Decoding IBM Build Card - 1959 Desoto Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Showman |
Member Posts: 17 | Hello, Does anyone have the ability to "decode" an IBM build card. I received one from FCA Historical Services but they cannot decode due to staffing constraints etc. Any help would be appreciated. Thanks Steve | ||
Expert 5K+ Posts: 9898 Location: Lower Mainland BC | Showman - 2017-09-23 6:32 AM Does anyone have the ability to "decode" an IBM build card. I received one from FCA Historical Services but they cannot decode due to staffing constraints etc. Steve Steve: There are a few folks here that can help you. However, they are not physic so you will have to at least post a photo (<250kB in size) of the build card so they can see the codes and perhaps break it down like I did for my IBM build card: You might want to read through this thread: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=64614&... And, if you need help posting a photo, this primer: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=64340&... | ||
59 explorer |
Extreme Veteran Posts: 384 Location: Hershey PA | Also include a picture of your data plate which can be cross referenced to the card The data plate for a sweep is by the passenger's side hood hinge Others are on the radiator splash shield down low to the right or by the driver's side door hinge | ||
Showman |
Member Posts: 17 | Here is the build card. (scan@actonglass.com_20170925_080613.jpg) Attachments ---------------- scan@actonglass.com_20170925_080613.jpg (145KB - 178 downloads) | ||
Expert 5K+ Posts: 9898 Location: Lower Mainland BC | Showman - 2017-09-25 7:43 AM Here is the build card. You might as well have posted a micro-dot. That scan is too small. Somehow scan it so it comes out just less than 250 kB here. Maybe then it will be readable. | ||
Showman |
Member Posts: 17 | Is this one better? (scan@actonglass.com_20170925_080613.jpg) Attachments ---------------- scan@actonglass.com_20170925_080613.jpg (226KB - 191 downloads) | ||
59 explorer |
Extreme Veteran Posts: 384 Location: Hershey PA | The easy stuff for you 1204 car made on December 4, 1958 454 Desoto (4) Fireflite (5) 4 door hardtop (4) 102218 the 2218th Fireflite Your title should read M451 102218 with M=1959 4=Desoto 5=Fireflite 1=made at Jefferson in Detroit XXX Pearl White top/body/sweep 364 Gray cloth and vinyl interior Your data plate based on the production date, should be on the radiator splash shield down low to the right, lower left of it should be a collection of letters with numbers thereafter like J2 which is the outside mirror and so forth. Please copy/provide and we can attempt to cross reference it to the IBM card. Top line of data plate should match top line of the IBM card | ||
Expert 5K+ Posts: 9898 Location: Lower Mainland BC | The trim code is 384 not 364. | ||
Showman |
Member Posts: 17 | Here is the data plate: (dataplate.jpg) Attachments ---------------- dataplate.jpg (235KB - 180 downloads) | ||
Expert 5K+ Posts: 9898 Location: Lower Mainland BC | Sorry, I just trimmed it a bit so it fits the screen better (I was surprised that 235 kB was so large on the screen). 59 explorer - 2017-09-25 2:58 PM 1204 car made on December 4, 1958 454 Desoto (4) Fireflite (5) 4 door hardtop (4) 102218 the 2218th Fireflite Your title should read M451 102218 with M=1959 4=Desoto 5=Fireflite 1=made at Jefferson in Detroit XXX Pearl White top/body/sweep Top line of data plate should match top line of the IBM card As 59 explorer predicted, it ooks like things match your IBM card well. Edited by 56D500boy 2017-09-25 4:14 PM (DesotoBuildPlate.jpg) Attachments ---------------- DesotoBuildPlate.jpg (101KB - 179 downloads) | ||
Showman |
Member Posts: 17 | Thank you. Do you know what the other codes on the data plate refer to? For example J2 4K N6 etc. | ||
59 explorer |
Extreme Veteran Posts: 384 Location: Hershey PA | Correcting my typo, 384 is the gray cloth & vinyl interior Working my way thru the rest J2 is the outside mirror(s) To be advised N6 Solex Glass F9 stone deflector C4 would have been the aluminum insert between the chrome lines | ||
Chrycoman |
