Plaza Brake Line Wheel Well.jpg (157KB - 386 downloads) Plaza Bearing Boxes.jpg (115KB - 377 downloads) | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | The upper hatch is held to the hinges with 1/4" bolts. One of which was broken off. Yesterday was a good day as I rarely have any luck extracting broken bolts. Edited by 71charger_fan 2017-04-27 8:56 AM (Plaza broken bolt.jpg) (Plaza broken bolt out.jpg) Attachments ---------------- Plaza broken bolt.jpg (112KB - 374 downloads) Plaza broken bolt out.jpg (97KB - 370 downloads) | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | The upper gate on the wagon latches to the lower with two rotating latches operated by twisting the central handle. One of the latches didn't work and a previous owner had put tape over it. I pulled the latch assembly and found a broken rivet. I used a socket and punch to remove the piece of broken rivet from the actuating arm but had to drill a hole in the latch assembly to get to drill out the piece of rivet in the latch piece. I filed down the head of a #10 screw and worked it through the actuator arm and latch piece. By dumb luck, the screw head is off center of the hole I drilled, so it doesn't have a clear path to work it's way out. I'm hoping this will be a good enough fix for how little the car will be used. I don't want to have to drill out all the rivets and take the mechanism completely apart. (Plaza latch broken rivet.jpg) (Plaza latch rivet removed.jpg) (Plaza latch hole drilled.jpg) (Plaza latch screw installed.jpg) Attachments ---------------- Plaza latch broken rivet.jpg (126KB - 385 downloads) Plaza latch rivet removed.jpg (129KB - 401 downloads) Plaza latch hole drilled.jpg (121KB - 379 downloads) Plaza latch screw installed.jpg (111KB - 383 downloads) | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | Pulled the rear shocks today. The shocks and the nuts at the upper mounting points both had undercoating on them. Again, I think they might have been 1955 originals. (Plaza rear shock old.jpg) (Plaza rear shock old_new.jpg) Attachments ---------------- Plaza rear shock old.jpg (114KB - 397 downloads) Plaza rear shock old_new.jpg (119KB - 379 downloads) | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | The Gabriel Guardian shocks I bought for the rear were somehow manufactured with different bushings from one shock to the other. The holes in the bushings of one shock were just enough smaller that the shock wouldn't slip over the mounting studs. It was too much trouble to return that shock for a replacement. I removed the upper mounting stud from the car and pressed it into the shock on the bench and was able to pound the lower bushing on just enough that the threads of the nut caught and I pushed it on the rest of the way with the nut and washer. | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | I bought a clutch/brake pedal set only to find out that, while they look the same, they are not the same. The clutch pad fits over the end of the pedal, but the brake pad is molded to the pedal. So, I found an NORS brake pedal pad which arrived today. (Plaza Brake Pad Front.jpg) (Plaza Brake Pad Back.jpg) Attachments ---------------- Plaza Brake Pad Front.jpg (110KB - 380 downloads) Plaza Brake Pad Back.jpg (114KB - 375 downloads) | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | I finally got the right side tie rod out today. The old grease was rock hard and took a lot of chipping and WD40 to finally get the ends out. One wasn't too bad, but the other required the bench vise and a large pipe wrench. (Plaza Tie Rod Ends.jpg) Attachments ---------------- Plaza Tie Rod Ends.jpg (115KB - 383 downloads) | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | New tie rod ends are in and many layers of rock-hard crud scraped off the sleeves. (Plaza tie rod ends new.jpg) (phpl9t0H0AM.jpg) Attachments ---------------- Plaza tie rod ends new.jpg (124KB - 381 downloads) phpl9t0H0AM.jpg (112KB - 371 downloads) | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | Since I've replaced every other moving part in the brake system, I figured I'd better also take a look at the rear wheel cylinders. I'm glad I did. I've only gotten as far as the passenger side, but there was so much rust in that wheel cylinder, I'm sure those pistons haven't moved in years. (Plaza rear brakes.jpg) (Plaza rear brakes old whl cyl.jpg) (Plaza rear