fuel pump glass bowl
57RID500
Posted 2018-03-07 7:33 AM (#559388)
Subject: fuel pump glass bowl
I have a 1957 Dodge D 500 single four barrel.
Question for the group:
Does the original fuel pump, have a glass bowl attached to the bottom of the fuel pump? That is what is on my car and I have one, which was removed that id like to rebuild, if its correct.
Thanks Bob
ronbo97
Posted 2018-03-07 2:46 PM (#559411 - in reply to #559388)
Subject: RE: fuel pump glass bowl
2000200025
No. That's an aftermarket. Glass bowl for fuel filter is up by carb.
Ron
LD3 Greg
Posted 2018-03-08 12:03 AM (#559434 - in reply to #559411)
I agree. Glass bowl at the base of the fuel pump was a 58 thing.
Greg
57RID500
Posted 2018-03-08 2:02 PM (#559461 - in reply to #559388)
Subject: Re: fuel pump glass bowl
Yes I have two. One glass sediment bowl attached to the bottom of the pump and another glass bowl at the carb.
Posted 2018-03-08 4:02 PM (#559469 - in reply to #559461)
500020002000500100252525
Not sure I've seen the glass bowl on the bottom of the pump.  I've had several '58s, but none of them had anything other than the regular-looking pump.
Many of mine have had the carter glass bowl and (hard - like a porous rock) filter near the carb end.
Edited by Lancer Mike 2018-03-08 4:09 PM
christine-lover
Posted 2018-03-08 7:28 PM (#559481 - in reply to #559469)
2000500100100100100252525
Some 58 engines had glass bowl fuel pumps, the B block in particular, Carter model 2662S, which I believe 1959s also had them? Not sure about 1957.
Edited by christine-lover 2018-03-08 7:29 PM
LD3 Greg
Posted 2018-03-08 11:56 PM (#559488 - in reply to #559481)
I think 58, 354s and 392s all were originally equipped with glass bowl fuel pumps. They also used those same ceramic filter elements.
Greg
LD3 Greg
Posted 2018-03-09 12:09 AM (#559489 - in reply to #559488)
Incidentally, those Carter bowl type fuel filters also had a small but powerful magnet secured in the aluminum housing to attract/remove any steel filings etc. from the system. A very efficient method.
Greg
