Quick Question about Vacuum Brake Tank Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
roblun |
Veteran Posts: 201 Location: Fremantle, Western Australia, Australia | Can a 1955 Chrysler Vacuum brake tank be used on a 1958 Plymouth Belvedere, I have a chance To buy one, it has a great chrome finish and it looks great! Attachments ---------------- 0EADA524-7EA6-47E9-9DE0-01083C33C10F.jpeg (201KB - 159 downloads) 9A66BF15-15B7-4098-B3C9-906BF7437D30.jpeg (167KB - 153 downloads) | ||
Expert 5K+ Posts: 9894 Location: Lower Mainland BC | roblun - 2018-01-15 7:14 PM Can a 1955 Chrysler Vacuum brake tank be used on a 1958 Plymouth Belvedere, I have a chance To buy one, it has a great chrome finish and it looks great! Trick question: A North American 55 Chrysler (and Dodge and Desoto) used a different power brake system (Bendix) than what you are showing so I don't know what you have. But there is a good chance that the chrome one would work. (MAYBE) 1955 NAmerican Chrysler: Vacuum tank part numbers: Edited by 56D500boy 2018-01-16 1:27 AM (55-58BrakeVacuumTankPNs.jpg) Attachments ---------------- 55-58BrakeVacuumTankPNs.jpg (129KB - 149 downloads) | ||
roblun |
Veteran Posts: 201 Location: Fremantle, Western Australia, Australia | Thanks for the reply, this is my setup (25991105_399220867200209_182783868a_o.jpg) Attachments ---------------- 25991105_399220867200209_182783868a_o.jpg (226KB - 155 downloads) | ||
roblun |
Veteran Posts: 201 Location: Fremantle, Western Australia, Australia | They look very similar (24129951_10210861247470603_6049992608703370668_n.jpg) (IMG_0627.JPG) (IMG_0636.PNG) Attachments ---------------- 24129951_10210861247470603_6049992608703370668_n.jpg (198KB - 183 downloads) IMG_0627.JPG (201KB - 153 downloads) IMG_0636.PNG (248KB - 156 downloads) | ||
Expert 5K+ Posts: 9894 Location: Lower Mainland BC | Looks similar to my 56 Dodge vacuum tank too. The issue will be the size and location of the "feet"/brackets on the two tanks. That is assuming you have to have the bling. | ||
roblun |
Veteran Posts: 201 Location: Fremantle, Western Australia, Australia | Im just waiting to see some more photos and then I'll make up my mind, just need to know the Bracket position, I know its a bit of a Bling but it looks in pretty good shape compared to mine, Thank you for your Input 56D500boy Edited by roblun 2018-01-15 11:02 PM | ||
LostDeere59 |
Extreme Veteran Posts: 406 Location: Hilltown, PA | From a functional standpoint a vacuum reservoir is a vacuum reservoir - they are all interchangeable to some degree. Variations that would need to be considered are: Volume - obviously a significantly smaller tank would not be able to supply the required volume of "not air" to effectively operate the brake booster. Fitting size - not only do you want your hoses to be able to connect, you don't want the fittings to create a restriction. Other than that, if the volume is appropriate (too big is fine) and the fittings don't present a concern, if you can mount it and connect it, it will work. The only operational component is the check valve, and all check valves are the same - flows one way, doesn't flow the other. Gregg | ||
roblun |
Veteran Posts: 201 Location: Fremantle, Western Australia, Australia | Thanks Gregg for the extra information, much appreciated... cheers Regards Roberto | ||
mstrug |
Expert 5K+ Posts: 6498 Location: Newark, Texas (Fort Worth) | If you don't buy it I will. Let me know. Marc. | ||
roblun |
Veteran Posts: 201 Location: Fremantle, Western Australia, Australia | Hi Marc, Just waiting for Peter to reply to my email, sounds like he got flooded with to many emails | ||
