1959 Dodge Sierra Generator to Squareback Alternator
Cataldo
Posted 2018-02-04 12:48 PM (#557494)
Subject: 1959 Dodge Sierra Generator to Squareback Alternator
Hello everyone,
So I just successfully installed my late 70's 440 into my '59 Dodge. I have several hurdles to bound now, the first is alternator wiring.
I have all of the original wiring in place, with the original Voltage Regulator. I understand the need to ground this duel field squareback alternator with a ground wire from one of the field terminals.
1. Can I just hook the black wire from a ground on the voltage regulator to the field terminal?
2. Can I simply just hook the red and green factory wires to alternator?
3. Will the original Voltage Regulator that is currently on the car work with this Alternator?
Also I need to figure out a Radiator for this thing if anyone has a suggestion.
Posted 2018-02-04 3:01 PM (#557509 - in reply to #557494)
Subject: RE: 1959 Dodge Sierra Generator to Squareback Alternator
200050010010010025
The generator regulator won't work with an alternator. Grounding one field terminal is only necessary when using the pre-'70 electro-mechanical regulator with the dual field alternator, the dual field alternator has its own dedicated regulator, wire it as shown below.
Edited by 57chizler 2018-02-04 3:04 PM
(Alt wiring (Large).gif)
Attachments Alt wiring (Large).gif (22KB - 3 downloads)
Cataldo
Posted 2018-02-04 7:04 PM (#557521 - in reply to #557494)
Subject: Re: 1959 Dodge Sierra Generator to Squareback Alternator
Ah thank you.
So i just need to pick up a later sttle voltage regulator.
Posted 2018-02-07 3:28 PM (#557652 - in reply to #557521)
200050010010010025
And the connector, available at your LAS.
(VR Connector.jpg)
Attachments VR Connector.jpg (18KB - 3 downloads)
