| I cannot seem to find a source for the gaskets that go between the block and the water pump housing for my 57 Dodge. It is a 325. Anyone have a suggestion for a source? Thanks |
| They're a pretty simple gasket to make. You should be able to trace the outline when you have the part off.
I know they're in a full rebuild gasket set but I'm sure you don't want to spend that much money for a few gaskets, that is, if you don't need any more gaskets. |
Location: McCleary WA | Try Olson's Gaskets in Port Orchard WA - 360-871-1207 , www.olsonsgaskets.com, info@olsonsgaskets.com. They have just about anything. |
| My fel pro engine gasket kit has them in it. Got it from rock auto |
| Thanks. Olsen's had them. Good to know they are in the Rock Auto kits though. |
Location: Alberta | Thanks for posting the supplier it's a great resource |
