How do I find the hole to thread the antenna wire through firewall?
Merto
Posted 2017-09-05 9:29 PM (#547810)
Subject: How do I find the hole to thread the antenna wire through firewall?
I have a 1960 Plymouth and I cannot find the hole in the firewall to run the antenna wire....
Any hints how I can find the HOLE??????
I have opened up the inspection cover in the inner fender and cant see the hole or feel it.
I have climbed under the dash and looked in the right side of the body under the dash and don't see it.
WHAT DO I DO?
Posted 2017-09-05 11:13 PM (#547815 - in reply to #547810)
Subject: RE: How do I find the hole to thread the antenna wire through firewall?
500020002000500100100100100
WHAT DO I DO?
57plybel
Posted 2017-09-06 4:35 AM (#547820 - in reply to #547810)
500252525
Is it behind the passenger kick panel and not the firewall itself?
Colin
Posted 2017-09-06 8:21 AM (#547825 - in reply to #547820)
57plybel - 2017-09-06 4:35 AM
Is it behind the passenger kick panel and not the firewall itself?Colin
My 56 must have had a CB radio at one time (never came with an AM radio) and there was an aerial on the passenger side cowl, between the windshield and the fender (not on the fender). The hole went down from there into the passenger kick panel area and then over to the radio. (I guess).
Edited by 56D500boy 2017-09-06 8:22 AM
58coupe
Posted 2017-09-06 10:10 AM (#547831 - in reply to #547810)
Subject: Re: How do I find the hole to thread the antenna wire through firewall?
100050010010025
All i can say is on my 58 Plymouth there is a hole with a removable plug on the right side of the cowl at about the same height as the instrument panel.
FIN_NV
Posted 2017-09-06 9:28 PM (#547870 - in reply to #547810)
20002000500252525
I have a 60 Plymouth. When iinstalled the new antenna, i removed the passanger side kick panel. It should be a bit towards the nose.
