big block 3 bolt timing sprocket on a single bolt cam? Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Expert 5K+ Posts: 7395 Location: northern germany | can you run a 3 bolt sprocket on a single bolt cam? the pin seems to be in the same location so if the center bore has the same diameter it should work. anybody knows the answer? | ||
Shep |
Expert Posts: 3393 Location: Chestertown, NY ( near Lake George) | You need the matching cam to use a 3 bolt. | ||
Expert 5K+ Posts: 7395 Location: northern germany | are you 100% sure? have you tried? doesn't the pin match or the center bore? or both? | ||
Expert Posts: 3776 Location: NorCal | The big difference is in the way the sprocket indexes on the front cam journal. The single-bolt sprocket indexes off of the front journal snout and the dowel pin; the front journal face is flush with the block. The 3-bolt front journal is wider and the face extends about 1/8" from the block; the block side of the sprocket has a counter bore that indexes on the outer diameter of the journal and the dowel pin. (Cam Sprockets.JPG) Attachments ---------------- Cam Sprockets.JPG (180KB - 151 downloads) | ||
Expert 5K+ Posts: 7395 Location: northern germany | I see. A big THANKS John and Dave. Edited by 1960fury 2017-09-19 3:04 PM | ||
60 Imp |
Location: North Australia | Sid, are you changing out the timing gear in the Fury? If so be aware of the new cam sprocket touching the block. This happened to me when I installed a new (single bolt) set in my 413, with the original cam. There was an embossed number on the back side of the cam sprocket which touched a bulge on the front of the block (oil gallery I think). It sounded like a bad big end and destroyed the new timing set. I purchased another different brand set to fit to the motor and had to machine the back-side of that cam sprocket to make clearance, as it was very close also. Steve. | ||
Expert 5K+ Posts: 7395 Location: northern germany | i replaced bb timing chains several times but never ran into this problem. but thanks for the heads up Steve! | ||
BigBlockMopar |
Expert Posts: 3575 Location: Netherlands | A few seconds with a flapper sanding disc is usually all it takes to clearance the block. Had it happen a number of times too with the dual roller timing chain sets. | ||
Expert Posts: 3776 Location: NorCal | 60 Imp - 2017-09-21 12:28 AM If so be aware of the new cam sprocket touching the block. This happened to me when I installed a new (single bolt) set in my 413, with the original cam. There was an embossed number on the back side of the cam sprocket which touched a bulge on the front of the block. Was that a double-row chain sprocket or original single-row? | ||
