1959 Headlight Switch Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
texas383 |
Regular Posts: 82 Location: Texas | Doing some rewiring and need a pin out/diagram/picture of the headlight Switch. Can someone share that with me please. The wiring was removed from the car so I couldn't just pull and replace. | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | I hope this may help you? - SERGE - (1959 RearView Headlight Switch.jpg) Attachments ---------------- 1959 RearView Headlight Switch.jpg (84KB - 106 downloads) | ||
texas383 |
Regular Posts: 82 Location: Texas | It helps a little... but I'm using an aftermarket wiring kit with different colors for the wires. Do you know which colored wire feeds the dome light? | ||
Expert Posts: 3774 Location: NorCal | You can download a copy of the service manual, it has wiring diagrams. http://www.mymopar.com/index.php?pid=109 Normally, the dome light wires are pink and yellow; pink is the feed from the fuse box and yellow supplies the ground at the door switch and headlight switch. | ||
texas383 |
Regular Posts: 82 Location: Texas | Thanx for all the responses.... but I didn't ask the question correctly and not sure what I was thinking when I typed that Lol I know about the pink and yellow for dome orange for dash etc. Thanx for the download site but it's do 59 Plymouth with different Switch pin out. My question is which pin on the back of the light switch does the yellow wire attach? Any help is GREATLY appreciated! Thanx so much for y'all s patience and responses!! | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | As it has already been stated, the yellow wire goes to ground someplace and as I recall there is no provision for a yellow wire at a 59 Ply headlight switch. It simply isn't needed. Your dome lights get a ground via the door switches or a switch on the light bezel. Greg | ||
texas383 |
Regular Posts: 82 Location: Texas | Ok... won't bother ya'll anymore | ||
Expert Posts: 3774 Location: NorCal | Not sure about the '59 but most HL switches have letters stamped in the fiber board where the terminals are attached. Example: B1=Battery B2= Battery I= Instrument lights P= Park lights D= Dimmer (This is where the yellow wire would attach, grounds when rotary dimmer is turned full left) | ||
texas383 |
Regular Posts: 82 Location: Texas | Thanx for all the help... to those interested the yellow dome light wire connects to the sliding map/some Switch on the dash above the ash tray and not the Headlight switch. Maybe this will help someone else that may face the same or similar issues. | ||
texas383 |
Regular Posts: 82 Location: Texas | ....sorry should read map/dome | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | Yes. True. There is, of course, a yellow wire that goes to a 59 headlight switch but it is power to the parking lights. Nothing for map/dome lights goes to the headlight switch. Greg | ||