brakes new wh cyl.jpg) Attachments ---------------- Plaza rear brakes.jpg (157KB - 385 downloads) Plaza rear brakes old whl cyl.jpg (122KB - 370 downloads) Plaza rear brakes new wh cyl.jpg (134KB - 380 downloads) | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | New rear shocks installed. (Plaza rear shocks.jpg) Attachments ---------------- Plaza rear shocks.jpg (111KB - 385 downloads) | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | I found an NOS back up lens to replace the lesser of the two on the car. I'm still looking for another NOS back up lens and one turn signal/parking lamp lens. I have an NOS '56 parking lamp lens and am considering just drilling two holes through that and using it. (Plaza back up lenses.jpg) (Plaza back up lens new.jpg) (Plaza back up lens2.jpg) Attachments ---------------- Plaza back up lenses.jpg (105KB - 380 downloads) Plaza back up lens new.jpg (104KB - 382 downloads) Plaza back up lens2.jpg (97KB - 385 downloads) | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | I've started repainting the interior. My new headliner is en route, so I need the interior repainted and good and dry before I start messing with that. I still need to order some insulation for the inside of the roof. Not sure what I'm going to buy. (Plaza interior repaint.jpg) Attachments ---------------- Plaza interior repaint.jpg (101KB - 372 downloads) | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | CTC Auto Ranch built a crate to ship me my headliner bows. Now, I have to get them out and get them painted. I don't want to put rusty headliner bows into a white headliner. (Plaza headliner bows.jpg) Attachments ---------------- Plaza headliner bows.jpg (75KB - 369 downloads) | ||
56' Savoy |
Member Posts: 30 | Hi,I'm new to this forum,and just had to join to follow this tread. Have a 55 Plaza 2dr suburban too,and this year I've had it for 40..! years..won't bore you guys with bad excuses for not finishing it,but rust,lack of parts,building a home,raising kids are a few of them..in addition,I live in Norway,Europe,and if it's tough to find parts in the US,you can only imagine trying over here.. Anyway,I'm thankful for the technical information,what parts you use,and the name of the suppliers.Will probably go for a lot of the same stuff,like the disc brake conversion,wire kit ++ Must say,I'm impressed by the speed you make things done,and the crisp and detailed pictures ! Just last Month though,I bought a pretty nice 1956 Savoy club sedan,with only 17200 miles since new,so will try to leave that alone ( for now ),and just enjoy it this summer,and get back to the Plaza in the garage when winter comes.. | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | I did the right side wheel cylinder first. I was happy to find the linings were pretty much brand new. Then, I moved over to the left side and found the linings were shot. No actual wear, but the material was crumbling. So, a new set of shoes from Bernbaum went on yesterday. (Plaza shoes old.jpg) (Plaza shoes new.jpg) Attachments ---------------- Plaza shoes old.jpg (147KB - 367 downloads) Plaza shoes new.jpg (114KB - 375 downloads) | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | Coating the headliner bows with Eastwood rust encapsulator. (Plaza headliner bows (2).jpg) Attachments ---------------- Plaza headliner bows (2).jpg (101KB - 363 downloads) | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | I've now realized that I have sedan headliner bows and not wagon headliner bows. The last couple of sedan bows are way too long for a wagon. Now, I have to either find wagon bows, shorten and re-arch the sedan bows, buy universal bows, or make some bows. I'm wondering if maybe cheap kids fishing poles from Walmart or Kmart would make good bows. | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | Today, I tried remounting the wheels and taking the car off the jackstands. I was disappointed to find the inside of the wheels interfere with the calipers. Looks like about a 1/4" spacer would clear this up. (Plaza caliper interference.jpg) (Plaza caliper interference on wheel.jpg) Attachments ---------------- Plaza caliper interference.jpg (132KB - 362 downloads) Plaza caliper interference on wheel.jpg (193KB - 376 downloads) | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | I used some washers as spacers and realized that a 1/4" spacer would