57 Royal with 392 project Jump to page : < ... 4 5 6 7 8 9 10 11 > Now viewing page 10 [50 messages per page] | View previous thread :: View next thread |
Expert 5K+ Posts: 5006 | i knew it wasn't the posi... my trans is jacked... ill try the spare I have that was supposed to be good. The one i pulled from the donor was parked for a "reason" I think i know why now The tranny fluid looks kind of cloudy, its brand new and shouldn't look like that... swapping a trans in is pretty easy though. Edited by mikes2nd 2021-10-03 3:20 PM | ||
Leadfoot1000 |
Veteran Posts: 241 Location: Southern CA | mikes2nd - 2020-08-10 3:31 PM its the 79-80 dodge Truck master its 1.125 bore https://www.rockauto.com/en/moreinfo.php?pk=309581&jsn=3 https://www.cardone.com/product/10-1860-master-cylinder Hello Mike, I continue to have drum brake issues on my New Yorker and I’m going to switch to front disc and use a remote reservoir master due to hemi clearance. From the comments, it looks like you used the RAYBESTOS MC39178 master and removed the reservoir. Can you please tell me the fittings you used in place of the reservoir to adapt the hoses for a remote reservoir? Thanks, | ||
Expert 5K+ Posts: 5006 | I got two aluminum dowels and drilled and tapped them out(youll need to clearance them a little on the bottom also) I used a funky remote reservoir off a Mitsubishi or something. I think your going to need a lathe and make brass like the one guy did before, i like his setup better. I guess mine is simper? I cut some grooves around the aluminum to put seals around the aluminum dowels since i didnt have the bottom lip (Booster with cyl.jpg) Attachments ---------------- Booster with cyl.jpg (245KB - 230 downloads) | ||
Leadfoot1000 |
Veteran Posts: 241 Location: Southern CA | Ok thanks for posting the photo, looks good. I’m working on some options now to replace mine. Steve | ||
Expert 5K+ Posts: 5006 | you need a lathe to make those plugs that match the plastic reservoir and he connected them to the original res... I think i might make a bunch, | ||
Leadfoot1000 |
Veteran Posts: 241 Location: Southern CA | After a bit of searching I found some hose adapters, the brass ones shown in the photo, $40 for a pair of the cups and elbows. We’ll see how well they fit the master. Make a bunch and sell them, they’re not easy to find. I probably should continue the updates to my car on the thread for it. I’ll post there as I redo the brakes. Thanks, Attachments ---------------- AF9BAB6C-7C71-4880-BC18-32B69CB8B687.jpeg (33KB - 234 downloads) | ||
Expert 5K+ Posts: 5006 | I bought a small lathe... fixing it up a bit... And the trans is out, i have to have the gear ring swapped over to my new torque converter... Cleaning my backup trans... I was thinking about a 700R4 but ill slap this one in see how it does. (transout2.jpg) (transout.jpg) Attachments ---------------- transout2.jpg (240KB - 242 downloads) transout.jpg (227KB - 239 downloads) | ||
Expert 5K+ Posts: 5006 | cleaned and installed, painted all nice and silver Swapped out the torque converter ring on the new torque converter... trans is reinstalled... (Screenshot.jpg) Attachments ---------------- Screenshot.jpg (219KB - 233 downloads) | ||
Expert 5K+ Posts: 5006 | redid parking brake... https://www.youtube.com/watch?v=6oxYTvZjip4 | ||
Expert 5K+ Posts: 5006 | New trans works great so far... I guess i realize why the donor hemi car was parked now. I did see the kick down rod had to be extended a bit to handle the 392 swap so I did that also and the exhaust is perfect finally. Shifts into reverse fine can come back off the jackstands as everything underneath is finally done and buttoned up... back to the interior. (Dodge3.jpg) Attachments ---------------- Dodge3.jpg (239KB - 218 downloads) | ||
Expert 5K+ Posts: 5006 | fired up and clearing out the moisture from sitting for a while... I will relash the valves i guess but it sounds good. Start cleaning up around it and get it back on the ground. I will fine tune later(that is the carb settings out of the box). I think im ditching the 392 emblem... Its kind of there so i dont have to tell people what it is but it looks pretty bad. https://www.youtube.com/watch?v=JWxYlnGy8D4 Edited by mikes2nd 2022-01-12 1:19 PM | ||
di_ch_NY56 |
Expert Posts: 1530 Location: ZH, Switzerland | Looks superb, sound good. | ||
