1957 Desoto Parts:
   Forward Look Swap Meet -> For Sale - PARTSMessage format
61_Imperial
Posted 2017-08-07 12:14 PM (#545762)
Subject: 1957 Desoto Parts:
100100100100252525
Parting out a '57 Desoto:
Front Core support, very straight, pretty nice overall. Was an A/C car. $90
Inner fenders: Driver side is really nice, passenger side has one small hole, overall very nice. Battery tray section is perfect. $275 for both. (I do not want to ship these, I have had very good luck with U-ship however, and it usually quite a bit cheaper then freight)
1957 (only) steering column and gear: car was low mileage, around 68K, not lots of play in steering, complete column attached. Power steering car of course, $175 for entire column and gear.
Signal seek "brain", this is mounted on passenger side under dash, this is also 1957 only. I do not have the radio, just this brain part of it. Comes with bracket as well that hangs from inner hood hinge. $75. (SOLD)
Front Desoto emblem: Nice shape, no broken screws. $75 for all 3 pieces
Big car (Desoto Firedome, Fireflight, Chrysler Saratoga and New Yorker) front sway bar. Nice shape, will need the hangers, $100
1957 Desoto 341 hemi 4 barrel intake, this was used on Fireflights only. This can be directly bolted onto a Firedome for added horsepower. in nice shape, painted black. $350.
1957-1959 Desoto dual antenna splitter. in nice shape, this runs all the way to the trunk for the dual antenna option. $100
I will post more stuff shortly..
Here are a few photos:
Edited by 61_Imperial 2017-08-07 3:11 PM
61_Imperial
Posted 2017-08-07 12:20 PM (#545763 - in reply to #545762)
Subject: RE: 1957 Desoto Parts:
100100100100252525
Posted 2017-08-07 7:12 PM (#545780 - in reply to #545762)
Subject: Re: 1957 Desoto Parts:
500020002000500100
Are the Dodge and Chrysler sway bars different? If so, how? I was hoping to swap a big body Chrysler bar on my Dodge.
61_Imperial
Posted 2017-08-08 2:58 AM (#545805 - in reply to #545780)
100100100100252525
Powerflite - 2017-08-07 7:12 PM
I actually do not know. I wouldn't think so...
ToMopar
Posted 2017-08-08 5:50 AM (#545810 - in reply to #545762)
10001002525
Nathan,
I would compare lower control arms and struds of both cars
61_Imperial
Posted 2017-08-08 10:21 AM (#545830 - in reply to #545810)
100100100100252525
ToMopar - 2017-08-08 5:50 AM
Nathan,
If it helps, I know the Ball joints and upper and lower bushings are the same on both cars. So that would lead me to believe they are the same set up..
61_Imperial
Posted 2017-08-15 11:44 AM (#546246 - in reply to #545762)
100100100100252525
Anyone? make offers...
Posted 2017-08-15 2:17 PM (#546265 - in reply to #545762)
5000
sway bars work on all cars(at least v8s) I just put a 57 Chrysler on my 57 Dodge.
Posted 2017-08-15 5:14 PM (#546286 - in reply to #546265)
500020002000500100
That makes sense as they use the same width of frame. But I wasn't sure about the lower control arms. Thanks for the input.
61_Imperial
Posted 2017-08-15 11:18 PM (#546315 - in reply to #546286)
100100100100252525
Powerflite - 2017-08-15 5:14 PM
Sounds like it will fit. Are you still interested?
Posted 2017-08-15 11:34 PM (#546316 - in reply to #546315)
500020002000500100
I already have one from my parts car. Just haven't gotten around to installing it yet.
big m
Posted 2017-08-17 3:38 PM (#546419 - in reply to #545780)
50002000500100100100
Powerflite - 2017-08-07 4:12 PM
I'm pretty sure the Dodge sway bars are different. The Dodge ones will fit a Plymouth, however.
---John
Posted 2017-08-17 6:22 PM (#546435 - in reply to #545762)
5000
I will take a picture of my Chrysler bar on my dodge. It looked like it would fit fine.
miquelonbrad
Posted 2017-08-19 12:27 PM (#546531 - in reply to #545762)
100050010010025
Ryan,
Would you have the A/C vents for the top of the dash? I'm looking for them for my DeSoto...
Posted 2017-08-20 4:57 PM (#546591 - in reply to #545762)
5000
John was right the Chrysler is a slight bit longer in the front.
if your putting it in a car with a sway bar installed you will need to move the frame mounts like 2 inches forward.
I am bolting my mounts in so I am moving them slightly forward, I wont actually mount them until I get the weight and the car on the ground...
(swaybarChrysvsDodge.jpg)
Attachments swaybarChrysvsDodge.jpg (244KB - 112 downloads)
61_Imperial
Posted 2017-08-21 9:12 AM (#546651 - in reply to #546531)
100100100100252525
miquelonbrad - 2017-08-19 12:27 PM
Ryan,
I do have these
miquelonbrad
Posted 2017-08-22 9:35 AM (#546738 - in reply to #545762)
100050010010025
Pm'd you.
macedon
Posted 2017-08-30 6:02 PM (#547377 - in reply to #545762)
5001001001001002525
Do you have these on this car? According to Ed Petrus not all of them had them. Supports for the mesh grille. I have 2 57's, one had them, one did not.
(supports1.JPG)
(supports2.JPG)
Attachments supports1.JPG (164KB - 115 downloads)
Attachments supports2.JPG (138KB - 133 downloads)