Expert Posts: 1819 Location: Vancouver, BC | Well, to go through the card - 01 - Route - (not used) 02 - Group - (not used) 03 - | 04 - | = Foreign Special ?? Make Order No. - (not used) 05 - | 06 - | 07 - WCB Gate - 075 - ?? 08 - Sort Code - 085 - ?? 09 - 7 | 10 - 1 | - Region = 71 11 - 3 - | 12 - 6 - | 13 - 8 - | - Dealer Number - 36862 14 - 6 - | 15 - 2 - | 16 - 0 - | 17 - 0 - | - Dealer Order NUmber - 002 18 - 2 - | 19 - 4 - Model - DeSoto 20 - 5 - Series - Fireflite 21 - 4 - Body Style - 4 door Hardtop 22 - 3 - | 23 - 8 - | - Trim - 384 24 - 3 - | 25 - 0,7 - Paint - Upper Colour - X - Pearl White 26 - 0,7 - Paint - Lower Colour - X - Pearl White 27 - 0,7 - Paint - Insert Colour - X - Pearl White 28 - 1 - (Unknown) 29 - Transmission - (not used) - Torqueflite standard, no options 30 - Power Equipment - 301 - Power steering 302 - Power brakes 304 - Power windows 31 - 2 - Accessory Group 2 32 - 7 - Tops - 317 - Rear seat speaker 33 - 1 - Antenna - 331 - Dual rear antennas 34 - 3 - Heater/AC -343 - 35 - 9 - 359 - Stone shield 36 - 2 - 362 - Swivel front seats 37 - 1 - 371 - Dual exhaust 38 - 1 - 381 - Licence plate frame 39 - (unknown) - (not used) 40 - Mirrors - 402 - Left, outside manual mirror 404 - Inside prismatic mirror 409 - ?? 41 - (unknown) - (not used) 42 - Roof Moulding - (not used) 43 - Instrument Panel - (not used) 44 - 3 - 443 - Radio 45 - Heavy Duty Shocks & Springs - (not used) 46 - 6 - 466 - Solex, tinted all windows 47- Custom ?? - (not used) 48 - Moulding - (not used) 49 - Sun Visor - (not used) 50 - (unknown) - (not used) 51 - Wheel Covers - (not used) 52 - (unknown) - (not used) 53 - 3 - 533 - Axle ratio 54 - 9 - 549 - Generator 55 - Batteries - (not used) 56 - Export Equipment - (not used) 57 - Miscellaneous - (not used) 58 - 1 - | 59 - 5 - | - 15 - Tires 60 - 1 - Car Service - 601 -?? 61 - 1 - Drive - 611 - ?? 62 - Route - (not used) 63 - Special Order (not used) 64 - 1 -| 65 - 2 -| 66 - 0 -| - 1204 - Scheduled Build Date - December 4, 1958 67 - 4 -| 68 - 2 - 682 ??? 69 - ? - Model - 69? - 70 - 9 - 709 -?? 71 - 1 -| 72 - 0 -| 73 - 2 -| - Car Serial Number - 102218 74 - 2 -| 75 - 1 -| 76 - 8 -| 77 - 8 -| 78 - 1 -| 79 - 4 -| - Motor Code - 8140 80 - 0 -| The (not used) means no holes were punched in the card for that column. (unknown) means I do not know what the heading is for the column - cannot make out what was printed on the card. The ?? means I do not have any description for that sales code (yet). | ||
Showman |
Member Posts: 17 | Wow....that's a lot of decoding. Thank you so much for your time! Steve | ||
59 explorer |
Extreme Veteran Posts: 384 Location: Hershey PA | Steve: Does Bill's translation match your car? With respect to your outside mirror(s)-do you have just the driver's side manual one? Do you have the prismatic inside one? Do you have a dealer plate on the trunk? Or noted on the owners manual? | ||
Showman |
Member Posts: 17 | There is only a drivers side - remote mirror - adjustable from inside the car. Yes....prismatic mirror inside. No dealer plate on the trunk. | ||
Showman |
Member Posts: 17 | Also, the car came with 15" tires. I understand that normally it was 14" is that correct. The hubcaps that came with the car were not original. I have a set of hubcaps, but they do not fit the rims (picture below)....were there more than 1 style of hubcap in 1959. Attached is a picture of what I purchased. Attachments ---------------- Unknown.jpeg (3KB - 189 downloads) | ||
Chrycoman |
Expert Posts: 1819 Location: Vancouver, BC | The 1959 DeSoto used 14" tires and 14" wheel covers on 14" rims. The wheel covers in the photo are 14" which is why they won't fit the 15" rims you have. What you must remember is not to assume everything on your car is as it was when the car was built. Nor should you assume that parts on the build card or original bill of sale not on the car now were not on the car when it rolled off the line. Many things can happen to a car over the years, and the tastes and preferences of the owner(s) can also change over the years. | ||
Showman |
Member Posts: 17 | Yes....I understand that for sure....What I am wondering is if there were other hubcaps produced for the 59's other than the image I was showing? Thanks Steve | ||
59 explorer |
Extreme Veteran Posts: 384 Location: Hershey PA | The wheel cover you show was standard on the Firedome and the Fireflite, optional on the Firesweep which had dog dishes standard The Adventurer had it's own wheel cover which was the standard wheel cover with a pointed hub over the emblem, gold anodized No other factory wheel were offered | ||