Expert 5K+ Posts: 5006 | just did some clips of trans info... was a pita but its done and working great. https://www.youtube.com/watch?v=wnMV1o4UPhQ | ||
Mopar1 |
Expert Posts: 3033 Location: N.W. Fla. | mikes2nd - 2022-01-12 12:16 PM Everyone assumes a hemi is a 392 anyway...fired up and clearing out the moisture from sitting for a while... I will relash the valves i guess but it sounds good. Start cleaning up around it and get it back on the ground. I will fine tune later(that is the carb settings out of the box). I think im ditching the 392 emblem... Its kind of there so i dont have to tell people what it is but it looks pretty bad. | ||
Expert 5K+ Posts: 5006 | nope lots of non 392s all over now.. | ||
22mafeja |
Elite Veteran Posts: 649 Location: Finland | I am restoring a 57 coronet now and noticed that you had found a 2nd vin on the frame somewhere...my body is soon lifted off so tell me where I have to look . Edited by 22mafeja 2022-02-19 5:04 PM | ||
Expert 5K+ Posts: 5006 | supposed to be on top of frame at passenger foot area. You will have to carefully polish that area | ||
22mafeja |
Elite Veteran Posts: 649 Location: Finland | So it is at the same spot as on my 58 Firedome...good to know...thanks. | ||
Mopar1 |
Expert Posts: 3033 Location: N.W. Fla. | reportedly it in a number of hidden places that the cops are supposed to know where. | ||
Expert 5K+ Posts: 5006 | making these seats fit... Not a lot of room in the back seats of these coupes... I think I can sit them down a bit and get it nice and comfy in the back. I will re vinyl them later with turquoise. (backseats.jpg) Attachments ---------------- backseats.jpg (248KB - 183 downloads) | ||
Expert 5K+ Posts: 5006 | finally getting there... these are the parking/running lights... I want 4 brake lights. License plate will be the reverse lights. Finishing dash and wiring this weekend hopefully.. Front and rear lights are essentially done... Then carpet and seats... Ill run black this year, will recover over the winter... (parking.jpg) Attachments ---------------- parking.jpg (207KB - 153 downloads) | ||
Expert 5K+ Posts: 5006 | Dash going in... (dash2.jpg) Attachments ---------------- dash2.jpg (159KB - 149 downloads) | ||
Expert 5K+ Posts: 5006 | these dash lights are not very bright... I even bought the ultrabright led's... (dash.jpg) Attachments ---------------- dash.jpg (249KB - 130 downloads) | ||
57burb |
Expert Posts: 3967 Location: DFW, TX | I guarantee you do not want dash lights that are "bright" in daytime while driving at night. Close up the garage and see if your dash lights are bright enough to see the gauges. | ||
Expert 5K+ Posts: 5006 | the lower tail lights are WAY too bright... got to swap those out... (reartails.jpg) Attachments ---------------- reartails.jpg (244KB - 124 downloads) | ||
Expert 5K+ Posts: 5006 | Okay the clock light is not working out... (greenLens.jpg) Attachments ---------------- greenLens.jpg (238KB - 136 downloads) | ||
Expert 5K+ Posts: 5006 | wiring of dash is done... hook up the steering column and put some kind of seat it in and test drive potentially... (Untitled.jpg) Attachments ---------------- Untitled.jpg (250KB - 125 downloads) | ||
Expert 5K+ Posts: 5006 | Am i the only one how has put a Chrysler power steering gear in a Dodge? It bolts right in... BUT you must cut the column cover and shaft down and weld it. I thought it was the same unit... its not. I did change out the arm for the dodge and it fit also, the steering ratio is 3.5 vs 3.4 so that won't be a problem. I guess I have the heavy duty power steering... I do need a measurement from the "dash to the bottom of the wheel where it meets the cover) if anyone can get me one from their Dodge. (PXL_20220808_004549104.jpg) Attachments ---------------- PXL_20220808_004549104.jpg (227KB - 116 downloads) | ||
57burb |
Expert Posts: 3967 Location: DFW, TX | The Chrysler has a 4" longer wheelbase, all forward of the doors, so I'm not surprised the steering column is different. And it's really just a bigger car... the frame is made from thicker steel, it uses heavier duty ball joints and steering parts, and there are likely several other key differences in the steering. Why not just run the stock Dodge steering gear? | ||
