58 300D 392 fuel pump questions
58 300D
Posted 2018-03-07 10:57 AM (#559396)
Subject: 58 300D 392 fuel pump questions
5002525
My fuel pump is leaking. Reading through old threads and a quick online search, these are obsolete. There are three main options: Electric fuel pump, a 318 (Carter M6270?) fuel pump with the adaptor, or rebuild the original. Mine is the original with the glass bowl. Is there a rebuild kit available? I'd rather go this route. Any suggestions appreciated.
KcImperial
Posted 2018-03-07 11:17 AM (#559398 - in reply to #559396)
Subject: Re: 58 300D 392 fuel pump questions
2000100100100100252525
I believe http://www.then-now-auto.com/fuel-pumps/ is the only source for rebuild kit for a 392 pump that is also ethanol resistant
ronbo97
Posted 2018-03-07 2:44 PM (#559410 - in reply to #559396)
Subject: RE: 58 300D 392 fuel pump questions
2000200025
58 300D - 2018-03-07 10:57 AM My fuel pump is leaking. Reading through old threads and a quick online search, these are obsolete. There are three main options: Electric fuel pump, a 318 (Carter M6270?) fuel pump with the adaptor, or rebuild the original. Mine is the original with the glass bowl. Is there a rebuild kit available? I'd rather go this route. Any suggestions appreciated.
Glass bowl on fuel pump is not original. Original fuel pump was Carter M2610S (1843359). Glass bowl for fuel filter is up by carbs.
Ron
KcImperial
Posted 2018-03-07 3:13 PM (#559414 - in reply to #559396)
I have glass bowls on the pump on my 58's but not on my 57