be fine. However, as it was, it was close, so I went ahead and tried the hammer. A few blows with the big ball pein and the metal moved enough to clear the calipers. (Plaza Rim.jpg) (Plaza Rim2.jpg) Attachments ---------------- Plaza Rim.jpg (66KB - 381 downloads) Plaza Rim2.jpg (135KB - 361 downloads) | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | Finally after months on jack stands, I started it up and moved it under its own power today. I just backed it out of the garage and let it idle until it got hot, but it was a relief to hear it run. I still have to set the timing and likely address choke problems with the carb, but I cannot adequately express how relieved I was, after all that rewiring, to hear it fire up. Of course, I couldn't completely escape my stupid side. I noticed the gas gauge read empty and assumed it wasn't working until the gas ran out when it was halfway back into the garage. About a gallon and a half from the mower can and I was good to go again. (phpjm9ytIPM.jpg) Attachments ---------------- phpjm9ytIPM.jpg (96KB - 375 downloads) | ||
56' Savoy |
Member Posts: 30 | Job well done so far,71 Charger fan ! | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | I found some '56 Dodge wagon headliner bows at Big M. While I wait for those to arrive, I'm sanding and prepping the interior for paint. Now that's a miserable job. | ||
Expert 5K+ Posts: 5006 | going to be amazing with that fake wood gone... 56 the same as 55? (1956PlymouthAd03.jpg) Attachments ---------------- 1956PlymouthAd03.jpg (117KB - 375 downloads) | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | '56 has small fins, different taillights, parking light lenses, grill, hood ornament, the dash is changed a little, and the '56s are 12V. Other than that, they're pretty close to being the same. | ||
Expert 5K+ Posts: 9903 Location: Lower Mainland BC | 55's Edited by 56D500boy 2017-05-23 12:22 PM | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | Today, I sanded and prepped the interior structure on the passenger side for primer. (Plaza pass int prepped.jpg) (Plaza pass int primed.jpg) Attachments ---------------- Plaza pass int prepped.jpg (117KB - 375 downloads) Plaza pass int primed.jpg (93KB - 370 downloads) | ||
Greg P. |
Elite Veteran Posts: 769 Location: Oley, PA | You do great work! | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | There are a couple of runs in the primer that I'll sand out today and some thin spots I'll recover, but I should have it covered in white paint this afternoon and be ready to move to the door frames. | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | I took the rear seat back cushion off of its metal frame today and discovered more mouse nests. Vacuuming it all out of the seat springs really filled up the shop vac. (phphcUkiDPM.jpg) (phppKwyH9PM.jpg) (phpZpclMfPM.jpg) Attachments ---------------- phphcUkiDPM.jpg (126KB - 374 downloads) phppKwyH9PM.jpg (148KB - 357 downloads) phpZpclMfPM.jpg (160KB - 369 downloads) | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | The '56 Dodge wagon headliner bows I ordered from Big M arrived today and I've given them a coat of Eastwood Rust Encapsulator. (Plaza headliner bows from Big M.jpg) Attachments ---------------- Plaza headliner bows from Big M.jpg (195KB - 372 downloads) | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | More mouse nests. I'm afraid to look in the front seat. This is the rear seat bottom. (Plaza rear seat bottom cushion.jpg) Attachments ---------------- Plaza rear seat bottom cushion.jpg (119KB - 388 downloads) | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | The metal pan that goes under the rear seat cushion suffered from rodent urine-induced corrosion. Lots of Simple Green and scrubbing later and it still looked like this. (Plaza rear seat bottom cushion pan.jpg) Attachments ---------------- Plaza rear seat bottom cushion pan.jpg (102KB - 375 downloads) | ||
71charger_fan |
Elite Veteran Posts: 667 Location: Frederick, MD | I got the rear seat bottom cushion pan stripped and primed. I took this piece and the corresponding piece for the seat back to the local powder coater. He wanted $600, so I brought them home. (Plaza Rear Seat Pan.jpg) (Plaza Rear Seat Pan (2).jpg) Attachments ---------------- Plaza Rear Seat Pan.jpg (92KB - 384 downloads) Plaza Rear Seat Pan (2).jpg (111KB - 390 downloads) | ||
