Power Options Circuit Breaker Bracket under dash Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Fastfury |
Regular Posts: 53 | Looking for the Bracket under the dash the holds the Circuit Beakers for the Power options , ie. Power Window ,Seats Top Mark | ||
Rodger |
Expert Posts: 1506 Location: Colo Spgs | Hola Some may wait until you say ---- what year is the vehicle or what the vehicle is that you are asking about. Rodger & Gabby Colo Spgs | ||
Fastfury |
Regular Posts: 53 | It was used on all Mopars in the late 50's with Power Seats ,Windows and Conv. Tops Flat steel plate with cutouts to hold the Circuit Breakers under the Dash | ||
miquelonbrad |
Expert Posts: 1737 Location: Hay Lakes, Alberta, Canada | The circuit breakers in my '57 Chrysler are inside the driver's side kick panel...maybe the convertibles were different? | ||
Chrome58 |
Expert Posts: 1316 Location: Belgium, 40 miles south of Brussels | miquelonbrad - 2017-01-19 2:20 AM The circuit breakers in my '57 Chrysler are inside the driver's side kick panel...maybe the convertibles were different? Same with me on my '58 Plymouth ... The Power Windows circuit breaker is inside the driver's side kick panel. | ||
Fastfury |
Regular Posts: 53 | How are they mounted and with what? | ||
Old Ray |
Extreme Veteran Posts: 507 Location: Invermere B.C. Canada - Rocky Mountains | Fastfury - 2017-01-19 7:10 AM How are they mounted and with what? I think this aftermarket mount is what your are looking for; Because I have no life,........ I looked for a mopar OEM bracket without any luck, ......you need more detailed information. | ||
Old Ray |
Extreme Veteran Posts: 507 Location: Invermere B.C. Canada - Rocky Mountains | .....look what I found ?
Edited by Old Ray 2017-01-19 1:29 PM | ||
Expert 5K+ Posts: 9666 Location: So. Cal | Here are the fuses for the power seat and something else in my '57 Windsor. The '57 New Yorker looks the same except there are three of them to work with the power windows. I am pretty sure that the fuse/breaker itself has a little clip on the back of its housing. That clip springs into a hole in the kickpanel area to hold it in place. You can see an empty hole to the left of these fuses for adding another breaker. The tops of the fuses are all bus-barred together to provide a common power source to all of them. Then the individual wires run out from the bottom connection to the different accessories. There is a paper that is applied over the tops of them that label the different connections. Mine is obviously not doing too well. Edited by Powerflite 2017-01-19 3:11 PM (Chrysler_PowerFuses.jpg) Attachments ---------------- Chrysler_PowerFuses.jpg (108KB - 56 downloads) | ||
Old Ray |
Extreme Veteran Posts: 507 Location: Invermere B.C. Canada - Rocky Mountains | Circuit breaker clip hold 4 breakers
Edited by Old Ray 2017-01-19 5:45 PM (breaker clip.JPG) Attachments ---------------- breaker clip.JPG (30KB - 54 downloads) | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | The "clips" that hold the individual circuit breakers are shown at the top left. These clips are installed in the square holes of the kick panel as shown in Nathan's pic. Greg (image.jpg) Attachments ---------------- image.jpg (81KB - 52 downloads) | ||
Fastfury |
Regular Posts: 53 | Greg, That is the one I have been looking for,Thanks you Does anybody have the one shown above. Mark | ||
Expert 5K+ Posts: 9666 Location: So. Cal | You should contact John at BigM. He may have some of them with the breakers. | ||
