Polishing Stainless Steel Trim Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
jboymechanic |
Expert Posts: 2196 Location: Muskego, WI | Anybody have any experience polishing stainless trim? All of the trim around my front and rear windshields are really straight, they just need a good polish. I would like to do the work myself, but I don't have a buffing wheel. I was thinking of purchasing a pedestal mounted buffer, but I have no idea what type I should get. How big of buffing wheels? What compounds? If anybody has some advice, please let me know. Again, my trim doesn't need to be restored, but I want it to shine similar to my new chrome. | ||
Expert 5K+ Posts: 9664 Location: So. Cal | When you do get your polisher, run it with 2 polishing wheels together on it. If you just run 1, it will grab the stainless and throw it. 2 wheels together are more forgiving. Use the highest grade buffing compound, usually white rouge, if your stainless is in good shape already and just needs the shine. If you have to rework them, you will need to start with a coarse buffing and progressively move to finer grit. | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | I managed to do all the stainless for a bunch of these cars. I just used a 1/2 HP bench grinder with 8" buffs. Nathan is right. Always use two buffs sandwiched together. They hold together better and run a lot cooler. I pissed around with a lot of buff wheels and compounds but finally zoomed in on Eastwoods buffs and compounds. Great products! Always use a "rake cleaner" to clean the buffs frequently during use. You will need the complete assortment of buffs and compounds. You will find that different alloys of stainless were used in these cars so no specific recipe of compounds/buffs will always work. Greg | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | Oh, Yeah, remember that the factory "clear coated" all this stainless. As you cut through this "clear coat" it will contaminate your buff so you must constantly "rake clean" the buffs!! It took me a long time to figure this out!!! Greg | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | i've done polishing myself and am doing non-car stainless now . multiple wheels sandwiched work best , i use 3 8's on both sides of a 1/2 hp craftsman buffer . as for compounds , i've found that black emery is nicely aggressive followed by white finishing . i've never seen stainless trim with clear coat , not saying there isn't . oh , and by all means never forget nice gloves . something like mig welding gloves works good . thick enough to help with heat build up , light enough they don't wear your hands out . should i mention a face mask to help keep junk from getting to your lungs . paper 3m works . remember compound , little and often . after you get your own technique you'll be good to go ---------------------------------------------later | ||
jboymechanic |
Expert Posts: 2196 Location: Muskego, WI | Much appreciated guys. | ||
lozrox58 |
Extreme Veteran Posts: 308 Location: Newcastle Australia | You can generally pick up kits off eBay. You will need a soft rag wheel, which are generally white and a rough rag wheel (generally black). the wheels are stiched cotton. Most kits will come with an appropriate arbour to mount on your bench grinder, and 2 or more polishing compounds. There are a lot of youtube clips which show you how to polish, so it's a self education process. You may also need some fine grit sand paper to remove any scratches. | ||
springsweptwing |
Elite Veteran Posts: 1141 Location: Blackpool, United Kingdom. | LD3 Greg - 2017-12-17 5:49 AM Oh, Yeah, remember that the factory "clear coated" all this stainless. As you cut through this "clear coat" it will contaminate your buff so you must constantly "rake clean" the buffs!! It took me a long time to figure this out!!! Greg Flash chromed over stainless, when you go through the chrome you will see it change colour as you start polishing the stainless steel. | ||
lozrox58 |
Extreme Veteran Posts: 308 Location: Newcastle Australia | LD3 Greg - 2017-12-17 2:49 PM Oh, Yeah, remember that the factory "clear coated" all this stainless. As you cut through this "clear coat" it will contaminate your buff so you must constantly "rake clean" the buffs!! It took me a long time to figure this out!!! Greg I know none of my stainless was clear coated. Seems odd that the factory would do this, as there really is no gain is there? | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | springsweptwing - 2017-12-30 3:40 PM LD3 Greg - 2017-12-17 5:49 AM Oh, Yeah, remember that the factory "clear coated" all this stainless. As you cut through this "clear coat" it will contaminate your buff so you must constantly "rake clean" the buffs!! It took me a long time to figure this out!!! Greg Flash chromed over stainless, when you go through the chrome you will see it change colour as you start polishing the stainless steel. That's it! Thanks, Paul. I really didn't know what needed to be "cut through" before one got to the actual stainless steel. Everyone knows that a highly polished surface of stainless is very, very fragile and subject to even finger tip scratches. Of course it had to be protected from everything to stand up to be a surface of a car!! Greg | ||
Expert 5K+ Posts: 8947 Location: WHEELING,WV.>>>HOME OF WWVA | maybe that cut through is just plain old oxidation of cheap stainless-------------------------------------------------later and if its clear coat , why not uses a faster means of removal than buffing Edited by 60 dart 2018-01-03 6:38 AM | ||
jboymechanic |
Expert Posts: 2196 Location: Muskego, WI | I purchased the kit in the link below just before Christmas, it was heavily discounted at the time. I don't have any oxidation, coating or flash chrome to remove. Everything that I'm doing is straight, just needs a good polish after aging for 60 years. http://www.eastwood.com/eastwood-1hp-buff-motor-buffing-kit-and-sta... | ||
big m |
Expert 5K+ Posts: 7806 Location: Williams California | Another thing to be careful of is warpage. Getting curved pieces too hot can cause the curvature to change. How do I know this? I ruined a few roof moldings this way. ---John | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | big m - 2018-01-03 5:24 PM Another thing to be careful of is warpage. Getting curved pieces too hot can cause the curvature to change. How do I know this? I ruined a few roof moldings this way. ---John That's why I never wore gloves to do the job! Greg | ||
