Sure grip oil?
Adventurer 60
Posted 2017-08-08 3:10 AM (#545806)
Subject: Sure grip oil?
500100100252525
What kind of modern oil should I use in my 300Gs rear?
Is regular W90 a bad choise
Posted 2017-08-08 5:08 PM (#545867 - in reply to #545806)
Subject: RE: Sure grip oil?
200010002525
The clutches in the Sure-Grip need additional lubrication; you can use a conventional GL-5 lubricant with an additive like the GM 88900330 or a synthetic like Red Line 75W/90 that needs no additive.
Edited by 57chizler 2017-08-08 5:16 PM
(LS Additive 88900330.jpg)
Attachments LS Additive 88900330.jpg (6KB - 58 downloads)
Mopar1
Posted 2017-08-08 10:45 PM (#545882 - in reply to #545867)
Subject: Re: Sure grip oil?
2000500100252525
Or check Summit, Jegs....
Posted 2017-08-09 4:36 AM (#545890 - in reply to #545806)
500050010025
http://www.ebay.com/itm/Dodge-Jeep-New-Limited-Slip-Additive-Fricti...
Adventurer 60
Posted 2017-08-09 5:34 AM (#545892 - in reply to #545806)
500100100252525
I'm in Finland. Cant go to Summit or Jegs or want buy oil on line.
But will these work?
http://www.motonet.fi/fi/tuote/6000158/Red-Line-peravaihteistooljy-...
or
http://www.motonet.fi/fi/tuote/590023/MAG1-LS-GL5-lukkoperaoljy-80W...
or
http://www.motonet.fi/fi/tuote/590073/Red-Line-75W90-GL5-Peraoljy-9...
Those are in one of local stores.
Edited by Adventurer 60 2017-08-09 5:40 AM
Posted 2017-08-09 5:50 AM (#545893 - in reply to #545806)
50005000100050010025
I would recommend Lucas Gear Oil http://www.autozone.com/greases-and-gear-oil/gear-oil/lucas-oil-hea...
You should find it locally.
BigBlockMopar
Posted 2017-08-09 2:01 PM (#545912 - in reply to #545806)
20001000100100100100252525
You need a gear oil with "Limited Slip (Differentials)" mentioned on the bottle.
Posted 2017-08-09 2:20 PM (#545913 - in reply to #545892)
200010002525
Adventurer 60 - 2017-08-09 2:34 AM
or
or
The Red Line (last on your list) is a limited slip differential lube, it's what I use.
Posted 2017-08-09 4:04 PM (#545918 - in reply to #545806)
Lucas and Red Line are good products!
