1956 Plymouth Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Muffin1 |
Veteran Posts: 242 Location: Michigan | I want to put a air conditioner in my 56 Plymouth , can someone tell where to look for one or a company to call ? Thanks Alex | ||
Old Ray |
Extreme Veteran Posts: 507 Location: Invermere B.C. Canada - Rocky Mountains | Aftermarket, non-stock or OEM ? | ||
Expert 5K+ Posts: 9666 Location: So. Cal | Chizler put one in his '56 Plymouth. Hopefully he will chime in. Vintage Air is a good place to start for aftermarket. You really just have to figure out how much space you have available under the dash to fit the evaporator. If you don't have enough, you may have to go with one of those old under-dash units that hang in the middle area. Brackets for the compressor would have to be fabricated for a poly, but you may be able to modify ones made for the LA318 to make them work on the poly. | ||
GaryS |
Expert Posts: 1207 Location: Ponder, TX | I'm installing a Vintage Air in my '56 Plymouth and it's an extremely tight fit. If I were to do it again, I's use a much smaller unit. My dash is out, so I have access to everything, but the available space for routing hoses is just too limited. I also had to make compressor mounting brackets for a Poly and had to swap locations for the alternator and the compressor to get a better fit. That required a custom bracket for the alternator also. I've installed Vintage Air systems in my '73 Dodge truck and my '64 Valiant convertible, and the '56 is by far the most difficult to make fit. | ||
Expert 5K+ Posts: 9902 Location: Lower Mainland BC | GaryS - 2017-09-24 2:41 PM I'm installing a Vintage Air in my '56 Plymouth and it's an extremely tight fit. Jay Leno uses Vintage Air. REFERENCE: 6:12 in this Video = https://www.youtube.com/watch?v=nBlUXG6IYGQ&t=550s | ||
Old Ray |
Extreme Veteran Posts: 507 Location: Invermere B.C. Canada - Rocky Mountains | GaryS - 2017-09-24 12:41 PM I'm installing a Vintage Air in my '56 Plymouth and it's an extremely tight fit. If I were to do it again, I's use a much smaller unit. My dash is out, so I have access to everything, but the available space for routing hoses is just too limited. I think Gary used the larger model unit and after reading his info (but he lives in Texas) I think the compact model might be better? | ||
Muffin1 |
Veteran Posts: 242 Location: Michigan | Thank you gentleman for you help ! Alex All most forgot, do I need to put a pulley on the front of the crank shaft pulley ? | ||
GaryS |
Expert Posts: 1207 Location: Ponder, TX | Muffin1 - 2017-09-25 9:30 AM Thank you gentleman for you help ! Alex All most forgot, do I need to put a pulley on the front of the crank shaft pulley ? I originally had a three-groove power steering pulley that came with the later model Poly. I needed a smaller diameter two-groove setup for my manual steering car, so I used a pulley from an LA engine | ||
Expert Posts: 3777 Location: NorCal | I didn't want to fight the congestion in the dash so I went with a hang-on unit. The "hump" on the lower dash makes evaporator selection more difficult, I went with a generic E-bay unit based on its dimensions. As to the pulley dilemma, the modern Sanden compressors turn with less resistance so they can often share a single belt with another component. (Evap.JPG) Attachments ---------------- Evap.JPG (129KB - 197 downloads) | ||