Expert 5K+ Posts: 5006 | 1. I don't have the dodge setup 2. The chrysler is already hooked up and working It's just a matter of getting it where it feels comfortable. I think I will wait till i get the caddy seats setup and see how it goes. I am a little worried about the hump though, i should be fine as the caddy has the center hump also. | ||
Expert 5K+ Posts: 9652 Location: So. Cal | I bet you're cutting up a 300C column, aren't you. | ||
Expert 5K+ Posts: 5006 | no im cutting up a new yorker :P these are not rare parts... same as sedan parts a dime a dozen... actually, i have a spare 300C column | ||
57burb |
Expert Posts: 3967 Location: DFW, TX | Well... You will need to take it all apart to shorten the column and weld it. You don't want it to wobble, and you sure as !@#$ don't want the weld to break. Attaching two images of the column and gearbox for '57 Chrysler in case it helps. As I mentioned earlier, the wheelbase is four inches longer on the Chrysler. You can use the angle of the column and the Pythagorean theorem to come up with an amount to shorten it. If the column angle is at 30* from horizontal (and I don't know what it is) then that means you'd shorten the shaft by 4.6188" I can't help but think you'll be better off just finding a Dodge power steering box and column. (PAGE-211.jpg) (PAGE-216.jpg) Attachments ---------------- PAGE-211.jpg (268KB - 115 downloads) PAGE-216.jpg (306KB - 115 downloads) | ||
Expert 5K+ Posts: 5006 | nah actually the angle is the same, lines up perfect... bolts right on the frame. The coaxle is like having heavy duty steering. the pitman arm was shorter by a very small margin. I wouldn't just 'tack" weld it trust me the weld would be stronger than the original. And since its two simple pieces to weld it wouldn't be a problem. Actually I am going to fit the wheel to like someone who is 6 feet to the seats. I have the Plymouth to compare and the Chrysler. | ||
Expert 5K+ Posts: 5006 | finishing window trim... got it all buffed... I am putting 58 Custom royal roof trim on a 57 dodge which is a little funky Anyone want to trade good 57 with good 58? (trim1.jpg) Attachments ---------------- trim1.jpg (202KB - 111 downloads) | ||
Expert 5K+ Posts: 5006 | Okay about to take the car for a ride around the block... I remember i was dumb thinking I would "just get it running"... and as I am anal retentive about the smallest details.. turned into a insane restoration with upgrades on everything. I used another brake booster that doesn't leak and used a good "loose" chrysler power brake pedal arm... Just slapped it in... works! Will release when you let off the trigger... this has been a long haul... finishing up trim. I will be fitting the regal lancer trim on the side this weekend... I will probably save windows for the winter but should make a couple car shows. https://youtu.be/NupdcNyTyUA | ||
61imp |
Regular Posts: 90 Location: Oklahoma | Looking good! I'm pretty sure this is the car I passed on because the ad only had 1 photo of the drivers side from what seemed like 100 ft away, and he never sent more pics that I asked for. I didn't want to drive to MO and deal with a guy that doesn't communicate well and then find out the car is worse than expected. Seeing your pics of it, I would have bought it at his asking price though, as I have a 4 door parts car. Looks like it's in better hands with you anyway, it would still be in my shop labeled as project #3 if I had bought it. | ||
Expert 5K+ Posts: 5006 | yeah it was a cop out of Missouri, and he was kind of a pita.. and it was worse than originally thought (like always). This has been a SLOG... The next cars will go much quicker... and I actually ordered parts for them as I ordered the parts for this. My 58 Plymouth part stash is well stocked. I also introduced my own issues though, and I am learning FWL restoration... And I am also working on a house and other cars constantly. (honestly 5-10 real hours a week is all i have last two years). But its going to hit the road finally i think... Will probably need driveshaft balancing to drive it over 35. Some things working with FWL cars take forever to get the right part or make it yourself. I am making rear window trim clips because you can't buy them anymore... s**t like that takes hours... little sh*t will kill you on these cars... just having the riight bolt or screw.... I made a ton of work for myself with the whole new wiring harness and tons of upgrades...
