Engine Temp sender unit ohms
Richbo
Posted 2016-12-05 2:48 PM (#527949)
Subject: Engine Temp sender unit ohms
10010025
Hi all.
Anyone know , or can check , what the ohm reading should be at my engine temp sending unit on my "59 Imperial w 413 ?? I bet most forwardlook cars use the same unit. My guage works (goes full scale when sender wire is grounded).
Warmed up I am seeing 180 Ohms at 180 Degrees !!! Yet my guage reads very low. My guess is the ohms at 180 degrees should be lower -- like maybe 120 ???
Richbo
Posted 2016-12-05 3:45 PM (#527955 - in reply to #527949)
Subject: Re: Engine Temp sender unit ohms
10010025
Well -- I answered my own Q !! Ran my '60 Imp while looking at the ohm values -- I got about 30 ohms at 160 , 20 ohms at 185 degrees.
So Cold to Hot is about 40 to 20 ohms.
Posted 2016-12-05 3:47 PM (#527956 - in reply to #527949)
Subject: RE: Engine Temp sender unit ohms
5000200020005001001001002525
I am guessing that the PN is 1507050 as shown below. That might lead you to spec on ohms versus temp
Or it could be a 4051140 or one of these (sorry, I thought I would find the unique PN and nope, bunches of them):
Posted 2016-12-05 5:29 PM (#527962 - in reply to #527949)
200010005001001002525
The lower the resistance, the higher the gauge will read. If the wire is removed from the sender and grounded (zero resistance) the gauge will climb to full scale.
sermey
Posted 2016-12-06 2:04 PM (#528034 - in reply to #527949)
1000100100
This may give you some additional information:
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=29524&posts=27#M246158
