KYB rear shocks failed.
Posted 2018-02-14 5:03 AM (#558087)
Subject: KYB rear shocks failed.
200050010010010025
I put my Imperial on my hoist (2 post) for the first time 2 weeks ago. When I lowered the car one rear shock spewed about a cup of oil and the other a couple tea spoons full of stinky oil. Smelt like a cattle truck nearby! Luckily I had the old Munroe's in the shed, they went back on.
First time i have seen this on any car, anyone else seen this?
Steve.
StillOutThere
Posted 2018-02-14 5:40 AM (#558088 - in reply to #558087)
Subject: Re: KYB rear shocks failed.
20005001001001002525
Which type of KYB? Must not be the Gas-a-Just which have gas rather than oil. Are your rear springs badly worn? Too many hobbyist believe the shocks hold up the car. They don't. The springs do. Air schocks will help hold a car up but it is stillmainly the springs job.
Shep
Posted 2018-02-14 1:20 PM (#558103 - in reply to #558088)
2000100025
This can occur if the shocks bottom out or are repeatedly over extended. Measure if in the mounted loaded position they are in approximately mid stroke.
Posted 2018-02-15 6:43 AM (#558131 - in reply to #558088)
200050010010010025
StillOutThere - 2018-02-14 7:40 PM
I call them Gas-a-Bust!
I got the KYB shocks recommended by people on this and the OIC sites for both ends of the car. KG5511 in the back. Let me tell you there is some stinky oil in them. I thought the gas shocks had the gas on top of the oil to reduce foaming etc?
My 60 Imperial has aftermarket rear helper springs that are adjustable (was a tow car at some point in its life) and the original springs are in excellent condition. The rear suspension also has the √ćmperial" torque bars. I dont know why it happened, but either I did something wrong or the shocks were defective.
I might cut one up and have a closer look.
BTW. the old Munroe's feel good!
Steve.