Edited by mikes2nd 2022-09-08 2:08 PM | ||
57burb |
Expert Posts: 3967 Location: DFW, TX | Glad to hear it running! Now go drive it around, it will really get you motivated to finish it up. Great job! | ||
Expert 5K+ Posts: 5006 | well its carpet and its kinda blue turquoise.. I may swap out later... (carpet.jpg) Attachments ---------------- carpet.jpg (225KB - 96 downloads) | ||
Expert 5K+ Posts: 5006 | its moving... didnt put the windows in it yet... that will be a nightmare for winter job... Front seat looks like its going to work. I may need to cut some lowering channels later also, it s a tight entrance but I dont have the power seat hooked up yet. I could have heated and cooled seats... the mechanism is there... cooling is just a couple fans. (PXL_20221001_203754273.jpg) (PXL_20221001_203456042.jpg) Attachments ---------------- PXL_20221001_203754273.jpg (209KB - 89 downloads) PXL_20221001_203456042.jpg (241KB - 93 downloads) | ||
Expert 5K+ Posts: 5006 | Uhg the bright turquoise vs the seafoam green... I will have to live with it though | ||
Expert 5K+ Posts: 9652 Location: So. Cal | I agree that the bright turquoise doesn't go well with it, but I do really like the outside colors you chose. It's great to get it all together and drive-able. Congratulations! Are you still planning to install the Regal Lancer trim onto it? | ||
57burb |
Expert Posts: 3967 Location: DFW, TX | The turquoise is a bit odd with the exterior colors. But if you ever intend to change it, now would be the time. Once you get the interior buttoned up and all the seals and windlace in place, it will be a lot more work to pull it back apart. JMO Edited by 57burb 2022-10-04 12:23 PM | ||
Expert 5K+ Posts: 5006 | Eh I think i will go dark blue now... to match the carpet. I can adjust as it goes... but I will get the seats in dark blue.(I THINK)... This is just way too radical... I also noticed most interiors were two shades of some sort and often matched the exterior. Everything else pulls off easily... just the screws... I just need to make sure the dark blue works this time... learned my lesson... be CAREFUL with turquoise. I kind a knew it when i put the green against the turquoise vent and was like wtf. Pulling the dash is the hard part. I could spray the headliner in the car with vinyl paint. But it's just painted surfaces... I can shoot them one at a time... or simple spray the vinyl with vinyl paint. I will put the regal trim on it over the winter. I think this is one of the most radical but still not shocking... I think i need to get the dash and rear panel close to the body color... or black/dark blue | ||
Expert 5K+ Posts: 5006 | https://youtu.be/okhN4kgNAKU?t=120 I would have been fired if i was working for Chrysler... Just didnt plan it out... ack... I do need to adjust some things anyway... The first go around with all the custom wiring and upgrades and just finding what bolt connects to where was the hard part. I actually scratched some pieces... didnt get it perfect like i want as Im rushing to get it out to the last car show of the year in two weeks. I will get the new vinyl now and fix the package tray, fortunately i didnt cover the seats in it... I doubt i can find "dark" green... so maybe just go black and close to the seafoam green if i can find... Finding that seafoam green is going to be tough in vinyl or paint/carpet.
Edited by mikes2nd 2022-10-04 11:42 PM (s-l1600 (2).jpg) Attachments ---------------- s-l1600 (2).jpg (341KB - 98 downloads) | ||
Expert 5K+ Posts: 5006 | White headliner.(I cant find flexible paint to match, I will see if can convert mine over).. I will body paint to match trim pieces.... and add the dark green as needed to offset like factory... fark... I will get the roof done real quick, worry about the rest later. FARK
Edited by mikes2nd 2022-10-05 3:33 PM | ||
Expert 5K+ Posts: 5006 | Drove around the block successfully... I'm really considering leaving the interior, but I think i want to take the headliner off and make a pattern for the Plymouth while its out. I'll slowly get it color swapped out over the winter then paint the dash two tone next spring. | ||
57burb |
Expert Posts: 3967 Location: DFW, TX | I ordered a headliner from https://www.headlinermart.com/. Of course, being a hardtop, you have to stretch and trim it to fit, and that's usually best done with the windshield and rear window removed. It is a nice looking headliner and fit the bows perfectly. You video everything! Where is your first drive?! | ||
Expert 5K+ Posts: 5006 | Lol i didnt do that, i will get one... the seat wasnt even nailed down. | ||
