1955 Powerflite switches
Blazin6969
Posted 2017-05-04 9:35 PM (#539464)
Subject: 1955 Powerflite switches
Hey quick question under this transmission is 2 switches one with 2 nipples Im assuming that for reverse lights and one with just 1 nipple is that the neutral start switch? If so how do you actually wire that? Anyone have any manuals or information on these transmissions?
Thanks
ronbo97
Posted 2017-05-04 10:31 PM (#539466 - in reply to #539464)
Subject: RE: 1955 Powerflite switches
20001000100
Yes, you have that correct.
Neutral safety switch is a 16ga brown wire from ARM on starter relay to nipple on switch.
Backup lights is a 16ga red from back of windshield wiper switch to one of the two contacts on the switch. The other is a 16ga black with yellow tracer to the back up light.
Note: This is from my 55 Desoto shop manual. Wire colors may be different on other cars of that year.
Ron
Edited by ronbo97 2017-05-04 10:33 PM
Blazin6969
Posted 2017-05-05 6:30 AM (#539485 - in reply to #539464)
Subject: Re: 1955 Powerflite switches
Great thank you for the info, I am putting this on my 34 plymouth and never wired a single wire neutral starter switch.
Posted 2017-05-05 1:09 PM (#539502 - in reply to #539485)
20005001001001002525
With the single wire NSS you need to run it through a relay.
Are you using the original direct drive starter? If so, the relay pictured will work; the large terminals power the starter while one small terminal is power from the starter switch and the other small terminal goes to the NSS.
(Relay.jpg)
Attachments Relay.jpg (19KB - 58 downloads)
Blazin6969
Posted 2017-05-05 10:40 PM (#539534 - in reply to #539464)
Yes, I am stilling using the same 6 volt starter from the 55 plymouth I pulled the tranny and engine from.
Blazin6969
Posted 2017-05-11 10:10 AM (#539874 - in reply to #539464)
Does anyone have a wiring diagram? 1955 plymouth savoy powerflite. Thanks
Posted 2017-05-11 2:54 PM (#539885 - in reply to #539874)
Wiring diagrams are here:
http://www.mymopar.com/index.php?pid=25
You can download a copy of the service manual on the same site.
Blazin6969
Posted 2017-05-18 9:24 PM (#540368 - in reply to #539464)
Thanks guys! Ended up using a horn relay as my neutral safety switch lol.
